Question about Panasonic Home Theater System System
I want to connect the Audio from tv to Surrounding audio system
I have Panasonic home theater surrounding sound system model .
my question is is it possible to connect the TV audio to the Home theater system . beside im having satellite receiver and i want hear the sound not from the TV i want it from the Audio system (Home Theater)
  • Anonymous Mar 15, 2014
    I can hear sound through the TV speakers but not the home theater speakers
For connections of audio, so that you can hear all tv audio through the
surround system, connect either an optical audio cable or red & white
analog audio cables from the tv to the home theater. If you are using
optical audio, there is a plug on back of tv labeled for digital audio
output and an input on the surround sound system. If you plan on using
analog red and white, use the PROG OUT red and white output jacks on the
back of the tv to the AUX input on the home theater.
For video connections, to get HD you will need to be using either HDMI or
Component cables. HDMI is the cable that will provided 1080p signal (the
best HD signal), but if the source does not output 1080p, then your tv
will not display 1080p. Most cable boxes output at 1080i or 720p when on
HD stations. This signal still provides great picture quality, but HDMI is
not needed to get these HD signals. You can use component cables for your
cable box and the DVD player output to the tv for video. HDMI might give
you a slightly better picture quality but the signal will be the same.
To make the connection, you will want to connect from the cable box to the
tv (component or hdmi). Also from the home theater system to the tv using
hdmi or the video cables from component (red, blue, & green cables).
We hope this information is helpful to you.
Thank You,
Panasonic Consumer
Posted on Dec 17, 2008
  • buck wherry Sep 08, 2014
    it is best to use the optical(digital) out with a toslink cable that way it is 1 cable and better sound
How to connect my hdtv to surround for audio
It looks like from my searching you have an optical link on your tv and your reciver. You should just have to choose that as your output on the tv and your input on the reciver. It should be labled something like spdif. In my opinion it is the best cable ever until hdmi came out now its still really good.
Jan 05, 2017 | Panasonic Audio Players & Recorders
Trying to connect Surround sound system with 3 Other Components!?
hi, you need to have 3 pair of audio-in ports for that. i think your sound system has 3 input ports. ie, 1.tv in ->u can connect this to audio out of your tv 2: vcr in ->u can connect this to audio out port of vcr 3: aux in -> this can be connected to your TV Receiver then you can use the soundsystem remote to switch between the source to listen one at a time. pls come back if u have any thing more sreejith
Aug 31, 2007 | Panasonic SC-HT75 System
Cannot get the tv audio working. Radio iPod all work fine Panasonic surround sound sa-pt750
Hi. Make sure you get audio from tv from the right place. Ie audio out not audio in.
Nov 05, 2016 | Panasonic Sa-pt750 Multi 5 Dvd Player...
Connecting a panasonic surround sound to a sanyo tv
if you have this option, use a hdmi cord from the dvd output to the input of the tv.most new tvs have several hdmi connectors. Then use a fiber optic cable from sound system to the audio input of the tv. between the both it should sound like a movie theatre. thats how i hooked mine up. good luck
Feb 27, 2012 | Panasonic Audio Players & Recorders
Just got Panasonic Home Theater and using Digital Audio cable along with HDMI cable. Cables are coneccted and when I do a speaker test all work fine. When I play my Wii the sound is coming out the Tv not...
What kind of TV do you have?
I have found one of the easiest ways to connect surround system is to connect all your accessories (ie. Wii, Cable Box, VCR, etc) to the TV.
Next find the AUDIO OUT on the TV and connect this to the TV or AUX input on the home theater.
Tune the Home theater to the Input that you connected the TV to. This should play the audio through the home theater for any input you tune the TV to.
Note: make sure to turn the TV volume all the way down otherwise there will be some distortion due to the delay between the TV and the home theater.
Good Luck,
Robert
Feb 26, 2011 | Panasonic SC-BT200 Home Theater Systems....
No surrond sound
TV's are not sources of multichannel audio. The best you'll get is stereo analog. Get the best TV-related audio from the same source the TV gets it - in this case the Cable Box.
Feb 28, 2010 | Audio Players & Recorders
Blu ray connect to my sc-pt660
as far as hooking up your blu ray player to the sc-pt660, the only real way to utilize the surround sound (with true surround sound) is through the optical audio out. You need to connect your blu ray player through hdmi to your tv and then connect your blu ray player to your surround sound using the optical audio out/in. I, personally have the sc-pt660 hooked up through component cables so I don't waste an HDMI input on my TV. Except for cd's, there is no reason for you to use the actual dvd player part of the surround sound considering you have a blu ray player. In conclusion, hooking your blu ray player and the sc-pt660 up to get better video simply isnt possible (your blu ray player alone gives the best possible resolution, 1080p). As far as audio goes, run an optical audio cable from your blu ray player to your sc-pt660 to get true surround sound.
Mar 23, 2009 | Panasonic SC-PT660 Theater System
Panasonic multi connections
HDMI audio in this setup is a one way street. Audio will not come back from the TV to the audio system.
Sorry as you have not shown the model number I can not advise on the system fully.
However, it is standard on the current Panasonics to use Optical audio as a return feed or phonos.
Optical would be best as it carries full digital surround, whilst the phonos only carry "surround"
It may help for you to look a the new Panasonic web sit as there is now an interactive "How to connect your system"
PanamanNE
Dec 28, 2008 | JBL Cinema ProPack 600 System
I have Panasonic home theater surrounding sound system model . my question is is it possible to connect the TV audio to the Home theater system . beside im having satellite receiver and i want hear the...
I have a Panasonic HT80 dvd system which plays 5 discs, bought in 2000.
If u have the same or similar he way to get the sound through the recorder is to put the audio output phono leads from the tv to the back of the dvd. On the remote (on mine) there is a button for dvd/tv/ext, oput this to tv it should allow the sound to be transferred from the tv set.
Paul 07956 150 240
Dec 16, 2008 | Panasonic Home Theater System System
Panasonic Home Theater System System Logo
611 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
