Question about ASUS A8N-VM Motherboard
Does My A8N-VM Motherboard support 500GB SATA or SATA II ?
I have A8N-VM Motherboard and AMD Athlon 3200+ Processor with 1GB DDR RAM. I have 250GB IDE HDD and I want to replace it with a 500GB SATA or 500GB SATA II.
Does my Motherboard support it?
  • Sriranga Rao Dec 19, 2008
    Thanks, I vale your advice and now I have both my IDE and SATA HDDs up and running ...at the same time !
  • 68 Answers
Yes, your motherboard features 2x SATA II ports so you can add any sata II hardrive
Posted on Dec 16, 2008
Ms 7050 motherboard drivers download
The makers of the motherboard should have them.
Jun 16, 2013 | HP DX5150 Desktop Computer Off Lease...
My HDD will going to corrupt, so i need to buy one, but i don't know that which HDD is compatible with my AMD Athlon XP 2000 PC. Could any one suiggest that how much maximum capacity HDD Support my PC....
Hard Disk upto 500GB capacity can be added to most of the PCs. As regards compatibility, first you have to check the motherboard for SATA Hard Disk interface as newer hard disks are SATA. Adding the hard disk has nothing to do with the processor. However, motherboard should have the connecting port/ option (such as SATA). Some motherboards support both IDE and SATA devices. Please check the motherboard for SATA Port. You may find the motherboard model/ system model and google a bit for its specification. (You have mentioned AMD Athlon XP 2000, which is the Processor not the motherboard)
If SATA is available on your motherboard, you may add Sata drives of 250-500-750GB drives according to you requirements. Otherwise you have to look for IDE hard Disk.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 24, 2011 | AMD Athlon XP 2000+, 1.67 GHz Retail...
I want to upgrade my RAm from 256 to 1 gb DDR 1 , Dose A7N266-VM Rev -1.05 mother board supports it ?
amd processor? yes you can upgrade it and do not install the 256mb ram together with the 1 gb memory that you want to upgrade, better use the 1GB alone,
Aug 04, 2011 | ASUS A7N266-VM Motherboard
Conflict adding RAM memory
you can deselect from BIOS - CAS LATENCY TIMER to value 2, or better (2,5)
Jun 26, 2009 | AMD Athlon XP 2000+, 1.67 GHz Retail...
Can I transfer data from 250GB IDE HDD to a SATA II 500GB HDD
Yes you can. You may have to go in BIOS or and select your SATA as the first drive to boot off of though, else it might try to boot off the old IDE. But once you're in windows, it will appear as another drive in my computer.
Thanks and please take a moment to rate as fixya.
Dec 16, 2008 | ASUS A8N-VM Motherboard
I have A8N-VM Motherboard and 250GB IDE HDD. Can i connect 500GB SATA II HDD and transfer data from my IDE HDD to SATA II HDD
Assuming you have a Asus A8N-VM CSM GeForce 6150 Motherboard then if you have a SATA cable that works for that or an adapter for the SATA II if it wont fit it should be fine and you can have both in at once. So there would be no need to transfer but if you want you could.
If im not getting this please let me know and I will try to help you more.
Dec 16, 2008 | Computers & Internet
Type of ram
ASUS A8N-SLI Premium Specifications
CPU: Socket 939 for AMD Athlon 64FX / Athlon 64 /Sempron / Athlon 64 X2
Chipset: NVIDIA nForce4 SLI
Front Side Bus: 2000/1600 MT/s
Memory: 4 x DIMM, max. 4GB, DDR 400/333/266, ECC, non-ECC, un-buffered memory, Dual Channel Architecture.
Expansion Slots:
2 x PCI-E x16
- SLI mode: x8, x8
- Default (single VGA): x16, x1
1 * PCI-E x 1/ 1*PCI-E x 4(x2 mode)
3 x PCI
Storage/RAID: nForce4: 4 x SATA 3Gb/s
NVRAID: RAID0, RAID1, RAID0+1 and JOBD span cross SATA and PATA
2 x UltraDMA 133/100
Silicon Image 3114R RAID controller
4x SATA with RAID0, 1, 10, 5
Audio: Realtek ALC850, 8-ch High-Definition Audio CODEC
LAN: nForce4 built-in Gbit MAC with external Marvell PHY MARVELL PCI Gbit LAN controller
or see this site:
http://www.ngohq.com/home.php?page=articles&go=read&arc_id=34
Oct 30, 2008 | ASUS A8N-SLI Premium Motherboard
Change of hard disk from 160 gb ide to 250 gb sata
Hello there.
I checked the specifications on your motherboard from here .
As you can see it does indeed support SATA Hard Drives, as per the page:
SATA Four-Channel Serial ATA supports 4 SATA II devices
Each SATA hard drive uses up 1 of the channels, so you can use a total of 4 SATA drives at once.
Hope this helps.
Jun 16, 2008 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
ASUS A8N-VM Motherboard Logo
253 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
