Question about T-Mobile Sidekick II
A sidekick3 that dont power on
The problem is the unit dont turn on or charge for that matter. it havent been dropped,i bought a new charger thinkin it was the charger still nothing,i also changed the battery around still no progress also i tryed it without the battery still nothing.
Well the same thing happen to me but i call t-mobile and they tell me to press @ 1 and 0 at the same time and it should reset it self it doesn't work for me but you can try it
Posted on Jun 28, 2007
Inspiron 1501 charging problem
should find out why the original charger stopped working in the first place... was it a faulty mother board really. anyway if the ratings on the charger you bought are for that laptop indeed, then it should power up the laptop minus the battery. ofcourse if you put in charger minus battery, dont expect it to show the charging led..just try to power it on
Regards
Feb 26, 2010 | Dell Inspiron 1501 Notebook
Ds lite comes on for a sec when charger plugged in then it goes of unit does not come on or charge
Hi three things come to mind, you dropped it but usually they wont admit it (dont go mad they usually all break when you do) if it rattles the capacitor under the power switch just fell off (common you have to solder it back on) if not that you replaced the bottom screen and forgot to insulate the metal of the back of the screen against the circuit board and blew either the f1 or f2 fuses (Replace them if you did) last thing i wont go into if you havent pulled it apart if you have reply and i will tell you Good Luck
May 20, 2009 | Nintendo DS Lite - Onyx
Phone switches off when charging using car charger
the phone appears to switch off when I plug it into my charger and restart again show only charging message havent a clue why,plz help me on this matter. thanks
Aug 21, 2008 | Motorola Mobility A1000
Sidekick3
The sidekick 3 has an issue with thte charging port. If you have a friend with a sidekick 3 or sidekick ID, try one of their batteries. If your unit powers on, the charging port has gone bad.
the repair for a charginf port runs about 80-100 dollars. A cheaper work around is to get a charging cradle that has a spare battery charger slot. They run about 30 dollars on ebay and it will allow you to charge the bettery seperate from the phone.
Check out the following link for cradles.
http://repairmysidekick.org/SideKick-Repair-Parts/Sidekick-3-Spare-Battery-Charger
Mar 29, 2008 | T-Mobile Sidekick® 3 Cellular Phone
My sidekick wont work
It seems your charger port is broken, it hapfens often on cellphones, wear and tear. Check to see if its under warranty, and it can be replaced. Check my profile if you need more help.
Jan 24, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick problem
It looks like it's a battery related problem . You should get a new battery. Good luck!
Dec 12, 2007 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick3 got wet
those kind of problems are fixed by totally changing the parts... because nano technology is very hard to fix..
you could also try opening it and clean a bit the outside of the lens and see if that helps.. but i doubt it because it could be or will be a sulfated contact
Nov 04, 2007 | T-Mobile Sidekick® 3 Cellular Phone
My problem is with the sidekick III, it wont charge, What should I Do?
dnt drain the batteries of your phones...if that happens pls buy multicharger or battery shock,remove the battery..... charge it for about 5min or shock the battery if ur using battery shock...be sure u positioned it ryt....den put it back on ur phone then charge it or continue the charging on the multicharger until its full !!!!im pretty sure of it....im encountering the same prob as urs before and thats what i did and it work!!!!
Jun 09, 2007 | T-Mobile Sidekick II
A sidekick3 that dont turn on
The sidekick 3 has a known issue with the charging port. If it is under warranty call t-mobile.
If not, you can get it fixed for 90-100 dollars.
The other solution is to get a external battery cradle with spare battery charger and an extra battery. This runs about 40 bucks on ebay.
Mar 20, 2007 | T-Mobile Sidekick II
T-Mobile Sidekick II Logo
Top T-Mobile Computers & Internet Experts
ismael castillo
Marvin
Marvin
Edward Talavera
Edward Talavera
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
