Question about Samsung SyncMaster 203B LCD Monitor
Syncmaster 203B LCD not working with Vista 64
Im trying to use this monitor on my new computer, but when I start up my computer nothing shows up...
I have the monitor on, it acts like its on but it doesnt display anything but a black screen (what would display if I had just turned on the monitor without turning on the computer). The monitor is plugged into the computer, when I unplug it from the computer it gives me a message on the monitor saying "check signal cable"... So Im assuming its on correctly, the computer is turned on correctly, but the monitor just doesnt display anything from the computer. I dont have another monitor from which to get on and change any settings on my new computer, so im using my old computer to try to figure out what to do. Ive also tried starting in safe mode (F8 when the computer starts up) and it does the same thing, acts as if the computer isnt on.
Thanks.
  • reigner99 Dec 16, 2008
    Alright Ill try that, but one thing I didnt mention is that my new computer is from a friend, and he has never had problems with the monitor not displaying before (even yesterday, it worked fine with his monitor)
    So when it comes down to it, my old computer works with my current monitor and my new computer works with other monitors, they just dont work together...
    Novelist:
    Champion:
  • 233 Answers
Try putting the graphics card from your old computer into your new computer. That is where I would start.
Posted on Dec 21, 2008
  • 68 Answers
I would first recommend reseting the bios, if the monitor still is black then it may be a problem with the graphics card
Posted on Dec 16, 2008
  • zonkpc
    zonkpc Dec 16, 2008
    The only other thing I can think of is there an external graphics card as well as an built in one? If so when windows loads try plugging the monitor into another port, it may be that he has removed the graphics card and left the original one for yourself. If this is the case then windows may be looking for a moniter in a pci port and not looking at the motherboard port, this can easily be changed in the bios. Good luck!
I just got a used syncmaster 203b monitor. I hooked it up and all I get is a black screen. I downloaded Driver whiz and hooked it up again. Still a black screen. Still get a black screen the blue light is...
Make sure that your computer unit is working. Sometimes we suspect that it is a monitor problem but usually, it is a frozen CPU set.
When you turn on the monitor, it should light the blue led and after a while, when it does not receive signal from the CPU, it will turn orange. If that is the case, the monitor is functioning well.
So what could be the problem?
Make sure that you hooked the monitor to the right VGA port. If you have an internal VGA port (built in with the motherboard) and you also have an external Video Card, you should hook it to the external VGA port and not the internal one since it is overridden by default.
Do you hear the "short beep" sound when you boot your PC? That signals a good video system. If you don't hear that beep sound (provided your PC's speakers are okay), you should open your CPU case and try to remove your memory modules (RAM). Clean the pins with an eraser and put it on.
Now, your computer should work fine and so with your monitor.
Aug 14, 2010 | Samsung SyncMaster 203B LCD Monitor
Syncmaster 203b power light comes on, but no image...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 20, 2010 | Samsung SyncMaster 203B LCD Monitor
SyncMaster 203B (Black) LCD Monitor: Monitor will not stay on (Samsung Syncmaster 203B)...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
May 16, 2010 | Samsung SyncMaster 203B LCD Monitor
Blank screen the screen has been working for over a year and all of a sudden went blank its not my pc as i plugged my pc into another screen and worked fine.... the standby flashing stops flashing when i...
Since you have tried another monitor with your computer, then we can only assume that your LCD monitor had gone bad.
If the light is green but you can't see anything on the screen, then most likely the backlight has gone bad. Unless you want to take the monitor apart, I would suggest buying a new monitor.
Apr 19, 2010 | Samsung SyncMaster 203B LCD Monitor
I want to open the case of Samsung Syncmaster 203b without damaging. Can you advise?
I do not recommend this at all. There is a VERY HIGH RISK of damaging internal components. If you want to tweak/modify/etc., just say no. The only thing you can do is keep it clean. If you're wanting to make it better, then I suggest investing in a new one.
Jan 14, 2010 | Samsung SyncMaster 203B LCD Monitor
My monitor started to give me problems when I first turn it on I have to push the power button several times before it will stay on it's the samsung syncmaster 203b
you need your power supply reaired. the capacitors go bad. remove the covers and look at the power supply reeplace any leaking and or crowned capacitors
Jan 01, 2010 | Samsung SyncMaster 203B LCD Monitor
How to rotate display when I rotate screen - SyncMaster 203B
You ought to be able to bring up the video card settings from your control panel and change it there. For instance I have a nVidia graphics card. When I bring up the settings panel it offers me the opportunity to change the rotation there.
Dec 28, 2008 | Samsung SyncMaster 203B LCD Monitor
Samsung SyncMaster 203B LCD Monitor Logo
284 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
