Question about Breezaire WKE 6000 Wine Cooler
How do I add R-134a refrigerant to a Breezaire 1060?
Is there a guide available showing me how to add more refrigerant (R-134a) to a Breezaire 1060EM housed in a wine cooler/cabinet (assuming this can be done by a careful novice)? What type of special screwdriver would be required? Where do I pour? ...
3 Suggested Answers
  • 25 Answers
SOURCE: breezaire wkce 1060 does not cool my wine cabinet
I'm not familiar with your unit, but sounds like condenser problems. Check for a dirty coil on the backside or underneath the unit. Also, if it has a fan for that coil, make sure it's running when the compressor is running and that the blades are clean. Other than that, it could have developed a refrigerant leak.
Posted on Sep 15, 2009
WCISERVICE
  • 50 Answers
SOURCE: What refrigerant is use for BreeZaire wkr 1060 and
A WKR 1060 SHOULD BE AN R-22 REFRIGERANT UNIT AND IT SHOULD STATE SO ON THE UNITS TAG ON BACK OF THE UNIT.
I IT IS IN FACT AN R-22 MODEL 1060 IT USES 9oz OF R-22
IF IT IS AN R-134A IT USES 10 oz
Posted on Sep 16, 2011
Breezaire wke 3000. What kind of refrigerant does it take and how much do I put in?
Refrigerant for homes is not like cars. Only licensed HVAC tech can add refrigerant in a home unit.
Aug 15, 2015 | Heating & Cooling
Breezaaire error code
WKC 1060 ARE NON DIGITAL AND CAN NOT DISPLAY CODES,YOUR UNIT PROBABLY IS A WKCE 1060 DIGITAL UNIT IF SO PLEASE CLARIFY WHAT IS THE ERROR CODE ON IT?
Sep 15, 2012 | Breezaire WKC1060 Wine Cellar Cooling Unit
II started up my 1060 two days ago. The fanis working properly but Idon't get any cold asir. A service person rechareged the coolan but still no cold air. I have unplugged it for the time being
The service person shouldn't be recharging the refrigerant unless they have found and repaired a leak. Or do you mean an antifreeze solution that is pumped round the system? If so the service person should have checked the cooling system was working before adding coolant.
Jun 16, 2012 | Breezaire WKC1060 Wine Cellar Cooling Unit
How many ounces of r22 does a WKCE 1060 hold at full charge?
A WKCE UNIT SHOULD BE AN R-134A SYSTEM NOT AN R-22 IF IT IS A R-22 IT SHOULD SAY SO ON THE TAG ON THE BACK OF THE UNIT NEXT TO THE CONDENSER COIL(BEHIND THE WHITE GRILL) IF IT IS AN R-22 IT SHOULD BE A MECHANICAL THERMOSTAT UNIT (SCREW ADJUSTMENT ABOVE THE FRONT BROWN GRILL)
IF R-22 MODEL 2200 13 OZ
IF R-134A MODEL 2200 10 OZ
MANUFACTURER CAN PROVIDE INFO ALLSO AS LONG AS YOU PROVIDE THEM WITH MODEL AND SERIAL NUMBER OF THE UNIT 858-566-7473
Aug 27, 2011 | Breezaire WKCE 2200 Wine Cooler
I am trying to recharge my Breezaire WK8000 cellar unit (which Breezaire said could be done), but the unit has Rivits at all corners. How do you get to the compressor to recharge this unit?
DRILL RIVETS OF WITH A 1/8 DRILL BIT AND ADD AN ACCES VALVE.
UNIT SHOULD NOT BE RECHARGED WITH OUT PRESSURE TESTING UNIT AND FINDING THE LEAK FIRST, OTHERWISE THE FREON WILL SCAPE AGAIN
Apr 30, 2011 | Breezaire WKE8000 Wine Cellar Cooling Unit
Dec 02, 2010 | Breezaire WKCE 2200 Wine Cooler
Can you advise what type and amount of refrigerant is in Breezeaire 6000 wine cooler?
TYPE OF THE REFRIGERANT IS LOCATED ON THE TAG ON THE BACK OF THE UNIT IT COULD BE AND R-22 OR AN R-134A
AND IT USES 22 oz OF REFRIGERANT WHAT EVER THE TYPE THE UNIT IS.
Nov 26, 2010 | Breezaire WKE 6000 Wine Cooler
Breezaire wkce 1060 does not cool my wine cabinet adequately unit worked OK (but not great when new). Now the unit is 4 years old and will not cool the cabinet more than 11 degrees below room...
Sep 14, 2009 | Breezaire Refrigerators
AC STOPPED BLOWING COLD; ONLY BLOWS ON MAX MANUAL SETTING
Your AC is low on refrigerant; The AC compressor needs a minimum amount of regrigerant to run. If and when it does run (while low on refrigerant) the air coming out of the vents will not be cold. The refrigerant you require is R-134A and is available over the counter but if you are the least bit unsure as to how to add refrigerant, taking it to a garage that does AC recharging would be your best play. If you want to try to add refrigerant on your own you will need the following, 1LB can of R-134A, an AC hose adapter to deliver the refrigerant, and preferably an AC pressure guage to ensure you are not overfilling the AC line which will damage the system.
May 10, 2009 | 2004 Honda Odyssey
Breezaire WKE 6000 Wine Cooler Logo
206 people viewed this question
Top Breezaire Refrigerators Experts
mike cooper
maniman
Are you a Breezaire Refrigerator Expert? Answer questions, earn points and help others
