Question about GE Spacemaker JVM1640SJ Microwave Oven
1800XL microwave hums
I saw you suggested putting a microwave on a test bench and disconnecting the lamp - how do I do that ?
Also you mentioned something about a stuck stirrer - how can I check that ?
  • Will Beames
    Will Beames Dec 16, 2008
    Would either fault cause the HV transformer to make a humming sound and get hot ? I know it's not the transformer as I have already switched it out for a replacement. The humming stops if I open the door and starts as soon as I close it - the microwave does not need to be running for the transformer to hum but will hum when running also. The problem started when I closed the door after retrieving cooked food which leads me to a problem on the door closure circuit perhaps causing a dead short in the transformer ??? - however, I am no expert !
    If I am understanding you correctly, I should be able to detect changes in the lighting caused by the movement of the stirrer (in normal circumstances) but if I don't see any changes it could be a stuck stirrer ? Would I be looking through the glass in the door to see the changes or from another angle ? I still have the cover off.
    Thanks for your help with this.
  • 981 Answers
A test bench will have known-good power, but disconnectable and on a breaker and metered, for example.  The lamp will be disconnected by opening the thing up (hence, the workbench setting) and removing the lamp circuit connections in whatever way is most convenient.
The stirrer is often integrated with the output from the magnetron to the oven cavity; it's a microwave component that literally spins as the thing runs, and since the oven light is commonly on the same side easy to see moving or evidenced by changes in the back reflections from its vicinity.  That is, you would notice some periodic change in the internal oven illumination from the stirrer's motion, which might have stopped around the same time the hum started....
Posted on Dec 16, 2008
How do you test a Magnetron on g e microwave
If you have the mag out of the unit. You can take an ohm meter and measure between the terminals on the mag. That is the Filiment. It should show continuity. Then measure from either of the two terminals to the outer metal frame of the mag. You should not see any connection. If you do it is shorted to ground and is bad. The unit would probably hum loudly when it ran. The only other way to really test a mag is under load with full hi volts and filiment power going to the mag and watch an amp meter and see if it fires up and draws around 10- 15 amps. I personally have Hi Voltage trays from stripped down units that I can power up a mag on the bench and see if it fires. Another way to check is to see if you have hi voltage. Unplug the mag and run unit for a couple of seconds, then, once unplugged, you can short across the capacitor with a couple of screw drivers and if you get a really Large Hi Voltage snap, the unit is producing hi voltage, so if it is not heating it is probably the mag. If it makes Hi voltage the timer and interlock circuits are working to send power to the transformer and the other Hi Volt components. If ti doesnt heat probably bad mag. If your unit has an inverter you caannot use this test.
Sep 18, 2017 | Microwave Ovens
Frigidare microwave has humming noise when not in use
You have a shorted cook relay.
Apr 26, 2013 | Microwave Ovens
My GE Spacemaker 1800xl makes a faint humming noise when plugged in, but not in use. It seems louder than any microwave I've ever owned before. Everything else about the unit works perfectly. Any...
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid with a one-year repair guarantee.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Nov 21, 2010 | GE JVM1660 Microwave Oven
Maytag microwave hums and then internal fuse blows. I replaced the blown fuse and started heating cycle, microwave hummed again and the fuse is again blown.
It sounds to me as though your magnetron is shorted. If you have an ohmmeter, DISCONNECT POWER, unplug the connector on the magnetron, and make two tests. From pin to pin should measure less than an ohm. This is the filament. From either lead to the frame of the magnetron should measure infinite. Do not touch the lead tips while making this measurement (makes false reading). If the magnetron checks okay, perhaps you have a shorted capacitor, or diode.
Oct 03, 2009 | Emerson MW8985W Microwave Oven
Where does the light (lamp) in a Kenwood SJ SS 25 microwave go? I ordered a bulb but am unsure of how to put it in when it arrives. The booklet that came with the microwave says "don't do it...
I did not fix the problem. I ordered a bulb (lamp) and subsequently saw it is beyond my knowledge to install it. I'll communicate with the store where I bought it 3 months ago and if they won't deal with it, I'll pay a repairman to do it.
Aug 20, 2008 | Microwave Ovens
MICROWAVE HUMS WHEN DOOR IS CLOSED.EVERY THING ELSE WORKS FINE.
Perhaps a fluorescent ballast or transformer is letting you know it's going bad; it might just need to be reset (see the manual as well as trying to unplug/wait/replug.)
Failing that, It is simple enough to unplug it, put it on a test bench, disconnect the lamp and see if it still hums; if not the lamp, you will have a better idea what is humming with the lid off, but stay inches away of the (usually well-packed-away) high voltage feeds to the magnetron as you do.  It could be that you just have junk inside the door switch and can unplug, clean out the switch interior (crumbs sneak in!) and put it back for a fix; or a stuck stirrer at the RF feed off the magnetron.
Jun 30, 2008 | GE Microwave Ovens
Kitchenaid model:KHMS105B microwave hood combination
hi alan,
it sounds like the transformer is bad, which makes this easy, time for a new one. 12yrs is a good age for a microwave, average life is about 8-10 yrs!
Mar 21, 2008 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Constant humming sound
the most common problem with ALL microwaves is the magnatron
Dec 29, 2007 | Samsung SMH7178STD Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
43 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
