Question about Toshiba 2060 Copier
Hello I have a Toshiba 2060 copier that when I turn it on it keeps saying "adding toner" I have replaced toner cartridge twice, I also have checked to see if the gear that turns toner cartridge is broken and if it turns. I am thinking it could be the toner sensor if it has one. Please help me figure out what the problem is; and let me know if I is a part or part number. I thank you so very much.
  • hooper97303 Jan 04, 2008
    my toshiba 2060 keeps saying adding toner
    gear turns
    new toshiba toner cartridge
    how do I adjust toner sensor?
  • 944 Answers
This link would allow you to get the service manual for your copier (if you dont mind paying $10.79) http://www.justmanuals.com/product_info.php?cPath=94&products_id=5317&osCsid=1e2cbd0fe0d1e9b355bf78602f2ce2fc and this link gives you a complete list of the error codes for your copier; http://www.visualhawk.vcc.ro/toshiba_error_codes_en.html It does sound as if the copier could have a fuser or thermistor problem, find a local toshiba copier dealer here; http://www.eid.toshiba.com/cgi-bin/mqlocator?link=find and hopefully they will help - sorry had no luck finding a definite solution Hope this helps, please post again if not :)
Posted on Mar 21, 2007
Ahh. thats problem that i incounterd. check first the toner sensor may be they have a small parts that paste in your sensor.. or if the sensor have already check end u find the sensor is good. the main problem of your machine is the sub main board thats need to be changes
Posted on Oct 07, 2008
  • 4 Answers
Make the auto toner sensor adjustment (05 service mode) and be sure is between specifications 2.41-2.46V
Posted on Oct 01, 2007
  • 163 Answers
Your toner is not original or toner is not going in the developing unit or developer sensor problem name is ATDC sensor
Posted on Sep 14, 2007
DISPLAYING ADD TONER AFTER ADDING NEW TONER
Check your developing gear maybe one already worn out replace one set 5 pieces if not try re-install toner cartridge twice, check sp mode -toner drop or reset. hope this may help you.
Jun 19, 2015 | Ricoh Aficio 1013 All-In-One Laser Printer
Toshiba 2060
i would buy new lazor toner 1st cartridge to see if yoru s bad or out
Jan 19, 2008 | Toshiba 2060 Copier
Toner dumping straight into toner bag
use original toner OR reset toner indication
Sep 12, 2012 | Toshiba 2860 Copier
Our copystar 2030 keeps asking for toner. We just
Can be an ensemble of the reasons:
1. The Silent sensor which checks the concentration of the toner.
2 Check pulled of you film defensive with tubas?
3 During moving the toner track can be broken or littered.
4 Can be a value-added degree to concentrations of the toner in service programme inflexion
5 Can be sensor itself to concentrations
7 Sensors can be littered
8 If it is used developer, can be violated concentration developer to toner
This in a complicated way repairs with words.Sooner whole you should apply to service,forgive, but such fault it is difficult do advice, it is necessary all look the experienced specialist, you may lose much toners and break the track of the presenting the toner, apply to service. Good luck
Oct 07, 2009 | Copystar CS-2030 Copier
Put in second toner and machine is still saying toner empty
If you are using refilled cartridges those errors are common, Samsung has an eeprom on the cartridge keeping track of usage and you need a new chip from the refillers. If you are using OEM cartridges you need to clean the contacts inside the machine that the cartridge connects to and wipe the contacts on the cartridge before installing, Otherwise a shop repair for the CRUM circuits.
Sep 11, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Empty old toner
Open front cover of your 2060. Inside the copier, on the left side, there is a blue lever labeled "A". Press lever "A" towards the left while pushing down on the top of copier....this will unlatch the **** shell and allow the upper portion to lift upward. The waste (used) toner container is located in the center of front frame (semi-clear plastic). Lift upward on container until it clears the frame, CAREFULLY pour the contents into a plastic lined trash can. Replacement is reverse of removal.
Jun 05, 2009 | Toshiba 2060 Copier
How to change a toshiba bd-4560 toner cartridge
Look and see if part of the old toner cartridge is still in the machine.Compare the new and old cartridge and see if the shutter has come off the old cartridge.
Feb 28, 2009 | Toshiba 2060 Copier
Just wanna know
It is not terribly difficult, but you MUST use the correct toner to avoid all kinds of problems
Feb 09, 2009 | Toshiba 2060 Copier
Toshiba 2060
bota la botella que esta jenna de toner cuando avre la puerta y ponle una nueva
Sep 23, 2008 | Toshiba 2060 Copier
462 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
