Question about Paragon JW-30-00 Percent Cycle Timer
My timer won't cycle the motor on and off.
Paragon model jw30-00
Micro switch works fine.
Motor run continually when the timer is set on "15".
Motor shuts off if micro switch is manually tripped.
Gears are not moving within the timer.
Need manual and operations/troubleshooting resource.
  • 52 Answers
You may need trippers
Posted on Feb 26, 2010
Want to know how to install a d frost o matic model 8145
1) Copy following links for defrost timer resources, explanation, manual, general description and illustrations:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#defrost
http://waterheatertimer.org/images/8145-20-wiring-600.jpg
2) Generally:
Power wires connect to terminals 1 and N.
Heater turns ON during defrost cycle, so heater connects to NO terminal 3, and to terminal N
Refrigeration fan motor is OFF during defrost cycle, and ON during refrigeration cycle, so it connects to terminal 4, and to terminal N.
Limit switch, which is the pressure or temperature sensor, connects to to terminal X and to terminal N. When defrost cycle pressure or temperature reaches set point, the limit switch activates, and this causes 8145 timer to reset, and then defrost cycle ends.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jan 30, 2013 | Hardware & Accessories
I have a Paragon 8145-20 D-Frost-O Matic installed in on my walk-in freezer. The ice is accumulated on the fins of the freezer. Now it run for 11 minutes then stop for 3.5 minutes. I think the stop time...
1) Copy following links:
http://waterheatertimer.org/images/8145-work-image.jpg
2) Typically the 8145-20 defrost cycle is time-initiated and starts when tripper pin located on outer part of dial passes the time-of-day point.
Defrost cycle terminates or ends when pressure or temperature switch activates. This is also called the cycle limit switch.
3) So your situation sounds like the pressure or temperature switch is not working correctly.
4) The 8145 timer also has 'time termination' setting. This red tripper is located on inner part of dial.
Usually the 'time termination' is used as back-up system if the pressure or temperature switch fails so that defrost cycle will not continue melting everything in freezer.
5) To solve problem until pressure-temperature switch is replaced, you can disconnect wire on terminal X, and then set 'time termination' for correct length of time by experimenting.
Dec 27, 2012 | Paragon 8145-20 Defrost Timer
Timer not working on 4000 series, think its 4014 single pole single switch for pool pump. pump turns on when manually turn switch on but timer does not move. I feel the normal resistance and can move the...
1) If circuit breaker is not tripped or shorted, then timer clock motor has probably gone bad.
2) Some places still sell paragon timers, depending on model number.
But model number given is for 240Volt timer.
3) The clock motor is not available that I can find.
Paragon is no longer making the 4000 series timers or parts
http://waterheatertimer.org/Paragon-timers-and-manuals.html#4000
4) Model number given does not match wiring terminals shown in manual.
4014 is DPST 240Volt timer with 4 wiring terminals labeled 1 2 3 4.
http://waterheatertimer.org/pdf/Paragon-4000-series.pdf
5) Paragon 4000 series timer with terminals 1 2 3 is 120Volt timer.
6) Replace 120Volt timer with Intermatic T101 indoor timer or T101R outdoor timer.
Crossover wiring:
Paragon terminal 1 goes to Intermatic terminal 1
Paragon terminal 2 goes to Intermatic terminal 2
Paragon terminals 3 goes to Intermatic terminal A
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
7) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 29, 2011 | Paragon 4001-00 24-hr Timer Control 120v...
My Maytag washer Model:LAT6800AA won't run after it fill cycle. I replace the fill level pressure switch because mit would not stop filling no matter what setting the fill switch was in, now it fills...
Is your model number correct? Or is this the LAT8600AA? (typo?)
This wiring diagram is typical of most every LAT model as far as the water fill & agitation circuits:
http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=28437491&pkw_=basket&model_id=26594&NewWindow=1
Can you select spin and have the maching spin?
Here is how to test the motor:
You can sacrifice an extension cord to build this test harness.
The direct connections for a motor run test involves making a test cord. The test cord will have 4 connections (2Y connections) I.e. each of the power / cord wires is split off to 2 terminal on each wire. This will run the motor. Reversing the motor is done by switching wires B and C
If the motor runs during this test. it is sure looking like the timer is bad.
If you can not see the end of the D wire it Connects where the BLACK wire was.
All wiring harness wires from the machine have to be removed for the test. Draw your own diagram for the wires you removed!!!!!!
Kelly
Jul 29, 2011 | Washing Machines
My Paragon jw30 timer runs continuosly no matter what setting. Is there a fix?
1) There are no repair parts for JW series percent cycle timers.
Paragon is no longer making parts or timers, except defrost timers. JW is no defrost timer.
Open link below for copy of manual and help identify model number
http://waterheatertimer.org/Paragon-timers-and-manuals.html#JW
2) The JW is still being sold, so somebody must be making it.
Google search: JW cycle timers
3) A cycle timer is meant to cycle continuously, and the percentage on-off repeats over and over without stopping.
If you want to override timer, you can add a switch or another timer on electric line either before or after cycle timer.
This way you can control what hours the cycle program operates.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on timer or any do-it-yourself project.
Feb 24, 2011 | Paragon JW-30-00 Percent Cycle Timer
The micro switch is bad and i need a new one...where can this be purchased?
1) Paragon is no longer making timers and parts except defrost timers.
You posted under JW-30-00 series cycle timer, which is not a defrost timer.
2) JW timers are still sold on internet. Some Paragon timers are still being sold, and other manufacturers will continue making various Paragon products under new names.
3) Intermatic cross reference shows CT1000 is replacement for JW-30-20
http://www.intermatic.com/customer%20service/competitive%20cross%20reference.aspx
http://www.intermatic.com/~/media/files/intermatic/products/sell%20sheets/time%20switches/ct1000%20sell%20sheet.ashx
4) Tork makes the ACT series cycle timer
http://waterheatertimer.org/Tork-timers-and-manuals.html#cycle
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Feb 11, 2011 | Paragon JW-30-00 Percent Cycle Timer
I need to purchase 6 (six) more sets, 1 on and 1 off, trippers for the churches' 7 day timer. Do you need to know voltage of motor? The voltage it is switching is 240 volt.
1) You posted under paragon 7008-00 timer.
It is not necessary to know voltage of motor to order tripper
2) Model number of timer is usually located on inside door panel
3) Paragon is no longer making timers or parts.
Open following link to identify timer for sure:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#7000
http://waterheatertimer.org/Boxtype.html
4) Following link from Paragon gives links for folks who might still sell parts:
Expect some suppliers to overcharge for parts.
I've seen paragon trippers selling for $60.
http://portalgb.knowledgebase.net/display/1/index.aspx?c=15121&cpc=XobrEdQ5Lsnv624T2PBS4Exx6S5VyiL7gw3am4YYt6&cid=13013&cat=&catURL=&r=0.485034763813019
5) It might be easier to buy another time clock.
Refer to Intermatic Competitive cross reference chart.
For example replacement for 7008-20 is Intermatic T7802B which is a 7-day, 40 amp 240V timer.
http://www.intermatic.com/products/timers/mechanical%20time%20switches/7%20day%2040%20amp.aspx
6) You are working for your church, probably as a volunteer.
I also volunteer several places in my community.
I have extensive files on timers and can help you choose and install a new timer if I know the model number.
Just add a comment to this post and I will answer if needed.
Feb 07, 2011 | Paragon Amf 7008-00 Timer 7 Day 120 Volt...
AMF Model No. 7008-00 How do I know if it is working or not. Where can I get more Pins to stop the bld everyday at 5pm.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Paragon 7008-00 timer parts:
http://www.paragontimecontrols.com/parts_accessories.htm
http://www10.shopping.com/-paragon+timer+trippers
Paragon mechanical 7008-00 has 120V clock motor
-8 poles control 1-4 separate 120V loads, with 2 NO Normally Open and 2 NC Normally Closed circuits with max 690 Watts per pole.
Test 120V clock motor:
-Clock motor connects to two far right terminals. Black hot to pole M, White neutral to pole T.
-You should be able to hear clock motor running by putting ear against outside case.
-Clock motor will rotate wheel, if wheel is not rotating, then motor is not running.
Sep 21, 2010 | Paragon Amf 7008-00 Timer 7 Day 120 Volt...
On a Paragon 8145-20 Defrost Timer, I know you land the refrigeration circuit on terminal 4, the heater on terminal 3, but what goes on terminal "X" and terminal "N"
Link below has 8145-20 wiring diagram:
Terminal N is 2nd wire needed to complete circuit.
In 240V 8145-20, there are two hot wires.
One Hot connects to terminal 1, with jumper to terminal 2.
Second Hot connects to terminal N, and this will power the clock motor and timer.
Terminal X is for temperature or pressure termination switch.
Defrost cycle works like this:
Timer is running but switched OFF.
Refrigeration fan is ON.
Timer switches ON, defrost cycle begins.
Refrigeration fan turns OFF.
Hot gas defrost turns ON.
When temperature-or-pressure limit switch reaches trip point, it switches timer OFF.
Refrigeration fan turns ON again.
Hot gas defrost turns OFF.
Aug 01, 2010 | Paragon 8145-20 Defrost Timer
I have an older Maytag model #WU482. For some reason it will not drain and will only run using the economy mode. I can hear the timer ticking at all other cycles and it does click between cycles. I...
First,inspect the drain float. Make sure it rides on the micro switch correctly or it will not take on water.Check the float micro switch for continuity. Check for power at the water valve when it calls for water. Remove the wire harness from the timer and re-install it. Make sure you get a good tight fit,they can become loose over years of use. If that does not correct the problem I would suspect a bad timer.
Sep 29, 2009 | Maytag 24 in. PDB1420 Built-in Dishwasher
Paragon JW-30-00 Percent Cycle Timer Logo
316 people viewed this question
Top Paragon Hardware & Accessories Experts
Gene Haynes
Steve
Are you a Paragon Hardware and Accessory Expert? Answer questions, earn points and help others
