Question about AudioBahn AWES15P 15" Subwoofer Car Speaker
How bridge the 15" 800 rms speakers audiobahn
I want to brige to 1 channel 2 speakers.
What's the best way if I don't have the owners mamual?
  • 15,935 Answers
Parallel wiring (if your amplifier is 1 ohm mono stable)
All positives together and all negatives together.
If your amplifier is not 1 ohm mono stable you will need a series/parallel which is a little more difficult.
Here is a wiring link.....
http://www.the12volt.com/caraudio/woofer_configurations.asp
Posted on Dec 21, 2008
DUB2502 550w 2-channel a/b mosfet amplifier 1000 watts maual
not 550 watt,,250 x 2 ,,
  • 2-Channel Class-A/B Amplifier
  • RMS Power (4 ohms): 250 watts x 2 chan.
  • RMS Power (2 ohms): 375 watts x 2 chan.
  • Bridged RMS Power: 500 watts x 1 chan.
  • Min. Impedance Unbridged: 2 ohms
  • Min. Impedance Bridged: 4 ohms
  • Brushed Aluminum Chassis
  • Top Mount Controls with Blue Illumination
  • Cooling Fan
  • Chrome DUB Fan Grille
  • Glass Epoxy Circuit Board
  • PWM MOSFET Power Supply
  • THD: 0.02%
  • S/N Ratio: 95 dB
  • Input Sensitivity: 200mV - 4V
  • Frequency Response: 10 Hz - 40 kHz
  • Variable 18 dB/Oct. Hi-Pass / Low-Pass Crossover: 50 - 250 Hz
  • Bass Boost: On/Off 12 dB
  • 4-Way Protecion: Thermal, Short Circuit, Overload, and DC Offset
  • Dimensions: 8-1/4" W x 2-1/8" H x 10-3/4" L
  • Authorized Internet Dealer
Audiobahn DUB2502 2 Channel 250W 2 Class Amplifier at Onlinecarstereo com
http://www.audiobahn.com/index.php/help/tech-support/manuals/category/1-amplifiers
Feb 26, 2014 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
Which amplifier is best suitable for me to use?
This really depends on the setup you intend to create in your vehicle.
The Amplifer (amp) needs to be matched to the speakers you intend to run.
As a rule of thumb, the power of the amp shouldn't exceed the max. power of the speaker (this may damage your speaker). Instead, the amp's RMS output power should be at 75-100% of the speaker's RATED (RMS) input power. NOTE: this must NOT be confused with max power.
Ideally, you want to run each speaker with its own amp channel.
A subwoofer will usually require a hi-power single channel amp, or a 2 channel amp, bridged into 1 (to increase power output required for the sub).
Here are some examples in simpler terms:
1 channel (hi power) amp can run a subwoofer.
2 channel amp can run 2 speakers, or 1 sub (bridged).
4 channel amp can run 4 speakers, or a combination of 2 spkrs + 1 sub (bridged), or perhaps 2 subs (bridged).
Hope this makes sense.
Feb 27, 2013 | Car Audio & Video
What is briged mode
I think you mean bridged.Which it is when you have for example a 2 Channel amp but instead of hooking Ch1's + & - or Ch2's + & - to the terminals on your speaker you would instead hook a + from Ch1 then the - from Ch2 to your speaker. The purpose is to increase the rms wattage being delivered to the speaker. Be sure to check what ohm stable your amp is while bridged though cause if the load is to low the amp will not last long.
Jan 21, 2013 | Kenwood KAC-7204 Car Audio Amplifier
How many watts is my jl audio 2150 amplifier
It depends on whether you have the M2150, A2150, or E2150.
M2150 Class A/B Two-Channel Full-Range Amplifier Specifications:
Rated Power 14.4 V Stereo: 70 W RMS x 2 @ 4 ohm, 110 W RMS x 2 @ 2 ohm
Rated Power 14.4 V Bridged: 140 W RMS x 1 @ 8 ohm, 220 W RMS x 1 @ 4 ohm
Rated Power 12.5 V Stereo: 45W RMS x 2 @ 4 ohm, 75W RMS x 2 @ 2 ohm
Rated Power 12.5 V Bridged: 90W RMS x 1 @ 8 ohm, 150W RMS x 1 @ 4 ohm
THD at Rated Power: 12.5V: <0.08% THD, 20Hz-20kHz, 14.4V: <1% THD, 20Hz-20kHz
S/N Ratio: >104 dB referred to rated power (A-weighted, 20Hz-20kHz noise bandwidth)
Frequency Response: 10 Hz-25 kHz (+0, -1dB)
Damping Factor: >200 @ 4 ohm per ch. / 50 Hz, >100 @ 2 ohm per ch. / 50 Hz
Input Range: 200mV, 8V RMS
E2150 Class A/B Two-Channel Full-Range Amplifier Specifications:
THD at Rated Power: <0.08% @ 4 ohm 20Hz-20kHz
Frequency Response: 10Hz-25kHz (+0, -1dB)
A2150 Class A/B Two-Channel Amplifier Specifications:
Rated Power 12.5 V Bridged: 150W RMS x 1 @ 4 ohm
THD at Rated Power: <1% @ 4 ohm 20Hz-20kHz
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 23, 2011 | Car Audio & Video
How many watts does a audiobahn a1502dp have
  • RMS Power Rating:
    • 150 watts x 2 chan. @ 4 ohms
    • 300 watts x 2 chan. @ 2 ohms
    • 450 watts x 2 chan. @ 1 ohm
    • Bridged, 300 watts x 1 chan. @ 4 ohms
    • Bridged, 600 watts x 1 chan. @ 2 ohms
  • http://www.sonicelectronix.com/item_2304_Audiobahn-A1502DP.html
    Feb 23, 2011 | AudioBahn A1502DP Car Audio Amplifier
    I have a 12 inch audiobahn 550 rms 4 ohm coil ported box and a dual box with 12 inch subs they say 550 max wattas a piece thats it waht amp do i need to get atleast 80% of my power in bass
    Get a 1200 watt 4 channel amp that's 2 ohm stable. Bridge 2 channels into the single 550W rms audiobahn. Use the other channels for each side of the dual box. Turn the LPF or Low Pass Filter on and vibrate down the road.
    Sep 25, 2010 | Car Audio & Video
    I have 2 jvc 6-1/2" 210w max 2-way coaxial speakers and a vr3 stereo speaker system ( 2 6-1/2" woofers & 2 horn tweeters) 300w max that i want to install n my trunk and be able to achieve its full...
    the speakers can handle about 45 watts rms a piece and the vr3 box can probabily handle 100 watts on its best day. your best bet is a 4 channel amp. use the front two channels for the jvc speakers and bridge the rear 2 channels for he vr3 box...keep the gains under 3/4 and tune the hrtz. fereq. to about 80 herts.hih pass filter on for the frot channel and low pass filter onfor the rear channel
    Sep 14, 2010 | Car Audio & Video
    I have a audiobahn a400t and im running 2-12''jh45 mtx jackhammers the speakers are wired in parallel stabel @ 2or1 ohm. the speakers are in a ported box. how do i run my wires to my hook these up right to...
    Hello rattle822,
    A pair of JH4512-04's can be wired to 2 ohms if the subs themselves are paralleled. There's only one voice coil and it's 4 ohm. If wired in series, the final impedance to the amp would be 8 ohms. They cannot be wired to 1 ohm.
    In bridged mode, your 4-channel amp is only stable down to 4 ohms. You can bridge 2 of the channels to provide a relatively low 200 watts RMS X 2. The best power solution for your subs would be to bridge channels 1 and 2 and wire one sub to it. Likewise, bridge channels 3 and 4 and connect the other sub. If you connect both subs in parallel, the impedance will be too low causing the amp to overheat and possible fail.
    As for the settings: Low pass filter on, crossover somewhere between 80-100, input levels to match your receiver, and bass boost to your personal preference.
    Hope this helps.
    Aug 13, 2009 | AudioBahn Car Audio & Video
    550x2 subs....SPL z2x-820 Amp
    The 230 watt amp is a little small for your subs. They'll work, but if you are looking for max SPL, you won't get it. To push those Audiobahn's to their potential pavement shaking max, I would recommend an amp in the range of 500-600 rms (2-channel bridged) or 1000 watts rms monoblock.
    Hope this helps.
    Mar 28, 2009 | SPL Dynamics Z2X-820 Car Audio Amplifier
    Do you have instructions for wiring install on volfenhag GX8200??
    Amplifier Class AB
    Number of Channels 2
    RMS Power (4 ohms) 120 watts x 2 channels
    RMS Power (2 ohms) 200 watts x 2 channels
    RMS Power (1 ohm) Not Stable
    Bridged RMS Power 400 watts x 1 channel
    Total RMS Power Output 400 watts
    Peak Power Output 1000 watts watts x 1 channel
    Minimum Impedance Unbridged 2 ohms
    Minimum Impedance Bridged 4 ohms
    THD at Rated RMS Power 0.1%
    Speaker Level Inputs No
    Preamp Outputs 1 pair
    Built-in Crossover High-pass (HP), Low-pass (LP), Full (AP)
    High-Pass Crossover Frequency 40 - 250 Hz
    Low-Pass Crossover Frequency 40 - 250 Hz
    Subsonic Filter N/A
    Signal-to-Noise Ratio N/A
    Channel Separation N/A
    Bass Boost 0 - 18 dB
    Bass/Gain Remote Yes
    Fan Cooled Yes
    Fuse Rating 20A x 2
    Dec 24, 2008 | Volfenhag ZX-8200 Car Audio Amplifier
    Car Audio & Video Logo
    151 people viewed this question
    Top AudioBahn Car Audio & Video Experts
    Colin Stickland
    Colin Stickland
    Jerry Naidoo
    Robert Rankin
    Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
