Question about Electrolux Cucina Pro 1711 10-Cup Coffee Maker
I have the cucina pro double brew coffee maker and have a broken carafe....how do I get a replacement carafe?
  • zimmermibig Jan 31, 2009
    same problem, can't find a replacement carafe
  • brendah1972 Feb 17, 2009
    Any luck in finding a replacement craft?
I have found a temporary solution! Mr.Coffee Replacement Decanter model # ECD13 will work if you take your old over and use it with this decanter. The lid that comes with the Mr Coffee is just a hair to short but the lid from the broken craft will work well with it. Just hold on to it when you poor your coffee. I hope this helps.
Posted on Feb 26, 2009
I have a Cuisinart DOC-4000 Coffee on Demand Coffee Maker. it no longer brews will not pump the water from the resivor tank to brew the coffee.
Fixing appliances is a dying art, and parts can be hard to get. Buy a new cheaper coffee pot. We've broken so many carafes that we won't pay more than $12 or so for a new coffeemaker.
Dec 22, 2014 | Cuisinart Coffee Makers & Espresso...
How to clean the kitchenaid java express coffee maker
The Coffee Maker can be descaled using
a packaged descaling agent or vinegar.
Always mix the descaling solution using
cool water.
• When using a descaling agent, follow
the directions on the package for the
recommended amounts of descaling
agent and water to use.
• When using vinegar, fill the carafe with
a solution consisting of 1⁄2 vinegar and
1⁄2 water.
Descaling Steps:
1. Before descaling, always remove the
water filter (see “Installing the Ion-
Exchange Water Filter” on page 7) and
make sure the brew basket contains
no coffee or coffee filters.
2. Run the Coffee Maker through a
complete brewing cycle using a full
carafe of the descaling solution.
3. If the cleaning needed indicator lights
after the brewing cycle is complete,
repeat Step 2 using fresh descaling
solution. Keep repeating Step 2 until
the cleaning needed indicator no
longer lights after brewing.
4. Rinse the Coffee Maker by running
it through two brewing cycles using a
full carafe of fresh, cool water
each time.
5. Wash the brew basket in hot, soapy
water and rinse with hot water. This
part can also be washed in the upper
rack of the dishwasher.
6. Reinstall or replace the water filter.
Replace the filter every three months
under normal usage, or more often
with heavy use.
Mar 30, 2009 | KitchenAid JAVASTUDIO KCM534 14-Cup Coffee...
Coffee overflowing and spilling out of the basket
Your coffee maker likely has the option where you can remove the carafe while it is brewing so that you can serve yourself in the middle of the brew. When you pull out the carafe in the middle of the brew, a small lever closes off the drip at the end of the basket (to keep the coffee from flowing onto the empty space where the carafe was on onto the burner).
Then when you replace the carafe, the lip of the carafe pushes against that lever and re-opens the valve so that the brew can now drip into the replaced carafe. Simple.
In your case, it appears that when you place the carafe onto the burner plate, it is not engaging that lever and opening up the valve; hence the valve stays closed and the brew fills over the basket and makes a mess, right?
So do this, pull out the carafe and look up where the pointed end of the basket drips into the carafe. You should see a lever, or plate that the carafe top lip hits when the carafe is placed into the burner plate. Once you find that lever, or plate, give it a push (like the carafe would) and see if it moves. if it does not, then that's your problem. It is stuck closed and won't allow the brew to exit the basket into the carafe. Clean it thoroughly if it is stuck and then see if works.
Mar 29, 2009 | Coffee Makers & Espresso Machines
I have a waring pro 12 cup coffee maker but no manuel.
Most of them will make any amount of water you put in.But I would remen 2 to 4 cups.
Mar 13, 2009 | Waring Pro WC1000 Coffee Maker
Broken Krups FMF5-14 Stainless Steel 10-Cup Coffee Maker?
My Krups was not working after I accidentally forgot to place the black plastic lid on the coffee carafe BEFORE starting to brew a new batch of coffee. The coffee will not drip into the carafe without the lid
in place. Because the lid is hidden when placed in the coffee maker, it's easy to forget! The coffee all backed up in the filter area and overflowed. The display got wet. Not good.....
If your buttons and or display is not working ( mine got wet with coffee) simply flip the coffee maker over. Unscrew the bottom. expose the display circuit board carefully, DRY it with a HAIR DRYER and put the unit back together! Presto! Mine is working again.
If you need a new circuit board, you can get one for $35 from Appliances.com I found. They also have the Duo filter and extra parts cheaper than the Krups website.
Feb 22, 2009 | Krups FMF5-14 Stainless Steel 10-Cup...
Cucina pro double coffee maker
i have the extra carafe, i need one too but cant find one, so you can have mine.
respond to elizabethstacey@comcast.net
Dec 16, 2008 | Coffee Makers & Espresso Machines
Brand new, first run, leaking?
You must have the carafe lid ON. The reason is the lid has a dome on top that pushes up to let the brewed coffee come down. With the pot off look in there with a flashlight....you'll see that the 1 inch dome pushes up on the spring loaded stem.
You MUST have the lid in place or the brewed coffee won't drain into the pot.
Aug 21, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Waring Pro WC1000: Pour over 12 cup coffee maker
Waring Pro WC1000 coffee maker replacement carafe is Waring WC1000CRF glass replacement coffee pot. Black lid and black handle.
http://www.bestreplacementpart.com/waring-pro-wc1000-replacement-carafe/
Feb 20, 2008 | Waring Pro WC1000 Coffee Maker
Electrolux Cucina Pro 1711 10-Cup Coffee Maker Logo
209 people viewed this question
Top Electrolux Coffee Makers & Espresso Machines Experts
Steve Allison
Steve Allison
Marvin
Marvin
Kolbrun...
Are you an Electrolux Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
