Question about Panasonic DVD-RV32 DVD Player
Panasonic dvd-rv32 f894
I have a Panasonic DVD/CD Player. when I turnd power on, the display
post an error :F894. I checked error code and knew that efprom 24C08W6
had problem. I want to repair it but I don't have the firm ware of them.
Pls, tel me method to cancel this problem.
Thanks.
3 Suggested Answers
Palmbeach
  • 185 Answers
SOURCE: DVD A160 E PLAYER ERROR CODE
Hi Maggie
This error actually means "eeprom abnormality."
An eeprom is a memory chip inside the player. In this particular case, it contains data that basically tells your player how to set itself up after it has been powered up. You could try disconnecting the power cord for 15 minutes then try the unit again. Failing that the chip may have a bad connection to one of the pins or it may be faulty.
If you are tempted to open the unit, be careful because these components are sensitive to static, which means that touching bits inside even when the power is off can damage them unless you know what you're doing.
Can be repaired by an engineer.
http://www.dcevolution.net/panasonic/downloads/S49%20service%20manual/CHM0505012CE_09.xml
Posted on Feb 15, 2008
  • 16 Answers
SOURCE: CODE F894
that means the player cannot access the eeprom to read it's setup data
in other words bad board
you can fix it but its not easy or worth the cost the eeprom is the 25020 chip you would have to soldered a new one on
Posted on Feb 28, 2011
CODE F894
Feb 28, 2011 | Panasonic DVD-A160 DVD Player
Dvd rv32 keeps saying hot and wolnt play dvds
I think you mean the front display shows 'H07' which means the laser/spindle motor assembly (as one part - also known as a traverse unit) has failed. H07 is a common error code with the Panasonic series of DVD playback decks. Because the traverse unit is a multi-operation device, and because the player is a budget model, the repair/replacement of this part to restore your player back to fully functional condition as well as labour costs could prove expensive - hardly worthwhile. It seems Panasonic have been using substandard components within their products for years now, designed to fail just outside their minimum warranty period.
Feb 10, 2011 | Panasonic DVD-RV32 DVD Player
DVD stops spinning displays code H07. Repair procedure?
H07 is the error code for Disk not Spinning. Open the case, open the DVD rack. Put 2 drops of 3-in-1 Oil on a Q-tip and rub the side of the spindle (located under the optical "eye"). Don't drip! Then close the DVD-rack with a DVD in it. Work the DVD in clockwise direction. Hopefully it will start to spin again.
hope this helps
john
Jan 21, 2011 | Panasonic DVD-RV32 DVD Player
My Panasonic dvd-rv32 player (8 years old) functioned perfectly for last 8 years and I cannot get it to PLAY again. I inserted another DVD tonight (actually 3 DVD'S in case the DVD's were defective) and...
Spindle motor/laser assembly is faulty. This part is not repairable - it has to be replaced by an authorised service centre. It may not be economical via this route, since the unit is not a DVD recorder. H07 is an indication of the above issue. Cheaper to buy a new DVD player or recorder than trying to get the faulty one repaired outside warranty.
Jan 19, 2011 | Panasonic DVD-RV32 DVD Player
Error code h07
HELLO
I have just recently posted a cure for this - but here we go again. Fault H07 is the fault code for the spindle/disc motor and to cure it do this!
With the lid of the player removed, locate the spindle and where the motor shaft goes into the motor itself, use a little light oil or WD40. Let it soak in a while and try it again - you should now find it works.
Why this works I just don't know - it just does! (:-)
Sep 09, 2009 | Panasonic DVD-RV32 DVD Player
DVD PROBLEM
Often on Panasonic DVDs, error code H07 indicates that the spindle motor is not turning. The spindle motor is relatively small and expectedly wuld develop hardware problems over time. In some cases, a temporary remedy wold be to clean and lubricate the inside of the motor. Here is my post on similar problems with spindle motors of another electronic device, while here is an illustrated how to.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 09, 2008 | Panasonic DVD-RV32 DVD Player
Hi Maggie
Feb 15, 2008 | Panasonic DVD-A160 DVD Player
Panasonic DVD-RV32
dvd wil not function and screen display f498 i need help
Dec 01, 2007 | Panasonic DVD-RV32 DVD Player
Dvd
I opened it up and sprayed silicone on the center where the disc snaps on. I also sprayed from a side angle to try to aim it towards bearings/works underneath. It worked!
Jan 24, 2007 | Panasonic DVD-RV32 DVD Player
Panasonic DVD-RV32 DVD Player Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
