Question about Panasonic NN-T888S Convection/Microwave Oven
Panasonic NN 9850 wall micro/convection oven
Hi, Hope you can help. All the buttons on my micro work EXCEPT the start button. The clock works, I can change times and micro settings but the Start button does not work so of course nothing works. Thanks in advance for your help.
  • 3 more comments
  • Urvashi Bhatia Mar 21, 2007
    I had someone in to take a look and he showed me a tiny piece that had broken in the door. This little piece holds some other piece in place to enable door to close properly. There was a very tiny gap in the door on the top. If we manually pushed in the micrw worked fine.
    Problem is the door seemed to be one whole piece and he suspected it would not be possible to buy the tiny piece. My model no is Panasonic NN-9850 and it is installed in the wall cabinet. Does anyone know of a place where I could get a diagram to figure out what this piece is called and buy either that or the whole door if no other choice.
  • ElmoDWard Jan 06, 2009
    One of the small door-hooks on our Panasonic NN-9850 / NN-9800 broke and now the door won't open properly once it is closed. We need to stick in a ruler to lift the one remaining hook to open the door.
    We can't find this part anywhere! It sure seems to be wasteful to throw out such an expensive convection microwave for the sake of a piece of plastic smaller than a fingernail! It otherwise works perfectly!
    j.e.miller@shaw.ca
  • abarros001 Feb 08, 2009
    I´m having a error code ( cook 4 ) and it´s seem a membrane panel problem, sometimes it works, sometime not, and I can´t find a new membrane panel to buy to test , my model is NN9850BH, Dimension 4, does somebody know what can be the problem ? Thanks in advance for your help. I´m from Brazil. abarros001@hotmail.com
  • Anonymous Mar 16, 2014
    The touchpad displays 00:00. Cannot set timer, clock, cook time or use a preset key. The oo:oo will not change at all.
  • Anonymous Mar 24, 2014
    Unable to set up time clock on Panasonic Micro Browner NN-K605BBPQ
PLEASE CHANGE MEMBRANE SWITCH
Posted on Oct 05, 2007
  • mostak ahmed Aug 21, 2013
    what is membrance switch?
You can take the membrane panel apart. The top Layer is just stuck on. take it off, then give the contacts a good wipe and stick together again. For me this did the trick...
Posted on Oct 26, 2008
  • 38 Answers
Make sure door is closed properly hooks on door activate switches in mwave .openmwave check if hooks make contact with switches
Posted on Mar 20, 2007
  • clyde paul Mar 21, 2007
    there may be aproblem with membrane switch
Set Clock
Try holding the send button until the clock flashes
Sep 24, 2011 | Panasonic NN-T888S Convection/Microwave...
Wont come out of demo mode!!!
Try pressing the clock button 3 times.
or
You press the high power button once and then stop cancel button four times in rapid succession.
Jun 02, 2011 | Panasonic NN-C994S Convection/Microwave...
Demo mode on
The instructions to turn the demo mode OFF on the model you have listed, can be found on page 24 of the owner's manual. Press the CLOCK pad three times to clear. If you no longer have an owner's manual, you can download a FREE copy at managemylife.com. Here's a direct link:
http://www.managemylife.com/mmh/owner_manuals/6952/PANASONIC-Countertop-Microwave-L0604142?brand_name_search=NN-C994S
I hope this helps you.
May 03, 2011 | Panasonic NN-C994S Convection/Microwave...
Model NN 9804 U microwave in Demo Mode
No owner's manual?
If you're in the US, find it here.
If you're not in the US, see Panasonic.net and look for support / download links.
Otherwise, I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Jan 14, 2010 | Panasonic NN-T888S Convection/Microwave...
Dimension 4 microwave stuck on demo mode
Here are is the manual:
http://service.us.panasonic.com/OPERMANPDF/NNT888S.PDF
Page 13 tells how to shut off Demo mode. (Press FUNCTION-0-2.)
Aug 12, 2009 | Panasonic NN-T888S Convection/Microwave...
Panasonic NNA554W
Jun 22, 2009 | Panasonic NN-C994S Convection/Microwave...
The microwave works for only 8-9 seconds, then stops
It may be in demo mode.  On some units if you hit the timer/clock button 4 times to turn demo off.
Feb 02, 2009 | Panasonic NN-C994S Convection/Microwave...
Panasonic dimension 4 microwave/convection oven
Does this unit have a turntable? If so does it turn when on?
Sep 24, 2008 | Panasonic NN-C980 Convection/Microwave...
Panasonic NN 9859 Membrane switch
Yes, you are correct. The membrane switch for this model was discontinued. The correct part number for the membrane switch is A630Y5460HAP for model NN 9859.
Mar 26, 2008 | Panasonic NN-T888S Convection/Microwave...
Panasonic NN-T888S Convection/Microwave Oven Logo
1,601 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
