Question about Dell Dimension 4550 PC Desktop
No ethernet controller in device manager
Cannot install ethernet adapter after fresh xp install on dell diension 4550. driver is not present in device manager after i install it off resource disc
  • bognerl Jan 19, 2009
    I installed a new XP pro sp2, and there is no ethernet controller. I put in a Linux live disc, and everything works fine, so I don't think I have a hardware problem. What's up?
  • 2,427 Answers
You need to flash the cmos.. To do this open it up and look for a switch inside the system., press for 5 seconds and release.
If you cant find the switch or there isnt one, then locate the battery on the board (its a big watch battery) pry it off, hold the power button down for 1 minute, the press it 5 times, replace the battery.
NB: UNPLUG THE SYSTEM BEFORE ATTEMPTING THE ABOVE. Once this is done follow the onscreen instructions to enter the bios or setup, load optimised defaults then save and exit. Your device will now show up in the device manager.
Posted on Dec 16, 2008
I have an old Dell dimension 4550, I just got it from a friend, the enternet wont work. It says no wirelless or wired devices found and no drivers. I downloaded drivers onto a flash drive and tried to...
hi your problem is that you should set the connection to internet
Dell Dimension 4550 (Pentium 4 2.66GHz, 256MB RAM, 60GB HDD, XP Home)
first you need to go to:
control panel>system>device manager>check if appears the ethernet car if it does then.
go to control panel>network conection>properties>select tcp/ip go to properties check and make sure the option of automatic ip and the automatic dns select it and you are ready....
May 27, 2011 | Dell Dimension 4550 PC Desktop
Dell dimension 4550 ethernet driver please
Dell dimension 4550 Ethernet Driver Installation Guide
1. Go here to download and install the Chipset - Intel driver.
2. Restart the computer.
3. Then go here to download and install the Ethernet driver.
4. Restart again.
Aug 20, 2010 | Dell Dimension 4550 PC Desktop
I install new windows and ethernet controller is not working and I can't get on the internet? What can I do?
Purchase a USB memory-stick.
On another computer with Internet access, access: http://support.dell.com and select "Downloads and Drivers". Select "Dimension". Select "4550".
Select "Network Adapters". Download the device-driver, copying it to the memory-stick.
Move the memory-stick to your computer, and "install" the device-driver.
Feb 02, 2010 | Dell Dimension 4550 PC Desktop
Just reinstalled xp on a dell dimension desktop 8250 and the ethernet NIC Card just does not show up in the network settings. Everytime I look up the card in Device Manager it has a question mark. I did...
if u have another way to contact dells website with eather a flash usb or a cd get the drivers from dell for you nic then go start/control/system/device manager and update your drivers for that nic
Dec 05, 2009 | Dell Ethernet Card Network Adapter
Reformated my Dell Dimension 2400, now under device manager I got the big yellow question mark for Other Devices - Ethernet Controller -PCI Simple Communications Controller Dell's driver support page does...
If you have windows Vista simply Right Click on the entry in device manager and choose Update driver (Requires working internet connection)
Else use the following drivers (Works on XP and vista)
ftp://ftp.us.dell.com/network/R64645.EXE
Oct 16, 2009 | Dell Ethernet Card Network Adapter
My dell inpirion notebook broke so i thought i'd install the
For Windows 2000 or XP:
1. Click on Start, go to Settings and then Control Panel.
2. Click on System, go to Hardware and then Device Manager.
3. Click the (+) sign on Network Adapters and select the adapter.
4. Double click on it and read the Device Status.
if device is working properly, close device manager
Checking your Network Connections settings;
For Windows 2000 and XP:
a. Please click on Start, select Settings and then Control Panel.
b. Double click on the Network Connections icon.
c. Right click on Local Area Connection and click on Properties.
d. Scroll down to Internet Protocol (TCP/IP) and click on Properties.
e. Select the option Obtain an IP address automatically and Obtain DNS server automatically.
f. Then, click on OK.
To test your network;
Windows XP
1. Please click on Start on the lower left hand side of your computer screen.
2. Click on Run.
3. In the Run box, please type in cmd.
4. Then, please click on the OK button.
5. Please type in ping www.google.com.
6. Press on Enter key.
7. The packets sent and received should be a total of 4.
If you have 4 replies, then you are online.
Apr 14, 2009 | Dell Dimension 4550 PC Desktop
Reinstall Ethernet Adaptor after Reinstalling O/S
Does the ethernet card have a yellow or red checkmark. If its yellow, select the device and then select turn it on. If it's red, right click on it and select uninstall. Rebbot Windows and allow it to find the card or at least provide an error.
Mar 24, 2009 | Dell Dimension 4550 PC Desktop
The network adapter in a dell dimension PC running XP home
Ethernet controllers click here
Check for drivers on that site, however much better that you know the brand of your LAN adapter.
Mar 15, 2009 | Dell Dimension 8250 PC Desktop
Ethernet card vanished from the list
xp will have basic drivers..go to the control panel, device manager, and have the system look at the hardware again( at top of the panel, there is an option for action) click on any of the items in the panel, and then Action, Scan for hardware changes..follow those instructions..it may ask for the drivers and utilities disk in that process..
Oct 16, 2008 | Dell Dimension 2350 PC Desktop
Dell Dimension 4550 PC Desktop Logo
1,553 people viewed this question
Alun Cox
