Question about Dishwashers
Whirlpool gold model GU100XTLB0, is not cleaning, leaving soap in the tray. have replaced the fill valve assembly, still doing same thing. what else can i check?
I found that the chopper assembly shaft had snapped in half, the scraper was not rotating to clean the screen so it was completely clogged. called the local parts supplier and they had the part in stock for $25. I will assemble tonight, but this should correct my problem. As dirty as the screen was I can see why the water pressure in the dishwasher was extremely low and not cleaning and leaving soap in the tray. To all you home "do it yourselfers", check the chopper assembly. From the looks of the broken shaft, it appears as if there was a quality problem with the casting of the plastic shaft. The shaft had air bubbles inside the shaft.
Posted on Dec 16, 2008
Whirlpool Gold icemaker won't make ice
Try this and add tap water to the empty ice maker. Turn it on if off and if after the water freezes the ice maker cycles dumping the ice into ice bucket and if the ice maker does not refill with water on its own you will need to replace the=> 2188746 Water Inlet Valve
If the ice maker does nothing then replace the=>
2198597 Ice Maker Assembly
Thanks John Tripp Appliance 911
Feb 16, 2014 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Top loader washing machine model sm8281115 leaking when filling loader whirlpool gold washing machine
The leak could be the filler tube, the soap dish, the water valve. You have to do some detective work to figure out where it is.
Jul 24, 2013 | Washing Machines
Upper tray doesn't clean, lower tray is fine. Also, lot of soap sticks in the soap compartment after the cycle. Thanx.
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound. If it seems as a low water pressure then check the fill valve.
Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete.
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
Jan 31, 2011 | Whirlpool 24 in. GU2500 XTP Built-in...
The icemaker whirlpool gold model GRZSHWPBOZ
either the water valve is bad if so replace it or the tube that delivers the water to the tray is frozen . ck both and replace the one that is bad . hopt this helps mm ..
Apr 06, 2010 | Refrigerators
Whirlpool dishwasher doesn't clean very well
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Oct 22, 2009 | Whirlpool Dishwashers
Whirlpool Gold Ice Maker not filling
If your water valve is good and your filter is not in need of replacing then you probable need a new icemaker, yes.
May 12, 2009 | Whirlpool ED2FHEXN Side by Side...
Dish washer not filling
I had the same problem. It was a clogged water inlet valve. Packed with sediment. Accessible from the bottom if you have the right tools. Just clean out and replace. Or the valve could be bad.
Apr 10, 2009 | Whirlpool 24 in. GU2500 XTP Built-in...
Whirlpool GU980 gold fills runs for 5 seconds then drains
Appears that the controller has gone ballistic and is now doing its own thing. That part may need replacement. Search Over 2 1 Million Appliance Parts
Sep 05, 2017 | Whirlpool Dishwashers
Dishwashers Logo
Top Dishwashers Experts
