Question about Maytag 24 in. MDB9150A Built-in Dishwasher
Will not drain
I have a problem with my Maytag MDB-9 dishwasher..it will not drain. Where is the drain and what could be the problem?
  • Anonymous May 10, 2009
    Do not even know how to check the drain... Where is it?
  • 142 Answers
Common problem is detergent/power used, the filter becomes blocked, and the outlet solenoid becomes blocked.
Posted on Jan 27, 2009
rylee_smith
  • 8619 Answers
SOURCE: dishwasher is not draining
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Nov 04, 2009
eagle338
  • 4889 Answers
SOURCE: Dishwasher will not spray water from arms
Check for utensils or pot handles that may be hanging below the bottom rack and interfering with motion of spray head.
Clean holes with toothpick.
Check temperature at hot water faucet with meat thermometer. If below 120°F (49°C), turn up thermostat on hot water heater.
Posted on Oct 19, 2007
rylee_smith
  • 8619 Answers
SOURCE: My Maytag dishwasher Model # MDB-3 will not drain.
Hi
Thanks
Rylee
Posted on Nov 03, 2009
SOURCE: Maytag Dishwsasher Model MDB-9
The Switches do not oprate when you press them. What can be the reason?
Posted on May 31, 2010
blueextc3221
  • 15935 Answers
SOURCE: How do I find and remove the water inlet valve in
CLICK HERE for a representation of the part in question.
CLICK HERE for an expanded parts diagram (#1)
1. Shut off the water and remove the lower access/kick panels.
2. Then disconnect the two wires from the inlet valve terminals - note which one goes to which terminal
3. Using an open end wrench loosen and disconnect the water supply line.
4. Remove the two screws securing the valve assembly to the inside wall of the dishwasher
5. Loosen the clamp on the water outlet line and slide off the hose.
Installation is pretty much the same in reverse.
Sometimes the valve assembly comes with the wire terminals oriented in a different direction than what you may find when you take yours off. If it won't work for you, remove the four screws that hold the electrical side of the inlet valve and rotate it to the needed position.
Make sure when putting it back together that you tighten the screws evenly to prevent leaks.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Testimonial: "This looks like exactly what I was looking for - and lots of good details. Thanks- NKC, Michigan"
Where is filter on maytag mdb-9 dishwasher
If you wish to get more details visit the site linked here. http://homenol.blogspot.com/
Feb 22, 2017 | Maytag Dishwashers
My Magtag MDB-9 Dishwasher the door does not slowly come down, it acts like the spring in it is broke. Could this be replaced?
I recently had a similar problem and after looking around the web I found a site called Appliance Art (http://www.applianceart.com). They have a dishwasher covers that look like stainless but were cheaper than actual stainless. I'm happy with the result, it might be what you're looking for,
Oct 07, 2009 | Maytag Dishwashers
Heat will not turn off Maytag MDB-9
The lock light will not turn off. tried break no joy.
Feb 26, 2009 | Maytag 24 in. MDB9150A Built-in Dishwasher
No water comes in to wash dishes.
sorry to sound obvious, but you will have pull the dishwasher out to get to it, just follow the hose into the inlet valve unit, they are located under the unit at the back.
Jan 27, 2009 | Maytag 24 in. MDB9150A Built-in Dishwasher
DW won't fill
Found it, fixed it.
Jan 17, 2009 | Dishwashers
No power to Maytag Dishwasher MDB-8
no breaker on motor look at door lock ***. for power
Nov 03, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Dishes have dried on food particles after cleaning
common problem with dishwashers, the filters become blocked/ break down, a cleaning cycle with an approved detergent usually fixes this. if not, the filters my need replacing.
Oct 24, 2008 | Maytag 24 in. MDB9150A Built-in Dishwasher
Sep 27, 2008 | Maytag 24 in. MDB9150A Built-in Dishwasher
Maytag dishwasher won't drain..
Please find attached DRAWING This will give you an idea how to tackle this
Jun 24, 2008 | Maytag Dishwashers
Maytag 24 in. MDB9150A Built-in Dishwasher Logo
561 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
