Question about Acer Aspire 5600 Series 5630-6951 Laptop
Battery life To prolong battery life should laptop remain plugged in when not in use.
  • 68 Answers
Batterys in laptops are now Lithium Ion batterys (li-ion) these batteries do not have a memory effect so it does not matter if you leave the laptop plugged in or not, you will not affect the performance
Posted on Dec 16, 2008
My laptop battery only charges to 70% now, but my fault really: i remember a popup window asked me whether i wanted this option, since it would prolong my battery life. without thinking, i agreed to this....
It really prolongs your battery life. I would recommend to keep it this way, while I don't know where to find the menu option to change it back.
Sep 17, 2013 | Dell Latitude C640 Notebook
Tip
How to Preserve your Battery
Make sure you only charge it whenever the battery level is like 20%. When battery is fully charged, remove plug from main source. Do not watch movies too much while running on battery.
This will help prolong your battery life
on Dec 10, 2010 | Computers & Internet
Tip
?Replacement batteries are much cheaper now but this is worth doing before you...
This actually applies to any device that uses a Lithium type battery. Some of this will apply directly to those devices but differences in hardware or software may limit that. The batteries work the same but the stuff they connect to is going to control everything.
If you have a laptop (or other device) powered by a lithium battery you will notice that over time the useful run time decreases. Eventually your laptop will run for a few minutes at most then shut down. So the first thing you will get told is your battery needs to be replaced, and most of the time that will be true. However, sometimes the battery is fine it just needs to be recalibrated.
On a typical laptop you should get two years of use out of it without it loosing much capacity. I actually have a laptop that has a 12 year old battery that holds full rated charge. I've had a new laptop that the battery was suspect after about 6 months but was fine. And I've managed to get some dead batteries to come back to life. There are no secrets to doing this, you don't have to buy anything, and you just need to do a few simple things. Basically think of this as battery maintenance. It's free so that has to be cheaper than the alternative which is battery replacement. If you have already had to replace the battery then you'll be able to make the new one last.
A lithium laptop battery isn't just a battery, there is actually a microcontroller that manages how the battery is charged and this is called a BMS or Battery Management System. The reason they use a BMS is that to properly and safely charge a lithium battery it needs to be charged at a certain rate and finish charging in a certain way.
First thing, we need to know how a lithium battery likes to be treated. This is pretty simple. You shouldn't use more than about 40-50% of the battery capacity. That doesn't mean you can't, but you definitely do not want to drain the battery dead every day. So use the battery and when it hits 50-60% on the meter plug it in if you can. Second, a lot of people will use the laptop much like a desktop and leave it plugged in all the time. This can be as bad as draining it too much. The battery does need to get 'exercised' or used on a regular basis. So at least once a week you want to use the battery. And about once a month you want to use it to the point where it runs out of charge. This monthly deep discharge helps reset or calibrate the controller or BMS. This is the one time where it is a good thing. Normally you want to avoid this at all cost. So the bad things are a lot of deep discharges or none at all. It's a short list but if you think about it that is all you can control.
What if your battery really isn't that old but the meter says it is acting like it is? Do I have to replace the battery? Well this is one of those times where a bit of luck can save you buying a new battery you don?t need. That BMS system also works with another system that is an information and control system. There are several names for this such as HCI or Hardware Control Interface (Toshiba Laptops). There are other names but basically this just lets your laptop hardware talk to your operating system and vice versa. Sometimes the battery is fine but what talks to it isn't accurate. So it will be telling you the battery is low or is bad when it still has lots of useful life. When a lithium battery actually goes bad it will be one cell inside the battery, out of the 6 or more cells inside. The BMS and other monitoring stuff have no way of knowing it is only one part of the battery so it can't compensate and say the entire battery is bad. The battery will also lose a bit of capacity with each charge cycle. Since these systems are not really sophisticated they will after a while be out on the accuracy.
To calibrate or recalibrate you need to do a bit of research. Each manufacturer will have different systems. Some will actually have a reset button on the battery. Some will use calibration software and other will use a special discharge/charge cycle. My Compaq uses the button and software, one of my Toshibas uses just software and another uses the cycle. When you do the recalibration it forces the system to measure the discharge rate and the time. When complete it then knows the new value of how much time or capacity your battery has left. Sometimes you will find that the battery still has plenty of life left. And other times you will find the battery does need to be replaced. Replacement batteries are much cheaper now but this is worth doing before you have to spend money.
on May 20, 2010 | Computers & Internet
Screen is dim when power not plugged in
In power settings you will find the dim adjust, Your laptop has power settings you can adjust to your preference. That said, the default settings are usually set to a power saving that means when you unplug your laptop from th AC source your laptop will dim to the power savings settings and prolong battery life. Look in power settings by right clicking the power icon in the taskbar notification area and open the power options. There are many options to choose from I use High Preformance, but on battery it shorten battery life. If you need assistance just respond to this solution.
Nov 05, 2012 | Samsung NP-N110 Netbook
My ibm wont turn on unless the charger is in it just wont turn on.
The battery must have gone bad! if its three or more years old you need to get a new battery for the computer. Periodic conditioning of the battery from first use may prolong the battery life. Battery life is reduced by plugging computer with battery all the time.
Conditioning. Periodic full charge and full discharge practice is good for battery. Batteries are better charged when they are at less than 10% power and its better to charge them to 100%. Do not leave on electric power once they are fully charged.
I hope this helps in future but current battery may need replacement!
Sep 14, 2011 | IBM ThinkPad T40 2373 Notebook
Tip
Prolong Your GPS Battery Life
Are you tired of having to keep your GPS plugged into the car for the entire duration of your drive? Does it die out instantaneously after removing it from it's jack? If it does, there nothing you can do to fix it because the battery had over heated and lost its battery life tremendously. I can only say that you would need to purchase a new one.
However, if your GPS doesn't die out right away, here's your chance to start prolonging its life. First, let it completely die out by turning it on, and leaving it on until it the batteries run out of charge. Second, plug the dead GPS into either a house outlet, or a car jack (if you are using the car jack, make sure the car is on!!!). Third, wait for the GPS to reach full capacity, but DO NOT let it overcharge, it kills the battery. So I recommend checking on the charging GPS periodically at even intervals of your choice. When it is done, just unplug it, and it is good to go.
NOTE: Do not charge the GPS in while in use.NOTE: If the battery is low as you are driving, turn it off and plug it in to charge.Explanation: This is why the steps above the notes are to be taken to prolong the life of your GPS' battery. 1 Complete Charge + 1 Complete Drain = 1 Charging Cycle
Thanks for reading my tip!
on Dec 04, 2009 | GPS
Tip
How To Prolong Your GPS' Battery Life
My laptop doesn't read the battery? what could be the problem?
First, check to make sure the battery is properly inserted.
Second, how old is your laptop? Batteries in laptops only have a certain lifespan. If you leave the battery in the laptop for prolonged periods of time while it is plugged in charging and the battery is at 100%, the life span will significantly degrade over time due to the constant charge/discharge.
Aug 22, 2011 | Averatec 4200 Notebook
How do I prolong the battery life of my Lenovo S10-2. Should I fully discharge or not?
The easiest things to do to make sure your battery lasts longer include turning down the brightness, turning off the Wi-Fi if you aren't using the internet, making sure that nothing is plugged into the computer, and not running programs that need a lot of resources, like games, or software to edit photos.
As for discharging the battery, the best thing to do for your battery would be to run it all the way down about once a month, and with the computer off, let it charge until the battery is full. What this does is let the battery know how much capacity it really has left, and it gives you a more accurate time remaining estimate on the battery guage.
Aug 21, 2011 | Lenovo IdeaPad S10-2 Netbook
Where can I purchase a battery charger?
A new product laptop battery charger
AC input:100-240V AC 50/60HZ
DC input:12-24V
High output:16.8V 2.5A DC
Low output:12.6V 2.5A DC
charge time:3-5h
color:black
That has be dead against use front happen problem and LI ion battery trait., when charge battery must take out use, has insure up to snuff on room temperature charge , as well as can avert happen blast or combustion or life reduce problem. simultaneity can let it is accomplish normally charge and discharge process the battery , It’s activation state urge LI ion battery inside is longtime. Can prolong use life the battery.
That has be dead against use two species battery voltage parameter at laptop IT trade, the product have setup switch switchover voltage, insure apply two species different voltage laptop battery charge, any more introduced commutator model the product DC output plug, can use different variety, let use charger electricize for laptop battery is safety and set one's heart at rest. And that can prolong use life the battery, best economize expenses which needless for the peoples.
It’s charge use AC to DC, DC to DC two model charger. May use in the home or office ,and car or ship or train. Usag is best convenience .
If you have need the product, please contact us
Mobile:13751018213
skype:lincen18213
Email:lincen18213@163.com
FAX:86-755-61573100
Feb 25, 2009 | Zenith ZPA-314 Portable DVD Player
Acer Aspire 5600 Series 5630-6951 Laptop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
