Question about HP LaserJet 3380 All-In-One Printer
Scanned files are too big
When I scan some documents with my Laserjet 3380 the file is huge. I have set the scanning settings at 75 dpi and got everything else on the minimum setting. It averages out to be about 1 meg per page. How can I fix this?
  • 2,427 Answers
Change the file format its saving in. different formats have different compression rations. Jpg images are smaller than bmp images. simply by changing it to jpg it will be 20 times smaller. To do this when click save and the save image box appers, in the format type select jpg or gif or what ever is avilable. Play around to see what gives you the smallest size. You can also use software like Photoshop, paint, and other image editors to change the format its being saved in.
Posted on Dec 16, 2008
I have used last 4 year canon 2900B printer. How to set 300 dpi printing resoluation
Canon PIXMA Manuals MG2900 series Resolution
Resolution The data in the image you have scanned is a collection of dots carrying information about brightness and color. The density of these dots is called "resolution", and resolution will determine the amount of detail your image contains. The unit of resolution is dots per inch (dpi). Dpi is the number of dots per inch (2.5 cm). The higher the resolution (value), the more detail in your image; the lower the resolution (value), the less detail.
How to Set the Resolution You can set the resolution in Resolution on the (Scanning from a Computer) tab of the Settings dialog.
Appropriate Resolution Settings Set the resolution according to the use of the scanned image.
Item Type Use Color Mode Appropriate Resolution Color photo Copying
(Printing) Color 300 dpi Creating a postcard Color 300 dpi Saving to a computer Color 300 dpi Using on a website or attaching to e-mail Color 150 dpi Black and white photo Saving to a computer Grayscale 300 dpi Using on a website or attaching to e-mail Grayscale 150 dpi Text document (document or magazine) Copying Color, Grayscale, or Black and White 300 dpi Attaching to e-mail Color, Grayscale, or Black and White 150 dpi Scanning text using OCR Color or Grayscale 300 dpi Important
  • If you double the resolution, the data size of the scanned image quadruples. If the file is too large, the processing speed will slow down significantly, and you will experience inconvenience such as lack of memory. Set the minimum required resolution according to the use of the image.
Note
  • When you will be printing the scanned image by enlarging it, scan by setting a higher resolution than the recommended one above.
Oct 07, 2014 | Canon LASER SHOT LBP-2900 Printer
Text being scanned does not produce a clear print to our cannon ip18oo printer
alot of the time if you scan something it will streach the image because of the scanner resolution. check you setting on the printer. you might need to change the settings to stop it from doing that to make he image more clear. if that doesn't work than also some printers are just like that when you scan something. it will also make one page turn into two pages. that may just be the way the printer is.
Aug 13, 2008 | HP Office Equipment & Supplies
We are having HP Officejet J4580 all in one in our office. but the problem is that even if i scan a document in gray scale & PDF then also the file size come out to very Huge; Which troubles us alot...
Scanning in gray scale alone will not bring down the scannned documents size alone. In your scan settings there should be a setting whereby you lower your DPI (dots per inch) or scan resolution. The standard DPI is usually about 300. Try lowering it to about 100 and check the scanned document size again. Lower your DPI until you reach the appropriate document size for emailing etc.
Best wishes,
Graemevm
Jul 26, 2011 | HP OfficeJet J4580 All-In-One Laser...
How can I scan a document then print it with larger print?
You can scan a document or photo or negative film etc.. using a scanner, there a many types of scanners which you can choose as per your requirement. There are dedicated scanners, all in one integrated scanners, or two in one like that.. but if you need it for your professional use or daily use, it's better to get a dedicated scanner not "all in one" since with all in one if the copier fails or fax fails, the scanner will also fail because they are related and built-in integrated.
The process of scanning a document is as follows;
  • > Place the document on the scanner's flatbed.
  • > Press scan button or scan using the integrated software from the computer.
  • > Customize the scan settings/quality.
  • > Save the scanned documents.
Printing a document to a larger size is different, you can use photo editors like photoshop, paint.net etc..where you can changed the resolution as well as the size of the image. It's best to change the size or resolution before you give the print command. Or you can also change the print size with the paper size or print size.
If you still need more help, please let me know with more details. I am ready to assist you.
Good luck.
Thanks for using FixYa.
Jul 04, 2010 | Computers & Internet
Problem with size of scanned document using HP laserjet 3380
It depends also on what you are scanning....half tones, pictures etc. but the easiest way to control the file size of PDF's is to change the resolution setting. Also referred to as the quality setting. These are settings like Super Fine, Fine, Standard. It should be right on your control panel. It is the same setting you can change when sending a fax. If your default setting is Fine for example, changing it to standard will use a lower resolution and reduce the file size. In other words the higher resolution/quality setting you use make the file size much larger.
Good Luck and Thank You for using Fixya.
Apr 06, 2010 | HP LaserJet 3380 All-In-One Printer
Hp laserjet 3055 scans larger than print area
When you place a document for scan, you must select the portion you want to be scanned.
You must also set the resolution which is set to 300 by default, if you want a actual size then set the resolution to 75, which is 3% larger then actual image.
It will reduce size in KB or MB of your image and it will be exact size.
Similarly, when you want to print, you must select option "Exact Fit" and print your document.
Everything will be normal.
Cheers
Nov 06, 2009 | HP LaserJet 3055 All-In-One Printer
I just installed a (new out of the box) HP LaserJet 3380 All-In-One printer/fax/scanner. I have NOT set up the fax function (no telephone line available). The unit is connected to my computer with a USB...
WHen you open the scan application and get to the point just before you scan... open at the top menu "File" and request to "Save As" and give it the "Name.BMP" see if that helps..
You named the folder but you did not mention naming the file you want to save????
Aug 04, 2009 | Office Equipment & Supplies
Huge HP scanner files
could be you are scanning pictures of documents and not doing OCR..Optical Character Recognition
Jul 23, 2009 | Konica Minolta magicolor 2430 DL Laser...
Huge pdf files
Try scanning a "photo" to file and using the advanced scan options to set a lower DPI. Then from the Library view you can convert that 'photo' (of a document) to PDF.
Steve
Sep 05, 2008 | Lexmark X7350 All-In-One InkJet Printer
Scanning
1- make sure tray guides are snug against the paper
2- is it set in the menu?
3- when you go to file, print, right click on the printer and go to properties and got to device settings is it set to lettter?
Nov 08, 2007 | HP LaserJet 3380 All-In-One Printer
HP LaserJet 3380 All-In-One Printer Logo
102 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
