I just bought a foreclosure house that I'm slowly getting up to livable. I have a GE dishwasher model # GSD4020Y73BB Profile. It runs properly till about half-way through it's cycle, then the solenoid clicks and does whatever it does, and leaks from somewhere on or adjacent to the solenoid. From what I can see, the leak comes out right around where the plastic lever gismo sits. Does the solenoid have gaskets or something I can tighten or replace, or do i need a new solenoid? Is this something I can do? I am above average "handy". I saw a similiar part online for around 30$.
So far so good, there was not much gunk in there, but taking it apart and cleaning and putting back together seems to have worked.So far so good, there was not much gunk in there, but taking it apart and cleaning and putting back together seems to have worked.
You can't post conmments that contain an email address.
Good evening... The entire assembly (motor/pump/solenoid) is a part # WD26X10013 and is not difficult to replace. These units tend to leak between the motor and the pump seal. Your leak may just be the shaft for the flapper that the solenoid is connected to. You can purchase a seal kit but the repairs may not last. The entire assembly should cost you around $75.00 and for that amount you have an entire new motor and pump. And the machine should last a long time...
Usually in a dishwasher solenoid there is usually a few gaskets and if the dishwasher is old, used and abused id say it's time to replace the gaskets and even the solenoid itself if it is clicking.
The flap in the solenoid is not closing all the way, get the crapola out of it so that the flap can colse all the way. Simple. This machines motor only turns in one direction. In wash mode it tosses tons of water on the dishes . when the timer gets around to the dump mode that solenoid flap comes open and the water is slung out to the drain hose, Stuff gets in the flap and stops it from closing back.
HI,
If you're just looking at the machine the problem is not going to be fixed..
and now the question: in witch cycle is leaking?
fill, wash or rinse?
can be...for fill...one hose from filling is broken.
for wash...mechanical seal from wash motor, the plastic manifold,one gasket.
rinse..manifold or hose for the rinse...rinse pump..
for drain..solenoid for drain, the hose for drain..
Anyway you must open the machine first of all and see.
it is possible that the plastic has developed a crack at the end of the threaded section
if you are handy with tools , turn the water off and remove that assembly( turn the power off at the plug)
check with a service agent spares department first as that part may not be available because of the age
A clog in the drain line or air gap (if there is one) is the usual
reason that a dishwasher won't drain. Often the problem is at the point
where the drain line attaches to the garbage disposer or household
drain line. If you remove this line, you can clear any debris from the
hose or hose connection. Be sure to reattach the hose before starting
the dishwasher again.
Many dishwashers use a drain valve with an
electric solenoid. When electricity flows to the solenoid, the valve
opens and diverts the water to the drain. Sometimes the solenoid, or
the diverting lever, sticks and prevents the dishwasher from draining
or filling properly. Try to free up the solenoid to lubricate the
lever. Otherwise, you may have to replace the solenoid or pump
assembly. With these systems, the motor always rotates in one
direction. When it's energized, the drain valve diverts the water.
Other
dishwashers simply reverse the direction of the motor to drain the
dishwasher. These units don't have a drain valve. Instead, there's a
drain hose connected directly to the pump housing.
the load limit switch under the tub!! is bad that controls the fill level! and if its stuck closed the machine will do that its under the machine on the bottom of the tub
1. Air gap / Drain hoses If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer Replace if defective (note: uncommon problem).
If this model doesn't have a drain solenoid to inspect(uncommon), this will lead to a control issue with the main control board or timer module. replace if found to be defective.
remember, the drain command is initiated by the control.once the command is issued, the pump will carry out the actions of draining the unit. if the control is faulty, it will not issue the command properly.
If this convert-able dishwasher is permanently installed, you will have to take off the lower access panel to get to the pump area. If it is still in a portable configuration, it may be easier to lay the dishwasher on it's back or side to do this. Now, examine the pump / motor assembly. There is not a separate water pump on this model. There is a diverter pump out solenoid which get's pulled down to direct the water out the drain hose for pump out, which is suppose to spring back out of the way to allow water to go up to the spray arms for washing. I suspect that the solenoid got to hot and the plunger will no longer slide in the solenoid. If this is the case, you can replace it with a WD21X802. If the arm and plunger move freely, check the spring, or for obstructions in the pump housing, or possibly the diverter arm in the pump housing has come loose from the shaft. The solenoid is the most likely.
This is a typical GE problem which I have seen many times...When a DW sets for a while not being used...the motor often freezes up....Take the front (lower panel off....find the motor assembly...(with the DW unplugged!!...very important)reach in with you hand or a screw driver...preferably your hand...at the back of the motor...there should be a impeller blade...you should be able to reach in with a finger and pull it down..it may be resistant so find a way to hold it in place as you reach up to the next impller blade and pull down further...finally it will all of a sudden free up....after which you plug it back in and start it up...I am also including a step by step (no drain problem check list as you may run into an issue like this if it has not been operated for a while ....notice article # 5).
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
I hope this helps...it is always useful to include the Model #...more specific instructions can then be provided
Good Luck and good day.....please rate my effort...the Fang
