Question about Whirlpool GEW9250 Electric Dryer
Whirlpool Duet Steam Dryer Beeping
I have a Whirlpool Duet Steam Dryer and it beeps during drying. When I open the dryer door, the beeping stops, but the clothes is not dry. This is a brand new dryer.
  • Anonymous Jan 01, 2009
    same problem- dryer beeping while it is running. If I open and close the door the beeping stops.
  • 15,935 Answers
Symptom: Dryer turns on, drum spins, but you have no heat.
Any of the following components are more than likely suspect as being bad:
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
All these components COMBINED, should cost less than $100. If you fix it yourself, you will avoid the additional cost for labor.
If the dryer isn't blowing ANY air at all, but the drum still turns, you may have a bad blower fan assembly inside the dryer. Or, the blower fan assembly may be clogged.
If your dryer performance has been failing (i.e., clothes taking longer to dry), it may be for a reason. You need to ask yourself when the last time you cleaned the dryer ventilation. If you can't remember, or if it has never been done, this can contribute to the dryer failing. All dryers need proper air flow in order to dry properly. If the ducting becomes clogged, the heating circuits will actually overheat and eventually fail. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced. Remove the dryer hose from the back of the dryer and inspect it thoroughly from where it leaves the dryer to where it exits your home. It should be clear with no kinks or clogs. If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect. RULE OF THUMB: The SHORTER and STRAIGHTER the vent duct, the BETTER. After you inspect the vent ducting, turn the dryer on and make sure you have forceful air flow coming form the dryer. This will prove that your blower fan is working properly or not. Since you stated that your dryer is not currently heating, the air will be cold, but you should still have some force behind it. If the air flow is weak, you need to clean the duct work INSIDE the dryer. It is important to keep a dryer checked routinely. I recommend once per season (that's 4 times per year). Dryers are the cause of many house fires. These fires are due to lint accumulations inside the unit catching on fire. A little preventive maintenance can prevent significant problems in the future.
Getting to the heating circuit to determine if the components are good or bad is the next step. If your dryer has the lint screen on the top of the unit, you will need to remove the back panel of the dryer to expose the heating circuits. If the dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. If this is a Kenmore Elite or Whirlpool Duet, the lower lick panel comes off by removing the screws under the bottom edge of the panel. (HINT: placing a block of wood under the front feet of the dryer can make access much easier). If your dryer has no lower kick panel, you have to remove the entire front panel on these models. This is accomplished by lifting the dryer top and removing the screws that hold the front panel in place.
NOTE: The heating circuit should be troubleshot with the dryer UNPLUGGED. Dangerous voltages are still present with the dryer turned off. Resistance readings are as follows:
Heating Element (located inside heater box) - remove the two leads from the ceramic terminals on the heating element and take a reading across the terminal points. It should read 9 - 13 ohms.
Thermal Cut-Out (TCO) (mounted to the heater box.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
Hi-Limit Thermostat (mounted to the heater box, closest to the heating element leads) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component. NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended by most manufacturers to replace BOTH components at the same time. They are often sold as a set. Without doing so, these components can cause potentially fail again.
NOTE: One item I failed to mention - Double check the input power for your dryer FIRST. You should have 220VAC at the receptacle and terminal block. The dryer will STILL tumble and the timer will still function with a portion of the input power missing as these circuits only require 110VAC. The heating circuits, however, require 220VAC to function. If one leg of the receptacle voltage is missing the dryer may exhibit "No Heat" like symptoms. This could also be an indication of a burned or failed power cord. Continuity checks performed with the dryer UNPLUGGED should indicate a short between the prong end of the cord and the respective lugs at the terminal block.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!@#$%^
Posted on Sep 30, 2010
2 Suggested Answers
  • 36 Answers
SOURCE: Whirlpool Duet Dryer WED9600 Beeping during drying
Dear Customer
Please perform the following
please rate this,thank u
Posted on Dec 16, 2008
My washer will run for a short time and them stop and just beep repeatidly
Frigidaire washer beeps for no reason, driving us crazy ...
? 1:03
https://www.youtube.com/watch?v=gP51k2bhbbg
Nov 6, 2011 - Uploaded by NatalieJonathan
Our Frigidaire washer keeps giving us ridiculous beeping issues, and for no reason. ... Mine stack dryer above ...
My washer pauses during wash cycle and will not restart ...
www.shopyourway.com > Manage My Life > Questions
The washer will stop during wash cycle and just beep. Sometimes we can turn it off and it will run again. Getting worse ... My washer is a Whirlpool 3.5 cu. ft.
FIXED Whirlpool Duet Washer Stops and Beeps - ApplianceBlog
www.applianceblog.com/.../48786-Whirlpool-Duet-Washer-Stops-and-B...
Jan 16, 2015 - 6 posts - ‎2 authors
It's a front loading Whirlpool Duet Washer 4.0 cu ft, with Tumblefresh ... wet it stopswashing and starts beeping (three beeps, pause, three beeps, pause, etc). ... The clip that holds them into the CCU (I think that's the right term) has a ... with my fingers so I could get a couple loads of laundry done until I can .
Jan 05, 2016 | Washing Machines
Dryer won't start, push the start button it just beeps
It is possible you have a broken drum belt. You may need to call a qualified service man as changing a belt can be tricky.
Oct 01, 2015 | Whirlpool Duet WED9550WW 27" Electric...
Dryer beeps during dry cycle
if the dryer is beeping on it's own most likely you have a bad board part WP8563974
Oct 28, 2017 | Whirlpool Cabrio WED6400SW Electric Dryer
What does beeping mean during dry cycle?
My dryer did the same thing, it was so distrubing noise in the middle of drying cycles, so I turned off the sound switch it went away, now it doesn’t peep any more.
Oct 28, 2017 | Whirlpool Cabrio WTW6600SBT Top Load...
Dryer runs but beeps intermitenly and doesn't stop beeping
you most likely have a bad computer board located in the top console.i haven't changed any of these boards out but on the frigidaire affinity dryer this happens alot and it's the computer board.the dryer would just start beeping on it's own,like 3 beeps at a time beep beep beep,then beep beep beep,was the board,you have to give the full model number to whoever you order the board from,open the dryer door,look around the opening where you put the clothes in and you'll see a tag with the full model number.good luck.
Feb 25, 2014 | Whirlpool GEW9868K Electric Dryer
Won't start, keeps beeping when i push start.
The door switch has gone bad. Replace door switch and you should be good to go.
May 16, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dear Customer
Dec 16, 2008 | Whirlpool GEW9250 Electric Dryer
Won't start, beeping sounds
sounds like the door switch might be an issue,, does teh tub light go on /off as you open the door??? if not try manually pushing the switch in a few times.
Oct 25, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
991 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
