FixYa.com
Tags:
Wheateena 3002 Wheatgrass Juicer
My juicer worked fine the first time but now when I... (by 3 users)
By Reynolds - usenet poster
My juicer worked fine the first time but now when I plug it in it doesn't turn on?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by tocarol, posted on Dec 25, 2007
I have the same problem.. the 1000 just doesn't turn on. I notice there's a red reset button on the bottom of the juicer but pressing that does nothing. Is the motor burnt out and if so, what can I do? I bought it used on ebay.
Comment by singerrobin, posted on Dec 14, 2007
The juicer I purchased appears to have the same problem. I used it for 10 minutes and it worked fine (purchased about 8 months ago or so). Then stored and then sold it, and now the new owners say that nothing happens, no power. I suggested to make sure the parts were put together properly and they did - with no change. They even checked other outlets. Any suggestions will be helpful.
Best Solution
posted on Aug 08, 2005
Helpful (85)
Luisa_K
Luisa_K - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
The newer model Juicers have a sensor located on the juicing parts that will not allow the unit to operate unless all parts are properly positioned
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jan 29, 2007
Not Rated (0)
THANH
Rating: 100%, 1 votes
THERE SHOULD BE A RED RESET BUTTON ON BOTTOM
OF JUICER. PUSH IT IN TO RESET.
Solution #3
posted on Dec 26, 2006
Not Rated (0)
e3wicklu
Rating: 70%, 1 votes
e3wic... indicated that his solution for
8005 Juicer Problem
is valid for all Wheateena Juicers
Where is the sensor on this juicer? I have this problem and cannot find a way to get it to turn on?
This Problem Also Relates To: Black & Decker JE 1200 Juice Extractor Black & Decker Black & Decker JE 20 Juicer Bosch MCP-9110 Citrus Juicer Braun MPZ-6 Juicer Braun MPZ-9 Juicer Breville JE3 Juicer Breville BJE200XL 700 Watts Juicer
Can you Help with these Juicers problems?
Juicers
manual juicer which is the best
hi, i searching to buy a manual... Answer This...
Juicers
refurbishing a old juicer
looking to find out what type... Answer This...
Juicers
cleaning my juicer
i have borrowed a 'master... Answer This...
Juicers
rival juice a matic parts
looking for rubber plugs on... Answer This...
Juicers
want to add grinder in my...
Hi I had a Philips juicer... Answer This...
Repair Service
Find Juicer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
