Question about EliteGroup ECS 755-A2 Motherboard
No Signal on Monitor
Before I moved all was fine. PC powers up, HDD works, all fans and lights work. no bips. Replaced Video card and same Message. Monitor works.
  • 2,427 Answers
Hi,, what you need to do is flash the bios there are 2 ways to do this I'll describe the two. Unplug the system and open it up.
1.) locate the jumper called jp1 or jcmos. Its currently set to 1 and 2,, set it to 2 and 3 ,, wait 10 seconds the set it back to 1 and 2
2.) locate the battery on the main board, remove it.. Its held in place by a pin, just pry it loose. press and hold the power button for 1 minute, release and press 5 times (to dump any current in the system) relpace the battery.
When the system boots you will need to enter the setup, load optimised defaults, save and exit.. Dont worry just follow the onscreen instructions to complete those steps.
Posted on Dec 16, 2008
My HP desktop fan turns on as does the green light, but there is a constant beeping sound and no display on the monitor
This error message mean that there isn't video signal from the video card going to the monitor.
Try reconnecting the video cable to the monitor. If this does not work then you may have a faulty video card.
Sep 18, 2012 | HP Pavilion a1410n (ER890AA) PC Desktop
I switch on my system and nothing happens The cpu
So practically the pc starts but you don't have any image. Try using another monitor and another video card - one of them is dead.
Jul 03, 2010 | Gigabyte GA-8I915P Duo Pro Motherboard
WHEN I BOOT IT UP-NO VIDEO EVERYTHING IS CONNECTED BUT I CAN'T SEE ANYTHING
When a monitor displays No Signal, it is an indication that there is no video signal going to the monitor.
The monitor is working fine.
1) Could be due to a bad monitor cable. They do go bad.
Test would be to take that monitor cable, (If it disconnects), and use it on a known to be working computer.
2) Could be the graphics of the computer.
If the computer has Integrated Graphics, the test would be to install a graphics card, and plug the monitor into it.
[Integrated Graphics is also termed as OnBoard Graphics.
On the motherBoard.
The GPU is the graphics 'engine' of a computer.
Graphics Processing Unit.
It can be soldered directly to the motherboard, (Integrated Graphics), or soldered to a removable graphics card.
http://en.wikipedia.org/wiki/GPU ]
When you install a graphics card, (graphics expansion card), the Integrated Graphics is bypassed.
The monitor plugs into the graphics card, not the motherboard.
Could be wrong, but I'll bet it's the Power Supply.
If this problem directly relates to a Compaq Presario SR1550NX, the computer is 5 years old. (According to my sources)
If the computer isn't cleaned inside, and the Power Supply isn't cleaned inside, on a regular basis as needed, the Power Supply is one hardware component that is sure to fail.
It's the top problem relating to computer failure.
The cooling components for a power supply is it's fan, and Heatsink's that are used inside.
1) http://en.wikipedia.org/wiki/Switched-mode_power_supply
2) http://en.wikipedia.org/wiki/File:ATX_power_supply_interior-1000px_transparent.png
The basic physical makeup of a Heatsink is a flat plate of metal, with tall, thin fins protruding from it.
The flat plate absorbs heat from whatever it is placed against, and the tall, thin fins absorb the heat from the plate.
The fins then radiate the heat away.
If there is a fan used along with a Heatsink, (Such as in the Power Supply, or on a Processor), the fan moves air in-between the fins, and around the fins, helping to carry the heat away.
If dirt, dust, hair, etc. is clogged on the fan blades, center hub, and surrounding cage, the cooling capacity drops tremendously.
The fan cannot move the needed amount of air.
To include on the Heatsink/s inside the Power Supply.
The gunk acts like an insulating blanket, causing the Heatsink to retain the heat, not conduct it away.
Heat = Wasted Energy
The Power Supply tries to keep up with the call for power, and eventually cannot, due to hardware components failing inside.
The Power Supply may seem like it is operating okay.
Lights light, fans spin, and it may sound as though the Harddrive inside is operating.
The Power Supply could have a weak Voltage power rail.
Power Supply's are rated in Wattage.
1) ALL the lights use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts.
3) A typical Processor can use anywhere from 51 to 125 Watts.
A bad Power Supply with a weak Voltage power rail, will have enough power to light lights, and maybe spin fans, but not enough power to turn the Processor on.
Harddrive sounds like it is working, because the Platters inside are being spun by the Spindle motor.
http://computer.howstuffworks.com/hard-disk.htm
There is no Processor operating (The 'Brain') to find the boot sector on the Harddrive.
Platters are spinning but the Arms aren't moving the Read/Write heads across the Platters.
In short the computer is not operating.
No video signal to the monitor, because there is no computer operating to send a video signal.
Bad Power Supply.
Jun 06, 2010 | HP Compaq Presario SR1550NX (PY059AA) PC...
Monitor (no signal) after replacing mother board and CPU
try only connect Monitor and keyboard, and check for booting (disconnect all the rest (HDD, CD DRIVE, Sound Card, Network Card, ....) then try connect one by one and always off to change hardware config.
If dont work with monitor and keyboard, try reset bios(jumper),check again, then replace memory modules (must be compatible to new motherboard), evan dont work, send back the motherboard for defective motherboard.
Jan 14, 2010 | Gateway Intel (El Paso 2) Motherboard P4...
PC is not working. Monitor message says 'monitor
Check to make sure that you have it plug all the way in to the video card. Also make sure that the video card itself is seated or pushed in good.
You could possibly need a new video card or the pins on the plug coming from the monitor could be bent.
Oct 13, 2009 | Computers & Internet
HP (dv2000) laptop will not boot up at all
It appears to be a video card/mainboard problem very common with the symptoms you have described. Try to connect the laptop to an external monitor (see the associated buttons too). No video signal on the external monitor could indicate a damaged video card/mainboard. Not worth it to be repaired and the replacement is expansive. Check the price on a professional repair store. There are new laptops on the market more powerful than yours for about 500-600$. So you can make a choice. Less common, could be a memory problem.Try the laptop with a good previously checked memory (or if there are 2 bars in your laptop, try them one by one). If you do not get any video signal on the external monitor have the laptop, first diagnostic is most probable.
In both cases, if you get a video signal on the external monitor it means your screen is defective (also expensive to be replaced).
Oct 04, 2009 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Upon booting, fans whirl and I can hear HDD
Sounds like your graphic card is not working. Try replacing that. Check and make sure you have the cable plugged into the right port in your graphics card.
Aug 27, 2009 | Acer AM5641-B5560A Desktop PC & Monitor...
Cannot get new Motherboard to boot up in Normal Mode
what u may have done is wwhen u were installing the new board, gave a static shock to the system...that will cause only the fans to come on and nothing more...this is a bad problem bc u cannot fix it...if u figure out something else is wrong, and it gets fixed, let me know
Jun 20, 2009 | Gateway Computers & Internet
No signal on monitor when card is seated
the problem occured probably because of a power shortage of motherboard battery malfunction, if your motherboard has an integrated graphics card you then need to enter setup and disable it or choose which graphis card your pc has to use but you have to do this while connected to the on-board vga slot as the other one won't be working, you will problably find the choice under the
'integrated periferals" menu in the setup menu, and to access it you have to press the "DEL" button when your pc starts-F10 in some devices-
Nov 29, 2008 | Evga e-GeForce 8600GT, GeForce 8600 GT,...
EliteGroup ECS 755-A2 Motherboard Logo
103 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
