Question about Singer 2662
My bobbin thread is not able to feed properly
Hello! I hope that you can help me repair my sewing machine, I am lost with out it and do not want to take to get serviced since I believe it is probably something so easy to fix... I was sewing a pair of jeans when my needle broke. I took apart the machine to get the tip of the needle and thoroughly cleaned my machine. I went to thread it again and now the bobbin thread will not feed to the needle. Any ideas? Please help. Thank you.
    Genius:
  • 1,074 Answers
Y have broken the clip for the bobbin case you need to replace the bobbin case and oil up your machine properly.good luck.my email is nicodhem@yahoo.com to keep me posted.
Posted on Apr 05, 2007
Automatic thread cutter.bobbin thread does not feed to the top.
when you stop sewing where is the arm located ,up or down ..that will make a world of difference
Jan 06, 2014 | Elna 7200 Computerized Sewing Machine
Machine will not sew, the thread is tangled and matted up on cloth side next to machine. I have re threaded, replaced bobbin. Still jams up.
I believe that the bobbin adjustment screw is loose, you need to hold the thread and see how fast it comes out of the bobbin, then tighten the screw until it just barely comes out. You may need to adjust a few times to get it right. If the bobbin screw is too loose, the thread feeds too fast and will jam up as you indicate.
Hope this is of some help
Please rate and comment,
Joe
Sep 07, 2011 | Brother Sewing Machines
I own a "Lena" machine
Hello
Make sure your feeddogs are up. That is the little jagged looking plate under the pressure foot. There should be a setting on your machine that will move it up and down.
If they are up then the bobbin is not in correctly. If it is a normal round bobbin that fits in a bobbin case, hold the bobbin in front of you so that the thread end is on top and the thread is going away from you, and slide it into the bobbin case. Feed the thread through the right openings in the bobbin case. When you pull the thread end the bobbin should turn clockwise.
Never hand-wind bobbins. Instead, use the accompanying bobbin winder which is attached to most machines,bobbin casings must be oiled regularly to prevent problems with the bobbin turning properly. The bobbin, when inserted properly into the bobbin casing, should spin counter-clockwise when thread is pulled.
Check the way your machine is threaded. Completely un-thread your sewing machine and re-thread it. Remember to always thread your machine with the presser foot up.
Check the bobbin and be sure the bobbin is threaded correctly and that the bobbin case is correctly threaded. Be sure the bobbin is in the bobbin case in the correct direction.
Always watch for bobbin wear, especially on the plastic type of bobbins. If the edges of the plastic are showing abrasions, the size of the bobbin has changed and may be the culprit. Although the size change is minute, it allows the bobbin to wobble in the case and changes the tension.
Dec 19, 2010 | Husqvarna Sewing Machines
Bobbin not looping top thread to make a stitch
Get a manual for your machine so you know how to properly thread the machine - you need to be sure the thread goes through the guides in proper sequence and - ALWAYS thread a sewing machine with the presser foot up.
You need to be sure the bobbin thread is feeding in the correct direction from the bobbin spool and through the correct guides.
Check the needle to see if it is installed correctly and is not bent.
Most sewing machine needles are installed with the flat side toward the back of the machine.
After proper threading and bobbin feeding, hold onto the top thread tail and lower the needle down and back up to pull up the bobbin thread.
Take both thread ends under the presser foot and to the back of the machine.
You did not provide the make and model of your machine so I can only suggest if you do not have a manual, search the Internet. Singer and Brother have downloads. Sewusa has many brands/models.
Mar 01, 2010 | Sewing Machines
My top thread gets caught in the bobbin. When I
Here are a couple of solutions to try.
* Try re-threading your machine. It may be threaded wrong.
* Raise your feed dogs
If your machine has this feature.
* When you start to sew a seam, hold the upper and bobbin thread tails back and out of the way as you sew your first couple of stitches. This will prevent them from getting caught in your machine.
I hope this helps.
Dec 29, 2009 | Sewing Machines
My bobbin wont engage with the stich. it just keeps getting jammed up. i lost the manuel i have no idea what to set the tension.
Try these solutions
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin. There could be a nick along the edge of your bobbin spool that’s catching your thread as you sew.
* When you start to sew a seam, Hold the upper and bobbin thread tails back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
I hope this helps.
Dec 24, 2009 | Sewing Machines
I am trying to sew and the thread keeps clumping up at the bottom.
Try these solutions.
* Re-thread your machine as it may be threaded incorrectly.
* Raise your feed dogs If your machine has this feature.
* When you start to sew a seam, hold the upper and bobbin thread tails back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
I hope this helps.
Dec 24, 2009 | Brother XL-5130 Mechanical Sewing Machine
The bobin thread bunches up on the bottom side of garment.
* Raise your feed dogs if your machine has this feature.
I hope this helps.
Dec 20, 2009 | Brother LS-1217 Mechanical Sewing Machine
Issue with the thread "birdnesting" on the underside of the fabric. Have changed out the bobbin, needle and thread.
Here's a couple of things to try.
* Before you start to sew a seam, hold the upper and bobbin thread tails. Hold them back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
Hope this helps.
Sep 21, 2009 | Sewing Machines
How do i keep the thread from gathering on the underside of the material The thread bunches and breaks. thought it might be the tension but can't seem to fix. I cleaned the bobbin areas.
Here are some solutions for you to try.
* Re-thread your machine, it may be threaded incorrectly.
* When you start to sew a seam, hold onto the upper and bobbin thread tails. Hold them back and out of the way as you sew your first couple of stitches. This will keep them from getting caught in your machine.
I hope this helps.
Sep 20, 2009 | Sewing Machines
Singer 2662 Logo
123 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
