Question about Whirlpool LTE6234D Top Load Stacked Washer/Dryer
I HAVE AN ESTATE WASHER
THE WATER WON'T SHUT OFF ON IT'S OWN I HAVE TO SHUT OFF IN THE BACK THATS HOW I HAVE TO START THE WASHER I HOP ON TOP REACH IN THE BACK TURN THE WATER ON WHEN WASHING STARTS I HAVE TO TURN IT OFF THE SAME WAY TO RINSE I HAVE TO DO THE SAME THING
  • michelelynmi Dec 16, 2008
    HEY DAVE HERE IS THE MODEL NO CS3507196
  • michelelynmi Dec 18, 2008
    HEY THANKS!!!!YOU WERE RIGHT,MY HUSBAND FIXED IT.THANKS AGAIN I WAS SO GLAD I FOUND YOU!!! MY HUSBAND IS HAPPY TOO....BECAUSE HE DON'T HAVE TO HEAR ABOUT IT ANYMORE LOL ~MERRY CHRISTMAS~
    MICHELE C.
    MONROVIA,IN
  • 113 Answers
You either have a water inlet valve that is stuck open. Need to replace the valve. Give me the model # and I can be more helpful. thanks Dave www.washermd.com
Posted on Dec 16, 2008
  • Dave Dec 16, 2008
    The washer agitates and spins ok though?? The water just keeps coming in as it agitates?? thanks dave
  • Dave Dec 17, 2008
    Sure sounds like you need a new water inlet valve. part # 285805 should do the trick. Hope that helps, dave www.washermd.com
Water won't shut off on my Estate washer
check clear tube that is inside machine.1st take off shell of machine look for clear tube about 1/4 inch diameter.it sometimes comes off,it pushes over nipple to load size water fill knob.if it came off the water will keep on flowing and over flow.if that's the problem just put a dab of silicon on nipple and push tube back on.
Feb 20, 2012 | Estate TAWS800JQ Top Load Washer
My estate whirlpool washer model# taws800jq1 water wont shut off when you start cycle
See this tubing:
If this tubing gets sediment in it OR vibrates loose OR gets pinched from re-installing the cabinet OR if the tube gets a hole in it then the pressure won't build up as the water level rises and the water will not shut down. The component that tube is attached to it the water level switch. The likelihood of it being bad is slim. Most of the time sand and sediment gets into the tubing and simply blowing it out and reattaching the the tube to the switch fixes it. Be sure to pump out water after cleaning and re attaching the tube to the water level switch. Service manual and more
Nov 08, 2011 | Estate TAWS800JQ Top Load Washer
I believe the water temp switch is bad. It will start filling on warm then stop if I put it on hot it will fill with cold water. I have cut the hot water off to achieve this but when it reaches rinse it...
it sounds to me that the hoses are connected to the machine incorrectly. Typically if the plumber ran the water lines behind washer correctly the hot pipe is on the left and the cold pipe is on the right sometimes thats backward and be determined by touching hoses while filling on warm setting and see which hose feels hot. On the back of washer they where they connect hot goes on the bottom and cold on top
Aug 08, 2011 | Estate ETW4400VQ Top Load Washer
The washing machine stops during rinse and won't spin.
Does it pump out the water? If it does then you have a broken drive coupler
11_10_2011_1_23_46_am.jpgIf it won't pump out OR spin yall have either a bad lid switch
11_10_2011_1_24_30_am.jpgor loose lid hinge or broken strike.
Service manual and more HERE
Aug 07, 2011 | Estate TAWS800JQ Top Load Washer
Water continues to drip after washer has stopped?
The fill valve has dirt in it and it will not shut off completely... kind of the opposite of these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 25, 2010 | Estate TAWB600JQ Top Load Washer
Taps that connect to washer water hoses are leaking
first of all make sure water water is shut off to washer,you can take the handels off take the nut off that holds the valve in place there you find either a rubber groumet or o ring replace that put back together should fix your problem.
Jun 20, 2009 | Estate TAWX700JQ Top Load Washer
Washer leak in an estate washer
i have Had 3 estate washers leak on all four corners....there junk went with ge instead......estate washers are horrible
Mar 20, 2008 | Estate TAWX700JQ Top Load Washer
Water keeps going and going and going!
the water is draining back to the ocean. The drain hose was not emptied properly from its last use. Put the machine in spin cycle (about 5 minutes) only to spin out the water from the outer tub completely and retry washer. If still problem, then visual check drain hose that it still has a "rising" section higher in altitude than the water level of inner tub (when working properly) before it makes a U-turn downward to send back to the ocean. You can also test the drain hose by putting machine in fill mode and crimping off the hose (fold hose over) to simulate a good drain hose. At this test, you should not "feel" water running through the hose if successfully crimped.
Jun 21, 2007 | Estate TAWS800JQ Top Load Washer
Whirlpool LTE6234D Top Load Stacked Washer/Dryer Logo
23 people viewed this question
Dan Webster
Dan Webster
Sal De
