Question about D-Link AirPlus DI-524 Wireless Router
Can't get router to connect to internet 192.168.0.1
Someone please help me. Got the router (DI-524) from a friend and can't get it to work. Tried hard reset on router to no avail.
Jason
  • 1 more comment
  • jason_l_grah Dec 16, 2008
    How do I do that?? Thx for the help.
  • Anonymous Feb 27, 2009
    my isp requires me to use a username and password do you know ow to set the router up so it can log in or at least let my computer log in through it?
  • dangal Mar 01, 2009
    the setup asks for a username from my isp (virgin)
  • 4 Answers
I would attempt to connect through a network cable first. Just plug it in to the router and point your browser at 192.168.1.1. The default username and password should be admin and admin. Set up your router with your ISP details and make sure you can connect to the internet. Then add your wireless conncetion WITHOUT security and test it. If successful add your wireless security. WPA2 is stronger than WPA which is stronger than WEP. Now you need to change the default username and password in your router for extra security. If you can connect to the internet from elsewhere you can download a manual from www.dlink.co.uk.
Posted on Dec 16, 2008
    Problem Solver:
  • 6 Answers
Please change the IP Address of the router to 192.168.1.1 and then try to ping it from your PC.
I cannot connect wireless or wired on my Dlink Di-524..;pls help
hi there,
Hard reset the router (you would see a hole when you flip the router over insert tooth pick or pin for 30 seconds and restart the connection)
Swap the micro filters(spilter, the one which is connected to telephone socket)
If it is not working call your Internet service provider.
Dec 20, 2010 | D-Link AirPlus DI-524 Wireless Router
Dlink router is not connecting to the internet
Check the lights on the router to make sure both out going and incoming are on.
Manual link below in case that helps
ftp://ftp.dlink.co.uk/di_broadband_gateways/di-524/di-524_manual.pdf
If not both on contact broadband supplier as IP for router may have been "altered" and will need resetting their end.
Not unknown for an outage to be proceeded by a "spike" which can blow unprotected items.
Jan 24, 2010 | D-Link DI-524 High Speed 2.4GHz (802.11g)...
Can't connect to my d-link DI-524 with my pc or wii
If you reset the router then the is now disabled... whatever your trying to connect with whether it is a PC or a game system make sure its connecting using no security
Mar 29, 2009 | D-Link AirPlus DI-524 Wireless Router
Di-524
- Update the firmware of the router.
Feb 28, 2009 | D-Link AirPlus DI-524 Wireless Router
My D-link DI-524 Wireless router not working.
g´day m8,
Your D-Link AirPlus G DI-524 Wireless Router needs a hard reset.
Log in to your router, go to -> administration -> factory default -> Restore Factory Defaults: =  "yes"
Then save settings.
You have now reset the router.
First thing you do is set your wireless setup in your computer to the same, i.e. no security.
Test if there is connection, if, the start with the setup from the top, beginning with admin password.
/Teis
Dec 19, 2008 | D-Link DI-524 4 Port Wireless-G Router -...
Connecting to dlink-524 on vista
your key code is the the code that you set fpr the key code di you write it down like it tells you to
Nov 24, 2008 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Connecting with internet
Yes, that is possible since you have a wireless router. Router can share internet connection. Go to this link this will help you setup the wireless connection (secure it if you want)
http://www.portforward.com/english/routers/wireless/Dlink/DI-524/wireless.htm then on the very bottom there is an option how to Configure Windows XP to connect to your wireless network.
I suggest this because it would be better if there is encryption on the network so people wont be able to access your internet for free (unless you give them the security key)
Sep 15, 2008 | D-Link AirPlus DI-524 Wireless Router
Configuration
I have same problem. Can not connect Di 524 to Surf 5100 Cable modem
Jul 23, 2008 | D-Link AirPlus DI-524 Wireless Router
DI-524 wireless router as wireless switch
You need to disable the DHCP server on your "slave" wireless router ( the di-524 ). In D-link routers this might be called configuring it to be an "Access point".
When this happens, connecting to the second wireless router should cause your computer to obtain an IP address which is in the range of the first router (that is to say, it will use the first router's dhcp server).
You should be able have your laptop connect with an automatic IP address and have it work.
Jan 24, 2008 | D-Link AirPlus DI-524 Wireless Router
Connect to wireless D-Link and Westell6100
I am assuming that you have a functional LAN cable connecting the Westell and the DI 524, right? If you are unsure, replace it with a cable you know is good.
If the 524 is turned on downstream of the Westell modem, it should find what it wants. You may try rebooting the Westell and seeing if the 524 finds it, and you maybe should reboot the 524.
Sometimes, when the world gets jiggered up I have to work pretty hard to get my DI-524 resync'd to my DSL modem.
Oct 26, 2007 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-524 Wireless Router Logo
285 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
