Question about IBM ThinkPad A22e 2655 Notebook
IBM A22e turn on problem
I have an IBM A22e Celeron.When I plug in the power cord, the light bulb shows green but the machine doesnt turn on when I push the on button, the bulb goes off for a few second then comes back green again. Someone tells me it is not a battery problem, it could be the switching-on-system that is bad...please help on how to solve this.
Regards
  • Davej00 Apr 28, 2009
    Hi, I have the same problem.
    It will not do anything when its stand alone (battary) - no light, but with AC Adaptor the power light is active. & goes offf for a second when u press the 'on' button. I've also noticed that with this lid shut, the Power light seems to blink. Like 1.5sec on, 1 sec off... repeating.
2 Suggested Answers
matchbox2022
  • 46 Answers
SOURCE: Changara
Try turning on the system without the AC adaptor. If it doesn't work on battery, then try pressing and holding the power key (after removing the battery) for 30 seconds.
Now attach the AC adaptor and try to power on.
If it doesn't work, it sounds like either a motherboard issue or an AC adaptor issue (possibly there isn't enough voltage being supplied) but it's an odd problem. I hope I helped.
Stay spicy, and happy lappying! :)
Posted on Dec 16, 2008
IBM Wheelwriter 6 powers up, then beeps. No lights, changed batteries. What is problem?
I have an instruction manual for IBM Wheelwriter 1000. The troubleshooting page in my manual for the machine coming on and having no lights is to make sure the cord is securely plugged into the typewriter and the wall or power strip and to switch the machine off and back on. Mine has a power saving mode where the lights go off after a while to enter power saving mode. I only need to touch a key to turn it back on.
Hope this helps - Cindy
Nov 06, 2014 | IBM Wheelwriter 6 Typewriter
How do i flash my generator to get power again
Get two short extension cords and cut the FEMALE end off each one. Strip back the insulation on that end. Connect the two green wires to each other, and connect the two white wires to each other.
Connect one black wire to a light switch, and connect the other black wire to a 20W appliance-type incandescent light bulb. Also run one short black wire (from a cut-off end) from the second terminal on the light bulb to the second terminal on the switch, like so:
plug -- black -- switch -- black -- bulb -- black -- plug
plug -- white ----------------------------------- white -- plug
plug -- green ---------------------------------- green -- plug
Turn the switch to the OFF position.
Start the generator. Plug one plug from your new rig into an outlet on the generator. Plug the other plug from your new rig into a wall outlet supplying 120V. With the generator running, turn the switch to the ON position.
The bulb should flash for a short while, then become steady. When it's steady, that side of the generator is flashed. Repeat for the other side of the generator if it makes 240V.
Jul 10, 2014 | Electrical Supplies
In my IBM T23 Thinkpad battery is fully charged showing green light constantly but not able to switch 'ON' after pressing the power button. What should I do?
try to switch it on with power cord still plug in it, if it do boot-up, you have to replace your baterry, if not somethings wrong with your laptop
May 06, 2010 | IBM ThinkPad T23 2647 Notebook
Thinkpad a22e no operating system
try to change the format cd , could be corrupted cd.
Mar 21, 2009 | IBM ThinkPad A22e 2655 Notebook
Changara
Dec 16, 2008 | IBM ThinkPad A22e 2655 Notebook
IBM Laptop A22e Display an error 0175
The CRC error (POST = power on startup test) on boot up refers to the BIOS settings. This could be cause by a near flat BIOS battery and it needs to be replaces. If it is not the battery you need go to the BIOS to correct any faulty settings.
Nov 29, 2008 | IBM ThinkPad A22e 2655 Notebook
Audio problem for IBM A22e celeron laptop
hiiiiiiii ther
how r u ??
u have too know the driver model and look it up online
or just try driver update
and if u need any further assistance email me
u take care and have fun
salammmmmm {bye in arabic }
p.s rate me thanks
Nov 25, 2008 | IBM ThinkPad A22e 2655 Notebook
IBM X226 server
i have two x-series server but in one server with one power cords it is showing green light but in case of another server it is comming yellow light.
Nov 24, 2008 | IBM xSeries 226 Server
IBM Thinkpad A22e Shutdown early on full battery
First, you should clean the battery terminals. You can scratch the terminals with a metal and then charge. Secondly, you should change your battery, that is, buy a new battery.
Aug 15, 2007 | IBM ThinkPad A22e 2655 Notebook
Open Questions:
See all IBM ThinkPad A22e 2655 Notebook Questions
IBM ThinkPad A22e 2655 Notebook Logo
137 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
