Cannot get DVD recorder DVD 3470H to download from hard drive to a disc. The machine is about a year old and I'm using recordable DVD-R When I try to record onto the disc I get a screen which says the recorder cannot play the DVD untilthe disc has been finalized but it wont let mew do this either.It simply opens the disc drawer and so it goes on round and round
Hi Guys,
Thanks for the response.
I've solved the problem.
I was trying to download a programme that was too big from the hard drive to the disc.Once I inserted a divide in the progeamme everything worked Ok,
Cheers,
Posted on Dec 20, 2008
I have two SONY RDR-HX750 DVD Recorders that I haven't used for a couple years (I've been using my TOSHIBA and MAGNAVOX DVD Recorders with Hard Disk Drives instead). Now when I try to play a DVD or play a...
have you tried resetting both machines, also if they where stored somewhere cool and then brought into a warmer area it may just be condensation, if this is the case leve the machine to acclimatise for an hour first.
To reset power up and remove all discs, then press and hold the Stop button on the machine and then press the power button, the unit will power off and will be reset to factory default.
Dec 06, 2013 | Sony RDR-HX520 DVD Recorder
How can I show my DVD-R(Memorex) on my televison?
I assume you mean that your current DVD player won't play this DVD?
There are 3 reasons that it won't play. One that the disc is faulty and therefore won't play on any machine. Two that the disc has a scratch or has marks on it. You can look at ways to clean the disc on-line!
3 That it was not finalised on the machine that it was recorded on. If you current player is a + machine it won't play the disc if it is unfinalised. You will need to use the old machine to finalise the disc or another "-" disc recorder to do it - if it will accept the disc! Otherwise if the old DVD recorder is no longer with you, then your only hope to save the disc is to find another model of your old recorder to do it on. If it was a common model someone might let you finalise the disc!
Feb 21, 2013 | Panasonic Original Pansonic Tv Vcr Dvd...
My Toshiba DVD recorder is not formatting my discs (disc error c310). I am using the same discs I have been using for 5 years. Nothing has changed. Any help would be appreciated. Thank you!
Have you tried a new disc? have you tried your 5 year old disc's in an other recorder? you have to know that re-writable discs have a life... 5 years (I'd say the best is out of them) and so is a DVD recorder, the laser get weeker with time thus making the system harder to record, i've seen some system so old that they could ownly record on a new disc but could not erase/format them after they've been recorded on...
Dec 30, 2010 | Toshiba Televison & Video
DVD recorder not recording any more
I have found that you get what you pay for in electronics. I bouoght a Cyber Home recorder, it lasted about 15 months before it went out.
I had another off brand ( don't remember name) that also didn't last. I have an older, I think it's a Panasonic, at least 5-6 years old. It won't reord on DVD+R, only on DVD/RW discs.
So, first I say you bought ****.
Buy name brand only it lasts longer.
Second, these things don't last to long.
I have a player only that is 5 + years old that still plays movies.
I haven't used the Panasonic for about a year. I do use it to PLAY movies still.
Jan 04, 2010 | Televison & Video
Is it possible to copy all the files from my dvd recorder to removable media such as dvd's or a portable hard drive? i would like to back up all the family albums etc
If you have a computer with a dvd writer, there is no need to use an external DVD recorder to copy discs. The DVD software on your computer will have a way to temporarily record a disc to hard drive then allow you to insert a blank disc for recording.
A consumer DVD recorder will not have this capability. There is usually no way to output digital files; the machines are intended for playback to a TV.
Oct 10, 2009 | Hitachi DV-DS160 DVD Recorder
Limited viewing
It sounds like the recorder will only record the dvd+ format, which does NOT need finalizing to play in other machines. ( you can record a dvd- , play it back on the machine you recorded it on, but need to finalize it to play on other machines)
The other units may only accept dvd-.(dvd- being the same format as you would buy or rent a film on)
One option, record the dvd on a dvd+rw (if possible) then copy to a dvd-r using your computer. The average use of a dvd+ is 1000 recordings.
There are many free disc burning suites available to download. Just google "free disc burning software" and take your pick.
I use 1 called "magix goya base" for copying disc to disc and "NTI" for burning to HDD and then to disc, if you only have use of 1 drive.
Sep 04, 2009 | RCA DRC8295 DVD Recorder/VCR Combo
Amilo PA 2548: DVDRW GSA-T20N can't write discs
Go into device manager and delete that disk drive and then reboot and it should reinstall it. That will separate the drivers and put the old one back.
Jun 10, 2017 | LG GSA-T20N DVD±RW Dual Layer Burner
Can not read disc
I mainly use my DVR to record TV shows on DVD-RAM discs (Panasonic brand or Maxell). I've had no problems with the DVD-RAM discs. However, today when I put a DVD-R disc in the recorder, I got an "Incompatible Disc" error message. I tried a second disc from the same set, and got the same message. I tried out some of the DVD-Rs that I recorded last year and I could read them. Tried a DVD-RAM. That was OK. So, I tried another DVD-R disc. That one is OK. I don't know if the problem is that these DVD-Rs are getting a little old (2 years??) or if the recorder is developing its own problems reading discs.
Dec 03, 2008 | Panasonic Diga DMR-EH75V DVD...
Recording to Dvd-rw
yes u hav eto use dvd +r disk ok try that 1st please thx nick
Feb 04, 2008 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Won't Read blank disc!!
I my DVD-HR735 wont recognise any discs at times, and is getting worse. I've now discovered (out of frustration) that if I tip the front up to between 30-45 degrees, it will play all the discs it says were unreadable. I've started jamming three dvd boxes under the front of the machine when i want to play dvds.
Nov 18, 2007 | Samsung DVD-HR735 DVD Recorder/HDD...
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
