I need the code for a sylvania TV for my RCA universal remote. And I also need to know which button to press in order to get the remote to the point where I can put that code in, or have the remote search for the right code for the TV. I dont have the instruction booklet. I went to the website www.rca.com/codefinder but that website didn't work for the links.
    Top Expert:
  • Televison & ... Master
  • 74,887 Answers
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
Posted on Sep 23, 2017
SOURCE: codes
i need the code # for my RCA DIRE.TV #RCR160SBM1
Posted on Mar 25, 2008
VOTIT
  • 2071 Answers
SOURCE: RCA Universal remote
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Aug 25, 2008
SOURCE: Bought the RCA universal remote
Does any remote work with Sylvania SST4192 TV? I looked at the front panel and did not see an infra-red sensor.
Posted on Nov 26, 2008
crayzeetrayn
  • 837 Answers
SOURCE: LOST MY INSTRUCTION MANUAL FOR MY RCA DIRECTV UNIVERSAL REMOTE
Here's an on-line guide
Here's a codes page (Sylvania 10054, 10030, 10171,10020, 10096, 10381)
Posted on Jan 04, 2009
Universal Remote Codes Not Working
Probably your RCA remote control does not have a specific code for your Sylvania TV. all universal remote controls do not contain all possible codes. You may have to try a different universal remote control. Follow the specific instructions for programming.
Jul 14, 2017 | Sylvania 6419TC 19" TV
I have a Sylvania 6424FF tv and i cant get it programmed to a univeral RCA remote the codes listed are NOT working
Hello
RCA- RCU 500 model universal remote has Sylvania TV coded with. The codes are:
006,007,010,011,013,016,027,
033,035,043,049,066,087,089
Programming method
[1] Press the button of the device you want to
control (for example TV).
[2] If the device turns on, press another button,
to confirm (for example CHANNEL UP)
[3] If the device you selected (TV) responds,
you will not need to program the remote.
If the device you selected (TV) does
not respond, you will need to program
the remote
There are very rare RCA remotes, with Sylvania TV can be programmed. Just try the above codes with your present RCA remote control. If it does not help, buy the above model RCA universal remote. You will get code list and all other related documents, how to programme it or so, with the device you do purchase. OK.
Jun 14, 2011 | Sylvania 6424FF TV
How do you program an RCA "RCR 615 DCM1" universal remote? Any instructions out there?
I know this is an old post, however if anyone else needs to know how to program the RCA RCR 615 DCM1 universal remote here is how: Turn on the device you wish to program, dold the device button you wish to program (tv, vcr, dvd, etc.) While holding the button with one hand, press and hold the power button with the other, hold both buttons until the device button lights up and stays on then release both buttons at once. Light should remain on. Point remote toward the device and press play button every 5 seconds until device shuts off. Once the device shuts off, with remote still pointed toward the device, slowly hit the reverse button (rewind button) until the device turns on again and then hit stop button. Now your device should be programmed. Repeat for each device. Hope this helps someone, because I had this problem myself and I played around with the remote until I figured it out . This may work for other RCA RCR----- remotes as well.
Apr 29, 2010 | RCA Universal Remote Control
Programing rca rcr451 to sylvania no codes just instructions
1. press and hold code search button until it stays on.
2. press button on remote for device
3. enter three digit number and code search light should turn off and remote should be ready.
if this doesn't work here is the manual for the remote.
http://www.scribd.com/doc/2218751/RCA-Universal-Remote-Codes
May 26, 2009 | RCA Universal Remote Control
I lost my sylvania remote and bought an RCA universal remote
hello here is how you get your remote to work...make sure tv is on
step 1.hold down code search button till you see the red light
step2. let go of code search button and hit TV once light should blink
step3. press and release the power button while pointong a TV u ((may have to press the power button several times)) once the Tv powers off press the enter button once
step4. press tv button and hit power
Mar 07, 2009 | Zenith DBZN-311 Remote Control
Will not work for a sylvania tv
Whats The Tv And The Remote Model?
Jan 23, 2009 | RCA Universal Remote Control
Rca remote
Finding a code for one TV could take a long time, here's what you do
1. Press the TV button once 2. Press and hold "Code Search" until it lights up 3. Point the remote at your TV with the TV on, and keep pressing the power button until the TV shuts off 4. Press the TV button once more.
Jan 21, 2009 | RCA Universal Remote Control
I have a rca universal remote,and i have a old sylvania tv,but none of the codes yall had worked.is there anything you can do for me?
remove the batterys from the remote. press and hold each button for about 2 seconds. be sure you press all buttons. reinstall batterys and try again. this will reset the remote to factory specs
Dec 18, 2008 | RCA Universal Remote Control
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
