Question about Dell A940 All-In-One InkJet Printer
Dell 940 all in one - blue smudges on print
Please help me. I have had the black cartridge re-filled .I have fitted it back and now on printing in colour there are blue smudges all on the print. If you print in just black and switch the colour off its perfectly ok. Any ideas !!!!!
    President:
  • Dell Master
  • 2,022 Answers
Just remove the colour catridge and then see is it working with single catridge .
Posted on Oct 01, 2007
SOURCE:
-Fitted new black cartridge and cleaned several times but print still smudged
Clean all of the rollers and mechanism involved in moving the paper while printing. If problem still persists I would return cartridge as defective after checking with printer manufacturer for suggestions.
Apr 01, 2014 | Computers & Internet
How do you clean the copper parts of the cartridge
Turn the printer on and then fill the paper tray with paper.
If this is an HP printer, press the "Setup" key until "Tools" is shown on the control panel display screen. Follow equivalent steps for other printers by reading the user manual.
Press "OK." If your printouts continue to be faint, show white line streaks or smudges, go to the next step to clean the contacts on the print cartridge.
Open the print cartridge access door. Wait until the print cartridge moves all the way to the right side and completely stops.
Remove the power cord from the electrical outlet.
Press down on the top of the cartridge and lift it up toward you holding it by its sides. Avoid touching the copper area when you lift it out of its slot. Sit it down on a flat surface, such as a table.
Wet a lint-free cloth with water and squeeze out any excess.
Pick up the cartridge by its sides and avoid touching the copper area.
Gently wipe the copper contacts of the print cartridge with the dampened, lint-free cloth. Be careful not to wipe the copper nozzle part on the bottom of the copper cartridge.
Let the print cartridge dry for 10 minutes and then plug the power cord back into the electrical outlet.
Reinstall the print cartridge. If your printouts continue to be faint, show white line streaks or smudges, go to the next step to clean the nozzle area (copper bottom part of the print cartridge.).
Repeat steps 4 through 7 and then gently wipe the nozzle area with a clean, dampened lint-free cloth.
Let the print cartridge dry for 10 minutes and then plug in the power cord back into the electrical outlet.
Reinstall the print cartridge. If the ink is faint, or streaks or lines show on your printed pages, the old print cartridge may be defective and cannot be cleaned. Replace the old print cartridge with a new one.
*If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Feb 26, 2013 | Dell 966 All-In-One InkJet Printer
ON MY DELL 1700 PRINTER THERE ARE BLACK SMUDGES ON THE RIGHT HAND SIDE ONLY ON THE COPY PAPER WHEN IT PRINTS BOUT 3 INCHES APART?
Normally this is caused by the drum cartridge that fits under the toner. Replacing this drum cartridge will clear up the black marks on your print. Use this Dell Part# : A0373010 to order. After replacing the drum cartridge counter will have to be reset, Use the following steps.
1. Open the front door.
2. Press and hold the cancel button (x button) until all the lights flash in order.
3. Then close the front cover.
This will reset the drum counter.
Jul 21, 2010 | Dell 1700n Laser Printer
When printing on ML4550B, there is a ~1cm intermittent black patches vertically on the right side of the printed page.
This is possibly toner on the paper feed rollers. If you happend to use refurbished cartridges they are often over filled to claim more pages for your buck. But they fail to say expect smudges down the printed page.
use a cloth and some metho to clean the paper path
Please rate my help++++Thanks for using FIXYA
May 18, 2010 | Samsung ML 4551NDR - printer - B/W - laser
Printer not printing in color; new cartridge, tests are fine
Check your printer settings to make sure the print in b & w box is not selected. Hope this helps.
Feb 08, 2009 | Dell Photo 964 All-In-One InkJet Printer
Will my dell 924 printer still work without the blue cartridge
when you put the black in you had to also put the blue in do you have the empty cartridge if so put it back in for right now and see if this helps
Jan 09, 2009 | Dell 924 All-in-One InkJet Printer
Gap in printing
the color ink cartridge has dried. replace it.
Nov 29, 2008 | Dell 924 All-in-One InkJet Printer
BLACK SMUDGING
Hmm... This sounds like it is a toner problem. If your roller is getting too much toner then it just globs it onto the paper even though the drum is not asking for it. Are you using a new toner cartridge or a re-filled one? Is it from Brother or a 3rd party? I suggest you remove the toner cartridge and check inside the printer. Clean any spilled toner. Check the toner cartridge for leaks .. give it a good shake and see if it is leaking. If you have another toner cartridge, you can replace it to test. You may need to pint a few pages to see a change. Another test could be to print a few (2-5) "BLANK" pages. The printer should not be depositing any toner. If no smudge or the smudge stays the same, then the toner cartridge is the likely problem. If the smudge is there, but gets smaller, then clean your printer.
Jan 10, 2008 | Brother HL 2700CN Laser Printer
Print Out
yes replace the cartridge it appears the cartrige is defective
Dec 06, 2007 | Dell 924 All-in-One InkJet Printer
Dell A940 All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
David Patricia James
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
