Question about EverFocus EDSR100
Cannot copy video onto memory card
Hi there, I am trying to copy video onto a Canon compact flash card from an Everfocus DVR and it's saying "cannot copy file" We've had this problem before and I remember someone saying that the flash card had to be formatted?? Any ideas?
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 21 Answers
You should try Long Path Tool to copy data to external devices.
Posted on Oct 02, 2015
I have a sandisk 2.0 gb conpact flash copies ok but can take 45min to copy 5 mins of suvalience
Posted on Mar 31, 2009
After inserting flash drives of video copied from my 6 camera EverFocus camera system
Yes. You want to open it. If you open it, your laptop will try to play that video so you can see it.
Dec 19, 2013 | Home Security
I want to find a good app to open copied video from everfocus home security cameras
You can use restore to take the computer back to a date that you know that it worked. You can use right click and open with to set the program, you can reinstall everfocus. You can manually set the file associations.
Dec 19, 2013 | EverFocus ECOR264-9X1/2T ECOR264 Series 9...
Dvr password
default password is 11111111
Apr 26, 2013 | EverFocus ECOR264-4F1/500 H.264, 4...
Err CF I have a Canon Rebel XT, how do i fix this error and what does it mean?
CF stands for compact flash which means you have an error with your memory card. Try removing and replacing your compact flash memory card. If that doesn't work you may need to format your memory card or replace it.
Jul 28, 2011 | Canon Rebel XT / EOS 350D Digital Camera
Have new Vivitar DVR810HD Digital Video Camcorder, loaded SD card correctly but camera does not record onto SD card Help!
Make sure that the video camcorder was not turned off immediately after recording before the images are saved in memory. Also be sure that your memory card is properly inserted in your camera.
Feb 27, 2011 | Vivitar DVR 810HD Flash Media Camcorder
Internal memory??
Highly recommend that you consider using a card reader to download you pictures. You insert the camera's memory card into the reader, and then insert the reader into a USB port on your computer. The card then shows up as a hard drive so that you can simply copy/paste or drag your picture files onto your computer. Card readers are much more faster in downloading pics, do not require the use of your camera's batteries, and provide much more reliable downloading of the pictures (fewer errors). They're also VERY inexpensive these days. Here are some examples of CF card readers from Amazon:
http://www.amazon.com/s/qid=1223745821/ref=sr_st?keywords=cf+compact+flash+card+reader&rs=172282&page=1&rh=n%3A172282%2Ck%3Acf+compact+flash+card+reader&sort=price
Also, if the card has somehow become corrupted, take no more pics until you've recovered the photos. Take the card out of the camera. Here's some freeware photo recovery software that should be what you're looking for:
http://camerarepair.blogspot.com/2007/12/recovering-those-accidentally-lost.html
You will also need to use a card reader with this software. Finally AFTER you've recovered your photos, recommend formatting the card IN YOUR CAMERA to prevent this from happening again. Note that formatting will totally erase your card. Turn on the camera, press the menu button, select the tools menu. Go down to the selection that states your CF card's memory capacity and select it. Then follow the formatting prompts.
Oct 08, 2008 | Canon PowerShot A75 Digital Camera
Formatting disks for EDSR1600
The EverFocus EDSR Security DVRs use standard PC Parallel (PATA) hard drives. I have used ATA100 and ATA133 speeds with no problems. There are no PC-type settings required except as below. The DVR has it's own internal firmware and will format the drive to its requirements.
If you are using a SINGLE drive tray, the largest hard drive I know will work is 500 GB. Set the drive to Master and you are done with the hardware setup. (CS Select would also probably work.)
If you are using BOTH drive trays, the largest hard drive EverFocus says will work on the EDSR100 or EDSR110 is 320 GB. Set both drives to Master and you are done with the hardware setup. (CS-Select on both would also probably work.)
Do NOT set any drive to Slave!
Lock the drive trays; if you don't the DVR will not go into record.
Press the STOP key and then press the MENU button. Go into the SYSTEM menu and do a DISK RENEW. This will erase the hard drive and also prepare it for DVR recording.
Do this by using ► or ◄ to select DISK RENEW. Change NO to YES (by using ▼ or ▲) and press the ENTER button. Highlight YES again by using ► or ◄ and again press the ENTER button.
Press the MENU button to exit and reboot the DVR. Then press RECord and you should be recording.
Aug 09, 2008 | EverFocus EDSR1600 16 CHANNEL 160GB...
Blue screen
You should check the settings to see which type of memory card you are using, xD versus Compact Flash. The default xD card that the camera comes with is very small and may not support saving the size of image you're trying to capture. If you are using a card with enough memory the card itself might be defective..
Jan 12, 2008 | Fuji FinePix S7000 Digital Camera
EverFocus EDSR100 Logo
443 people viewed this question
Top EverFocus Televison & Video Experts
Marvin
Marvin
Are you an EverFocus Televison and Video Expert? Answer questions, earn points and help others
