Question about Thetford Norcold RV Cooler/Freezer
My norcold frig(RV) freezes food in lower level
I have an RV norcold refrigerator model#12101M that freezes food below with the temp set as low as it will go, I moved the thermostat as low as it would go on the cooling fin it's mounted on. It does this on both gas and electric. Please help.
Thanks,
herbert phillips
  • 3 more comments
  • dennis522 Jan 01, 2009
    exact same problem. Refer temp is 5 deg when setting is at 1 = warmest.
  • Anonymous Jan 18, 2009
    We have the same problem with this refrigerator. Also, can't use ice maker becauses it freezes up. Can anyone help?
  • pwclark2 Jan 18, 2009
    We have same problem with this model. Also, can't use ice maker because it freezes up.
  • benmalcom Feb 09, 2009
    Model number N641R frezzes even on lowest temp setting, HELP!
  • Anonymous Mar 26, 2014
    the refrigerator is freezing everything, I was thinking broken thermostat but could it be anything else and if it is thermostat is it an easy fix?
    Problem Solver:
  • 15 Answers
In your refridgerator there is an internal thermostat on the cooling fan u can move up or down it should be placed on the last finn to the right looking at the fridge
thanks
cruz
cruz's mobile rv repair
Posted on Jun 17, 2009
I cannot understand the dual thermostat manual (" rolling " knob type) controls . They are printed in Japanese . There are 2 temp. control knobs side by side located inside the ref. compartment / lowe
Don't think it's the temp control problem, I suspect one on the defrost elements at the top is faulty, if food starting to defrost in the cycle indicates the lower element is working overtime.
Nov 22, 2014 | Refrigerators
Norcold fridge does not stay cold.we turn it to lp gas or electric and it goes to an n.
Quit playing with it ... absorption refrigs work slow ... and do not recover well ... If yours has a thermostat ... set it a little lower ... check it in the morning ... use a thermometer inside. Keep track of the temps.
Putting warm food in the frig will result in a big slowdown in recovery.
Thanks frr using FixYa.com
Oct 05, 2010 | Thetford RV Refrigerator - N300 Model -...
Frig won't hold set temp keeps freezing things.
Thermostat is defective.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 11, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Fruits & Veggies are freezing in both lower frig compartments
Good day,
This problem appears in spades this time of year, every year.
The problem becomes more severe when the temperatures in the house cools down and is made even worse if the usage of the machine becomes lighter.
It occurs when the machine is off, not on.
There is an open vent, near the bottom, between the freezer compartment and the fresh food compartment. This opening or vent is necessary when the machine is running, so that the air pumped into the top of the fresh food section, can return to the freezer compartment. This is by design.
Now,
When the machine is off, the zero degree air from the freezer compartment. can drift into the fresh food compartmnet and drop the temps near the bottom to below freezing.
Off time increases substantialy at this time of year.
Some have even recommended turning the controls colder to offset the problem, but I've no proof it works well, or even a little.
SXS and top freezer models experience it more than bottom freezer models.
Dec 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer works ok but the fridge doesn't
are you running gas to oper the frig in the rv or electricty if only using the heating element for the frig RV STYLE ONLY maybe starting to make and break causing intermittent cooling or not enough cooling in frig but at all thing concerned try to increase you temp setting higher if you have that option
Aug 19, 2009 | Refrigerators
GE Profile Arctica - Frig Freezing Food
Replace the damper assy, in the Refrigerator section. The damper door is stuck open. Very common problem on these refrigerators.
Nov 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Food freezing in refrigerator section of frig.
look under your refridgerator and see if there is alot of dust on the coils. Whenever food starts freezing in my fridge I vacuum the coils and the problem goes away.
Sep 01, 2008 | Refrigerators
Thetford Norcold RV Cooler/Freezer Logo
2,168 people viewed this question
Top Thetford Refrigerators Experts
John Tripp
John Tripp
christian nielsen
tom wright
tom wright
Are you a Thetford Refrigerator Expert? Answer questions, earn points and help others
