Machine is stopping mid cycle. Still has water in but will not empty on pump out. On/Off light, reduce creases and time saver lights are all flashing - help!
Just had this problem whilst trying to get kids off to school you know the deal, suit on reddie brek in your ear, wife shouts back as you scream help me get the bowl!!!!!!!
This is a pump siezed inication. Well thats what mine was. Switch it off at the wall, remove bottom whit cover by the screws, mind there are some hidden. On the right at the bottom the pump has a plastic splash cover on it. flick that off and slide the pump towards the cylinder it is held in by 2 lugs on a top heavy eight figure and then it lifts out. Remove power lead dont worry it only goes back in one way. The 2 clips holding the black pipe from the machine (this will have 2 bowls full of water so have one standing by and within reach, also make sure the wife is behind you and keeps quiet!! the white that is the drain are both ratchet style. with a bit of persuasion they will slide off each other if you get a twist on them with a screwdriver. (the teeth go across each other a lot easier than trying to pull against whats they are designed not to do). once you have the pump in your hand look in both ends for obstructions, mine was a party balloon which was well and truly wedged. Try it for free movement if not then maybe a new pump, get the part number off its id plate. Further tests if your careful plug it back in and cycle the machine and see if it spins up. If not then you may be in another world of components and relays. i have had my machine for 7 years and am amazed how well its doing, now its becoming an old friend as i am getting to know its inner workings more and more. Good luck, i am on email if you need. andy@air1charter.com.
Posted on Feb 24, 2009
Excellent, many thanks!
Posted on Jun 08, 2007
Filter blocked or brawire or similiar in drain pump take off cover at bottom rear. take of hose going to bottom of tub. filter is in that hose you will have water everywhere. one way round that is to lay machine on side - left side down viewed from rear
Posted on Mar 20, 2007
Mar 05, 2017 | Washing Machines
Aug 07, 2017 | Washing Machines
May 18, 2014 | LG WD-80130F 7.2kg Washing machine
May 17, 2014 | Washing Machines
Mar 06, 2010 | Hotpoint Aquarius WF210 Front Load Washer
Jan 18, 2010 | Hotpoint Aquarius WD640 Front Load...
Jan 16, 2010 | Hoover Washing Machines
Jul 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
Mar 09, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Jun 02, 2008 | Washing Machines
Jul 06, 2014 | Hotpoint Aquarius WF220 Front Load Washer
Jun 03, 2014 | Hotpoint Aquarius WF220 Front Load Washer
336 people viewed this question
Model WF210 1100 Spin, getting stuck on cycle & leaking water
starts going round on wash at which point all lights flashing, not emptying
The machine has stopped mid cycle and says f11
On a 'D' cycle wash, no extra settings, stops mid cycle. All lights come on and stay on. Door unlocks, and drum full of water. Cycle does not complete
stopped on rinse cycle, sounds like water is trying to enter and machine is trying to pump at the same time. checked filter and pipe both clear
How tomopen door
