Question about Evga nForce 680i SLI (122CKNF68) Motherboard
Can't get EVGA 680i mobo to see 2nd BFG 8800 GTS (640mb, not OC) The first card has worked great in PCIE slot 1 for almost 2 years. But when I bridge the 2nd identical card with SLI neither the current BIOS sees it, nor visible in Device Manager - Vista Ultimate (64bit) Am using a Q4 Intel with 8GB of OCZ RAM. It's possible the (used) card arrived DOA, but I have no reason to doubt the eBay seller - and would like to exhaust my testing before we do the whole return thing. Have tested the ? card in the first slot - seems DOA, but want to be sure.
  • 6 more comments
  • johnklapak Dec 16, 2008
    flashed to current BIOS already, and have 750 Watt PCIE-ready PSU. 2nd card draws power (fan spins) but still BIOS says no SLI Memory available, and device manager shows only one BFG
    oops 800 Watt PSU
    where in BIOS? i see red bar across bottom indicating "no SLI memory" or something to that effect
    yep plentyof power
    thx
    but will triple check it
    I think there may be something with the memory - it's OCZ platinum - and I see they have an SLI-Ready line. :(
    I thought that was jsut marketing hoo-ha. and I can't return it.
    GRRRRRR
    Anyone know if memory that isn't labeled SLI-ready can be used for SLI ? or how to trick my BIOS into recognizing it as such.
  • johnklapak Dec 18, 2008
    Yeah, I Found that out when I posted to the OCZ boards. updated all
    nvidia software again and Tried the ? card in slot 1 again, still bad.
    will have to return it... :(
    well it worked fine all through this troubleshooting - but i only was testing it in the first pcie slot.
    however, after taking the ? card out or the last time and putting mine back in - I keep getting error code 25 and no display. tonight i will try re-re-re-reseating my video, experimneting with the DIMMS in different slots, and trying a new PS2 keyboard.
    also his has a glossy label and a sticker that reads BIOS Version 60.80.07.00.01
    Mine is a matte finish and my sticker reads "BIOS Version 60.80.07.00.02
    otherwise identical cards, according to BFG's product sticker..BFGR88640GTSE.
  • 679 Answers
Did you enable it in the BIOS, I have an sli on this machine, you also need power to the second card. Bridge, Power, And enable in Bios, peace
Posted on Dec 16, 2008
  • 1 more comment
  • George Bill
    George Bill Dec 16, 2008
    in bios wher it lists the pcie card, on mine I needed to enable the 2nd card when I added it, PCIE settings, take another look under peripehrols, also check the irq's, it is definetlly a setting that is in need of change
  • George Bill
    George Bill Dec 18, 2008
    No john ram is ram. Mine isn't for sli, and my SLI is working for over a year. The only thing is you want to run the same type in each channel. Ram as well as the video cards will default to the slowest speed component, but it would still work, thanks, Gym
  • George Bill
    I have one more thing to try, will your system function with just the new card in it, scince we know that the old card works, This will tell us weather it is a bad card or an incompatable card, just a thought, this way if that second card is just bad we will know it for sure. Thanks, Gym
Hi I have a supermicro x8sti Server Board inside
Basically you have two choices for installation of video card:
1. To purchase small form factor PCIe card suitable for installation on 1U server chasis or
2. Purchase PCI express riser card and to install most full-sized PCI Express cards (Check this link for PCI Riser )
Oct 04, 2013 | SUPERMICRO COMPUTER Supermicro X8STi-F...
Bfg 8600 GTS OC
While BFG used to have a good warranty, they went out of business in late 2010, which makes a replacement under warranty very unlikely.
If you have another PC you can install and test it in, I would try that. But it does rather sound like a graphics card problem to me. Which means a replacement will most likely be needed.
Luckily, you can get a very decent, if not better, card to replace it for less than $100. I would recommend anything in the Fermi graphics card,either 400 GTS or higher, which I have (with or without rebates) in the $100 range. PNY, Gigabyte, or XFX are all brands I have used, they have at least 3 years warranty on them.
Jan 21, 2012 | BFG Technologies GeForce 8600 GTS OC 256MB...
My cousin recently upgraded his PNY video card, so he gave me his old one. It's a VDCARD, 8800, GTS 640MB PCIE. When I try and install it in my TA760G M2+ (Biostar) motherboard it makes a loud, cringing...
This Graphics card needs a system with at least a 450Watt power supply. As your cousin upgraded to a newer card, we can therefore assume that this card works and the problem lies with your computer. The power supply being the most obvious. I recommend a Cooler Mater Extreme Power Plus 460W or greater.
Dec 23, 2010 | PNY XLR8 GeForce 8800GT 512MB PCI Express...
Video card does not work and PCIe red light remains on
To isolate, put your video card to the other pcie slot then see if it works. Try also to enable the video output of your motherboard either thru HDMI, DVI-D or vga since it is a H57 mobo to check if the motherboard is working properly and will output video ( not using your video card ) . Also reseat your RAMs ( remove and put it back again). If your video card does not work on the 2nd pcie slot after reseating your RAMs then the problem is with your video card and not your motherboard.
Nov 04, 2010 | ASUS P7H57DV EVO Motherboard
Can foxconn g33M02 handle 500watt psu? and what nvidia geforce 8 series will work on my mobo?
Nvidia Geforce 8 is PCI-E Card.
Here are the list. This were all best and good to your MOBO.
bar_specs.jpg Core Clock (MHz) Shader Clock (MHz) Memory Clock (MHz) Memory Amount Memory Interface Memory Bandwidth (GB/sec) Texture Fill Rate (billion/sec) GeForce
8800 Ultra 612 1500 1080 768MB 384-bit 103.7 39.2 GeForce
8800 GTX 575 1350 900 768MB 384-bit 86.4 36.8 GeForce
8800 GTS 500 1200 800 640MB or
320MB 320-bit 64 24 GeForce
8800 GTS 512MB3 650 1625 970 512MB 256-bit 64 41.6 GeForce
8800 GT
600 1500 900 512MB 256-bit 57.6 33.6 GeForce
8800 GS 550 1375 800 384MB 192-bit 38.4 26.4 GeForce
8600 GTS 675 1450 1000 256MB 128-bit 32 10.8 GeForce
8600 GT 540 1190 700 256MB 128-bit 22.4 8.64 GeForce
8500 GT 450 900 400 256MB 128-bit 12.8 3.6 GeForce
8400 GS 450 900 400 256MB 64-bit 6.4 3.6
  • Full support for both Microsoft® DirectX 10 and DirectX 9 for unparalleled levels of graphics realism and performance
  • NVIDIA PureVideo™ HD2 technology provides unsurpassed Blu-ray and HD DVD movie picture quality
  • NVIDIA 8 Series graphics processors are essential for accelerating the best Microsoft® Windows Vista™ experience
Here is the link for more details about GeForce 8 series:
www.yboyandrei.com/geforce8
Hope i help a lot and give some ideas.
If i am helpful, please rate me.
Thank you. Good luck!
Yboyandrei
Aug 18, 2009 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
System not powering up. Orange light coming on on evga 680i
check your hardsik or memory or other wise out your motherborad and download in check card your problem will be ko
im riaz ahmed brohi or email riazbrohi@gmail.com
Jan 27, 2009 | Evga nForce 680i SLI 775 TR...
MSI nForce 680i Refernce board SLI problems
Try first resetting the bios to default, sometimes there is no way to have a video adapter working when you get this kind of problems, I will tell you more.
Dec 12, 2008 | Evga nForce 680i SLI (122CKNF68)...
Video card problem
this is probably a setting in the BIOS-setup you need to change. look within system/miscellaneous configurations for an option that defines which graphics adapter should be used as default. in normal circumstances there should be an auto-detect option...
Sep 03, 2008 | EliteGroup ECS P4M900T-M2 Socket 775...
NO video @ bootup
Are you sure that the memory you have installed is compatible with your motherboard.
It is weired but some memory do not work with certain motherboards, irespective of speed or voltage rating.
Aug 05, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
PCIe 2.0 compatibility
Yes it will work, though a nvidea card may yeild better performance overall in your system.
Feb 12, 2008 | ASUS A8N-SLI Motherboard
Evga nForce 680i SLI (122CKNF68) Motherboard Logo
216 people viewed this question
Top Evga Computers & Internet Experts
Tony
David
David
Larry Rider
Larry Rider
Are you an Evga Computer and Internet Expert? Answer questions, earn points and help others
