SOURCE: 2003 Navigator wont start runs through system
have you tried reseting your alarm or disconnecting your battery for a few mins the connect and test!
SOURCE: have a 2003 navigator when truck is in forward
could it maybe be the brakes?
first i would check the brake pads and then go for the transmission after that if that is not it.
SOURCE: my 2003 lincon navigator wont
Hello Eagle.
Your transmission range sensor/switch isn't working.
The starting system depends on this so it will not start in gear.
This switch is mounted to the left side of the transmission on the gear select shaft.
They are relatively easy to replace for a technician and is best done on a hoist.
It is also possible that the connection is loose or corroded.
If you would like further assistance with this please ask me here in a comment.
Thank you for using FixYa.
KL
