Question about Epson Stylus C62 InkJet Printer
Carriage won't move over to install new innk cartridge
The red and green light is blinking. This is usually a standard procedure, this time won't work.
  • ndm247 Dec 27, 2008
    C62 red and green lights blinking. . . . . I took the printer apart, but did not find anything obviously wrong. When open the cartridges can be changed; which I did. The same problem remained.
    I cant help feel that the problem is either a faulty censor or the ink tray is full. Note also, this printer is under used, about 3/4 prints per month.
    Hope it helps
  • 353 Answers
Both green and red flashing together usually means the waste ink pads need replacing. This is a printer dismantle job, which is very difficult unless you know what you are doing. Sell it on E-Bay for what you can get!
Posted on Jan 31, 2009
  • Gerry Millward
    Gerry Millward Jan 31, 2009
    Oh - I should have said that you can download the SSC utility herehttp://www.ssclg.com/epsone.shtml which you can use to reset the waste ink pad protection counter. After that, your printer will work. But do remember, it's full of waste ink - don't tip it up or you may have ink all over the place.
  • 3 Answers
Personally. my carriage move (ink maintenance button) stopped working within the first month...i have this printer for almost 6 years now, I just manually move the carriage over by hand
Posted on Jan 27, 2009
Error 5100 what do i do???
Error 5100 points to a "carriage jam"
The carriage is the assembly that contains the print head and cartridges.
This error can be difficult to solve because various things can cause it.
Since this is a new printer, maybe there is some packing or packing tape that is obstructing the carriage.
Verify that the carts and print head are installed properly.
Check the gears as best you can for any obstructions.
If the carriage moves to a center position when you open the cover as if to change cartridges, try a reset to clear the error message :
1. Turn off printer (use button, don't unplug)
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal
Sometimes you have to try this a couple of times, if you've n
Sep 08, 2011 | Office Equipment & Supplies
Epson R2400 paper and ink lights blinking red. Ink waste pad replaced and counter reset to 0. Lights still blinking red. Close inspection for any loose objects in printer but none found. Please advise....
Try to turn on your printer without the ink cartridges. When the printer starts and ask for the cartridges, put them back in.
(To remove the cartridges turn on the printer, watch the print head carriage move, when it is at the center quickly unplug the power cable, move the carriage by hand to a position where you can remove the cartridges, after removing the cartridges push the carriage to the right where it should be parked.)
Sep 02, 2010 | Epson Stylus Photo R2400 InkJet Printer
Red and green lights are flashing alternatively and colour ink cartridge has run out. How do i change the cartridge?
Flashing alternately mean waste pad full. Reset using SSC utility or Adjusment program/resetter. But, you must replace cartridge before. Turn off printer, unlock carriage lock (left side of carriage at parking position). Move carriage by hand to replacement position. Replace ink tank. Reset using the resetter.
May 21, 2010 | Epson Stylus C46 InkJet Printer
Ink red light on . which colour is out?
When red ink light flashes - one or more ink cartridges is low. When you print, a message on your screen will tell you which one(s).
When red ink light remains on - one or more ink cartridges is empty. When you try to print, a message on your screen will tell you which one(s).
Furthermore: When following the procedure for installing a new cartridge, if the red ink light was on or flashing, pressing the ink button will cause the carriage to stop with the cartridge that needs replacing under the "ink out mark" (ink droplet with a slash through it).
Jan 08, 2010 | Epson Stylus C66 Inkjet Printer
The red light on left is blinking. What does that indicate? I have a deskjet 904C. There are three light The left one is blinking, the middle is okay and the right is the green one, that shows me the...
Hi:
If you open the door on the top of the printer, while it is powered on, the ink cartridges will move to a spot that shows you the status of your ink.. There are little cartoon pictures of the cartridges with smiles or frowns to tell you if you have an empty color or black cartridge.
Nov 04, 2009 | HP DeskJet 940c InkJet Printer
Epson C60 - The green power light and middle red error light
-reseat the new cart
-clean the contacts (cart and carriage)
-try a new cart
Sep 04, 2009 | Epson Stylus C60 InkJet Printer
Error Message 22, but can't reset it.
First make sure there isn't any thing keeping the carriage from moving freely, the reset as follows:
How to clear Error Code Canon printers MP150 MP160
CANNON Printers MP150/MP160 ERROR CODE
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 16, 2008 | Canon PIXMA MP150 All-In-One InkJet...
No response
If you´re pressing the ink button and the carriage still does not moves is cause the level of the ink is low, but it does not finished yet. You must use the printer more, then the red light will stop to blink and hold on, then you´ll be able to change the cartridge.
Apr 19, 2008 | Epson Stylus C60 InkJet Printer
Error code E5
hi dear
hi dear
may the error code or how many blinking can solve your problem
this is the list of error code
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
full
Direct Printing
E22 Carriage error
E29 EEPROM error
try this methode
Methode 1
service mode. (Waiting formenu selection)
button pressing
procedures below.
procedures below.
that's all
maybe it can fix your problem
thanks
cropp
Mar 27, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Orange cartridge light error keeps on blinking!
clean the carriage home
check the data cable for the carriage home
check the media sensor on the left of the plotter media bar
Mar 12, 2008 | HP DesignJet 450c InkJet Printer
Epson Stylus C62 InkJet Printer Logo
252 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
