posted by jjjjffff on Mar 20, 2007
I'm unable to send a FAX. Error message is "Communication error". Phone line is working when I hook a phone up to the Copier.
Best Solution
posted on Mar 29, 2007
Are you still receiving faxes although you are unable to send? Or is it no send & no receive? When you hook a phone up are you able to connect with a # dialed from that phone. It's possible that the problem is the copiers NCU board- but it's rare that they fail & even more rare that it loses just the send portion. You'll want to be absolutly sure that it's not the phone line. If you are positive that the problem is not the phone line - try turning the machine off & unplugging the power cord for 30 minutes. Occasionally the NCU card will lock up & not function properly. Unplugging the machine for 30 minutes has worked for me in the past.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on May 16, 2008
Toshiba is the biggest piece of **** box made next to panasonic! Take it from a kyocera tech that was forced to work on the those toshiba dogs. No wonder they lost the hd war with sony. I'm a tech in central saskatchewan.
Suggest a new solution for this problem
Post a New problem for Toshiba e-Studio 350 Copier
Email this problem
Email this problem
Can you Help with these Copiers problems?
Cannot get the machine out of...
How can I reset the machine... Answer This...
Repair Service
Find Copier Repairman Near You:
