I have set up & installed a Denon 589BA AVR, every connection and assignation seems to be in order but no sound other than static is produced. All 5 Boston Acoustic Speakers work as I was briefly able to get stereo TV, no sound is produced when I play a DVD either. I have a Direct TV DVR/box. My TV is a 2002 Toshiba without HDMI ports so I'm using component cables for video and Optical for Audio. Any suggestons? Thank you
  • CLIBBEY Dec 17, 2008
    Yes. I was not able to get any sound so I now know my Denon AVR 589BA is defective. Thank you
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, pls try:
  • disconnect all cables from the various sources other than the speakers;
  • select FM;
  • determine if there will be sound and not only static;
  • try the different modes (Decoders Dolby Pro Logic II, DTS Neo:6, DTS 96/24, Dolby Digital, DTS decoder) or with no sound processing, plain & simple FM reception/listening;
  • if there is sound and no static, then the Denon 589BA AVR generally is OK;
  • connect the DVD's aduio L/R, red/white;
  • pklay a known good DVD;
  • set Denon 589BA AVR to DVD;
  • try the different modes (Decoders Dolby Pro Logic II, DTS Neo:6, DTS 96/24, Dolby Digital, DTS decoder) or with no sound processing, plain & simple DVD listening;
  • do the same to all others;
  • finally, connect the Optical Out of the Toshiba;
  • set the Denon 589BA AVR to Optical IN,
  • If yes, then you are set;
  • if not then the Optical Audio OUT of the Toshiba is the issue.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 16, 2008
  • 505 Answers
It could be a hardware failure, check you radio (am and fm - need antenna hookedup) and see if you can get good sound from there.. if not, there may be an internal problem. If radio comes in ok, then it may be wiring. Make sure no speaker wires are stripped down too far causing them to short out, on both ends. It could be as simple as setting an input to digital instead of analog (dvd sound).. there is usually a signal type button of some sort, push to switch from analog to digital.
My DENON AVR-4308CI HOME has no sound. Everything comes on as it should and unit looks great but no audio comes out. It's had off and on issues since I bought it, but firmware helped with some. Now, no...
This may require quite a bit more info. Verify that there are no shorts in the speaker connections to the Denon - it has a short detection circuit that will shut down the audio amps in the event of a short. If you are using optical or coaxial digital input for you audio - verify that the correct digital input has been assigned to the component selected on the Source Select dial: Menu > Source Select > Assign > Digital. If this is an HDMI connection go into the HDMI setup menu and select Audio: AMP: Menu > Manual Setup > HDMI Setup > Audio > AMP. If it is set to TV the audio passes through the AMP without being decoded and goes to the TV instead: there is no 'Both' setting.
Oct 26, 2013 | Denon AVR-4308CI Receiver
Subwoofer will not produce sound. Connections are correct. I do hear a hum or a crackel as I pull the connection on and off. AVR-689 model
In order to ensure output to your subwoofer: make sure the subwoofer is connected to the subwoofer out of your amplifier and make sure that your amplifier/receiver is set to output multi channel sound
May 07, 2011 | Denon AVR-689 Receiver
Denon AVR 1804
You need to get the manual and do some reading first. I couldn't find the AVR-1804 but the AVR-1803 is avaiable. It should be close enough to get you through connection and setup.
Register with retrevo.com and download it for free.
Feb 23, 2010 | Denon AVR-1804 Receiver
My Denon AVR-5800's optical (toslink) inputs no longer work. My Tivo, DVD player, HD DVD player, etc. does not produce sound so I know it's not the toslink cables. I've configured the assignments...
Press the input mode on the front of the unit to select auto while on the input you want to use if this is does not work you will need repair on the unit
Jul 04, 2009 | Denon Audio Players & Recorders
Back speakers with av denon 1908
Plug your rear 5.1 speakers into the surround speaker connections. Be sure to use the AVR 1908 set up menu to set rear speakers (not an amp assign). Hope this helps.
Jan 03, 2009 | Denon AVR-1908
Denon AVR 1609 Receiver Zone 2 has no sound
you have to change the power amp assignment to zone 2, you must also have Analog audio connections to the Denon from your devices.
Try this put your remote in the zone 2 mode, select tuner in zone 2 and turn zone 2 volume up to -10
Dec 18, 2008 | Denon AVR588 Receiver
Itunes assigned to CD stereo outputs to zone 1 but not zone 2
Ron Digital audio will only reproduce in the surround area you will have to connect using analog connections in order to get that sound in the 2nd zone
Dec 14, 2008 | Denon AVR-2807 Receiver
Zone 2 problem for AVR 3808
It doesnt down convert to zone 2 via hdmi.... must use analog audio or something else.
Jul 14, 2008 | Denon AVR 3808Ci Receiver
Denon 3802 Amp issue
check the output res. from the DVD, your Denon may not pass high res 720p, 1080i or 1080p and also check the component assignment in the Denons setup
Oct 08, 2007 | Denon AVR-3802 Receiver
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
