Question about Seagate 500GB Maxtor Diamondmax21 SATA2 Hard Disk Drive 7200rpm 16MB STM3500630AS 500 GB SATA Hard Drive
Seagate 40 gb big problem please
Hi , I am Nabi from india,WB .I Faced a big trouble in a seagate 40gb Pata internal Harddisk.iam using this harddisk last 3years problem is that when partition this hdd its partition no problem but when i reboot and check it is same condition then i am format this hdd after reboot it's same then i tried from seagte DM zero filling and low level format it's same condition.No problem comes under this all process.i can read all data from harddisk when i save some docs it's show ok but not save.
I'd take a look at the <a rel='nofollow' href="http://segate.com">Segate</a> website.
Posted on Dec 16, 2008
My 120 Gb seagate Sata harddisk got fired due to high voltage shock. What can i do. Is there any way i can reapair it. Is there any way i can replace the logic board of it with 80 Gb board and try.
I understand the value of the files that resides on the disk:) Yes! It is possible that harddisk may back to life by replacing the logic board but of the same model or part number. If it is not possible by replacing logic board due to other defects such as head crash and spindle drive motor opened/shorted, there still a big chance to recover depending how you value the data on it by contacting international Seagate Data Recovery support service with considerable service fee. Hope this helps.
Mar 04, 2014 | Seagate BARRACUDA Computers & Internet
Haw can chaqe my 40gb harddisk as garranty posion
This hard drive is very old and the guarantee period is for one year from the date of purchase. Therefore it is no longer under warranty.
Seagate no longer manufactures a hard drive of 40Gb capacity, the hard drive are now over 100Gb in capacity.
Sep 03, 2010 | Seagate Barracuda 7200.7 40 GB Hard Drive
Iam having p3 proceessor,133mhz, 810e chipset, motherboard,512mb sd ram,80gb seagate harddisk. iwant to upgrade my harddisk like 160 gb or 250 gb. is it compatible with this configuration. ...
You can put a 160gb on it as is with no trouble, but should add ram to at least 1 gig to make better use of your system. Hope this helps:)
Aug 24, 2010 | Computers & Internet
I have samsung 40 gb harddisk how to make a zrero fill.
Are you trying to wipe the data from this hard disk by writing ones and zeros on the hard disk?
There are programs such as Wipedisk available on the Internet, do a Google search for such programs.
Sep 11, 2009 | Seagate HDD 40GB 7200RPM ATA100 2MB...
Hard disk problem
try the partition magic software it will slove your problem
Jan 18, 2009 | Computers & Internet
Hard disk problem
you may try formating into a linux partion first using partion magic and then to any of the windows partition
Jan 18, 2009 | Seagate 40GB EE25 5400.2 Ruggedized PATA...
Unable to detect 250GB Seagate hard disk on P4 PC
you need bios update
download bios express installation file
install first any 40 or 80 gb ide harddisk install windows and run express installation file
your motherboard will update your bios
download from http://www.updrivers.com/search/d845glly
or
http://www.updrivers.com/getdriver/Motherboard/Intel/D845GLLY-BIOS/10018.html
Oct 17, 2008 | Intel D845GLLY Motherboard
Maximum size of hard disk supported
Hi Bijay.
Neither is at fault. Please click on this Seagate link:
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=How_To_Install_and_Troubleshoot_ATA_Hard_Drives&vgnextoid=559e5b1142aec010VgnVCM100000dd04090aRCRD
Scroll down to: Partitioning the drive in Windows XP / Windows 2000 (for systems where this is the 2nd drive in the system).
Follow the instruction on the web site.
This Seagate web site will help you setup the Seagate 160 drive.
If you feel the drive is still at fault you can run Seagate’s SeaTools. Click on the next link:
http://www.seagate.com/www/en-us/support/downloads/seatools
This software will check the 160GB drive.
(Follow the online instructions for), SeaTools for DOS.
In a Windows XP system & using a FAT 32 & a cluster size of 16kb instead of NTFS. Windows will see the total size of the drive but can only access 149GB of drive space. 11GB of drive space will be used by the FAT. File Allocation Table. The FAT is windows guide to every cluster on the drive.
XP uses NTFS & sets each cluster to 4kb. This 4kb size lowers the total usable GB size & uses more GB's for the FAT. You're 127GB size may be correct for a Win XP system using a NTFS file system. The FAT is using 33GB of drive space as a locator for every cluster on the 160GB drive.
Help with understanding the NTFS file system: http://www.microsoft.com/windowsxp/using/setup/expert/russel_october01.mspx
Bijay if you are still having trouble understanding please post any questions here.
Mike
Aug 12, 2008 | Intel D845GLLY Motherboard
Seek rate problem in Seagate 200 GB
Hey, I recommend you test the harddrive with seagates own tools.
http://www.seagate.com/www/en-us/support/downloads/seatools/
I recommend the dos version.
Also try active smart
http://www.ariolic.com/activesmart/index.html
I would recommend backing up all the data from the drive, and then if the drive still has problems You should send it for warranty repairs. Shouldnt cost a thing.
You can also take it to a local pc repair shop to get all the data copyed and then sent to warranty service if nessasary it will cost thought if you do it via a shop.
Feb 21, 2008 | Seagate Barracuda 7200.7 200 GB Hard Drive
Seagate 500GB Maxtor Diamondmax21 SATA2 Hard Disk Drive 7200rpm 16MB STM3500630AS 500 GB SATA Hard Drive Logo
312 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
