Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Broiler and oven igniter the same?
Both the oven and the broiler aren't working. When I checked online to order the oven igniter and broiler igniter, they were the same part number. Do I only need one? My model number is JGBP85WEB1WW.
  • 1 more comment
  • rebecca sears Nov 06, 2007
    It turned out that my broiler was working, it just took longer to ignite than I expected. So, I ended up paying someone to do something I could have done myself.
  • Anonymous Mar 15, 2014
    oven works. model MER550BAW
  • Anonymous Mar 16, 2014
    How do I swap out broiler igniter with oven One
    Problem Solver:
  • 11 Answers
You may not need a igniter. the problem could be with your control board which supplies power to both the broil igniter and the oven igniter. In my years of working on ovens i have not seen a oven that needed both igniters replaced.
Posted on Mar 21, 2007
SOURCE:
Model ew30gs65gsc. Why is broiler not igniting?
Electrolux Oven Broiler Not Working - Model E30DF74EPS ...
www.repairclinic.com/...Range-Stove-Oven/...-/Electrolux-Oven-broiler-...
Most Frequent Causes for Oven broiler not working. See All Range/Stove/Oven Parts for model E30DF74EPS. Cause 1 Temperature Control Thermostat.
Electrolux Oven Broiler Not Working - Model EW27EW65GS6
Electrolux oven broiler not working? Use our DIY troubleshooting & videos. Then, get the parts you need fast. Return any part for 365 days.
Oven Broiler Not Working - Repair Parts - RepairClinic.com
www.repairclinic.com/...Range-Stove-Oven/...---/Oven-broiler-not-worki...
Oven broiler not working? Use our DIY troubleshooting & videos. Then, get the partsyou need fast. Return any part for 365 days.
Gas Oven/Broiler not working/igniting - ApplianceBlog
Jan 13, 2016 | Electrolux Kitchen Ranges
Amana arg7102w gas range broiler works fine but regular oven doesn't heat up, viewed igniter from the back while turned on and see igniter glow but no gas flowing, can't find service manual online...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jul 12, 2011 | Amana Microwave Ovens
GE HotPoint XL44 Gas Range Model RGB528
My bet is that the broiler ignitor has been out for a while and you just never knew it...
I would change the ignitor as a first try to fix it it is themost common failure..
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Apr 27, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Broiler works Bake Oven doesn
The first thing to check is the oven igniter, check for spilled foods on igniter and clean if necessary
Dec 12, 2009 | Televison & Video
GE XL 44 gas oven not working. I replaced the igniter for the oven, but not the one for the broiler. Also replaced the regulator valve. Still doesn't work. I didn't replace the broiler igniter as we...
most newer models of gas oven require electricity in order to work. I would check the outlet where you have your oven plugged in. Plug something else into that outlet to make sure it is live. If it is not, check the electrical panel breaker or fuse.
Oct 29, 2009 | Kitchen Ranges
Gas Oven will not ignite. Broiler and burners
The ignitor for your oven is worn out and needs to be replaced.
Oct 02, 2009 | Kitchen Ranges
Amana broiler problem
Each burner manifold in the oven has its own igniter. If the igniter is defective, the burner assembly will not light. The igniter has to be functioning properly in order for the gas safety valve to open. This is a designed safety feature that prevents free flowing gas from entering the oven cavity without ignition. This reduces the risk of explosions.
There should be a flame spreader metal plate covering the access over the broiler. You will need to access the broiler so you can view the broiler manifold and igniter. Turn the oven setting to broil and make sure the igniter begins to glow. If the igniter fails to glow, replace it. If the igniter does glow, but you still do not have ignition after 90 seconds, the igniter may be weak and still require replacement. The following link explains oven igniter types, their current potential, and how to replace them:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
If you have questions, or require additional assistance, please let me know before you rate the solution. I hope this helps you.
Jan 29, 2009 | Amana RanARG7302 Gas Kitchen Range
Oven/Broiler Igniters for KitchenAid range KGST307
Oven bake ignites usually have lifetime 5-7 years. If igniter glows but gas not came in - replace igniter. Same with broil igniter.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Dec 09, 2008 | Ovens
Guy, your missing some letters at the end of the model but I compared 4 different gas slide in's starting with KGST307 and the part numbers are bake ignitor 9751123 and broil 9751784. Catriver..post back
Apr 02, 2007 | KitchenAid KGST307 Gas Kitchen Range
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
1,257 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Steve Allison
Steve Allison
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
