Question about HP PhotoSmart C4280 Laser Printer
HP C4280 incorrect paper feed
I created business cards in WordPerfect and they print out fine on regular paper. As soon as I try to use card stock (standard Avery, InkJet, not overly heavy), the alignment screws up completely and the cards print at the very top of the page. I've tried feeding the stock one page at a time; card stock on top of plain paper, card stock on top of card stock.
  • timespender Jan 10, 2009
    I'm trying to print notecards, two on a page in landscape orientation.  I'm using  Pages to set up the cards.  They print perfectly on plain paper but when I put in the card stock the left margin becomes smaller than the right and the size of the images actually changes slightly.  Any advice?
  • psjohn Feb 04, 2009
    My business cards will not print on any card stock... Avery, Staples, or any other. alignment is always off. The lower rows are all off to the top of the card. Same problem with labels. HP assistance was no help at all.
    FYI the HP C4280 is not a laser printer it is an inkjet.
  • 24 Answers
Check your printer's capability.
Buy the card stock they recommend.
If all else fails, print on plain and take card stock to a copy shop and have them do it for you.
Walking there beats going nuts over stupid software or hardware problems
Posted on May 26, 2009
3 Suggested Answers
craxtech
  • 33 Answers
SOURCE: Using Avery papers with my HPc4280
you could use any matte type of paper or your could contact avery to get a recommended paper type profile for your printer
Posted on Jul 25, 2009
komguy
  • 2306 Answers
SOURCE: HP Photosmart C4795. Can't get business cards to align correctly.
In printing properties and printing preferences be sure and tell the printer you're printing labels, it allows more time for the card stock to reach the starting point.
Posted on Jan 05, 2010
Testimonial: "That took care of my problem. Thanks."
I have an HP Photosmart A646 printer that I bought in the hopes of printing to 5x7 card stock. We have pre-printed card stock that we use for gift certificates and we need to be able to feed the card stock...
Thanks for visiting FixYa!
Depending on the program you are using to print your gift certificates, try this-
1) Open the program and open the file you use for your gift certificate.
2) Click on 'Layout' then 'Page Set Up' (probably found in the top menu bar by the right side of, FILE.)
3) Select 'Landscape' and then select, 'Custom'.
4) Enter 5x7 for height and width.
5) Enter the information you need in the data field, (ie, name address, etc.)
6) Select, Print.
7) When the 'Print Manager' box opens, click on, 'Properties'.
8) Click on, 'Type' and choose, "Envelope'.
9) Click on, 'Size' and choose 5x7. - and click, OK.
Your printer should have a slide where the paper is inserted. Place one of the 5x7 cards in the slot just as you would an envelope and slide the slider until it is 'close' to the card but not directly against the card.
Click, 'Print'. The printer should recognize the card (due to its thickness) as an envelope and print it.
Mar 19, 2011 | Office Equipment & Supplies
Started feeding business card stock incorrectly - worked previously
You may need to have a technician adjust your copier or replace the rollers.
May 06, 2009 | Office Equipment & Supplies
Brother laser printer wont print on cardstock My brother printer won't feed teh card stock paper. It used to work but now it won't feed it, normal paper works fine. Even if i nudge the card stock paper,...
If there printer is not able to print on card stock then check the recommend
card stock paper thickness, if the printer works with normal paper but not card stock then there is problem in the card stock and by using this paper may also damage the rollers on the printer and make the printer useless ...
Good luck...
Feb 09, 2009 | Brother MFC-5840CN All-In-One InkJet...
I have a Dell 946 printer and Im trying to print Avery 8871 business card sheets. When I press print the printer will not feed the sheet through and it says there is no paper. I tried to adjust the...
I looked up the user guide at Dell's website and looked up printing cards.
  • The print side of the cards faces down.
  • The cards are centered on the paper exit tray.
  • You select Automatic, Normal, or Photo print quality.
  • Apparently you need to feed the card stock one page at a time into the printer on TOP of the paper exit try (The card stock will feed in from above the normal paper load try [remove paper from the paper tray] and once printed come back to the same spot.
    Jan 26, 2009 | Computers & Internet
    Blinking yellow light
    I m not sure what the specification of the paper type you are using however if you are using card stock than you should use manual feed Tray and in the printer driver properties you should select paper type as Card-Stock to make sure there is no print quality issue.
    Nov 30, 2008 | HP Color LaserJet 2550n printer + HP Color...
    My Printer works fine... except it won't feed business cards or card stock
    You cant fix this because brother printers are limited to paper:
    paper that weights more than 200g wont run through the paper feeder.
    Mar 19, 2008 | Brother MFC 420CN All-In-One InkJet...
    Only prints business cards correctly on plain paper, but not on the card stock.
    I am the guy with the hp d'jet D2445. I ran out of card stock in failed attempts. Not wanting to give up I bought more (Avery, no serrations) and it worked fine. Don't ask why.
    Oct 21, 2007 | HP PSC 1410v All-in-One Printer
    Print Garbage
    The reason your pictures come out dark and grey is that you have not set the paper thickness on your printer. On the back you will see a flip switch change this setting then feed your business card sheet in there and see the diffrence. Plus make sure your settings for your printer are set for a thicker paper this will fix your problem. Make sure though when done printing your cards that you set it back to the normal or you will have problems printing regular paper documents.
    Sep 15, 2007 | HP OfficeJet 7310 All-In-One InkJet...
    HP PhotoSmart C4280 Laser Printer Logo
    685 people viewed this question
    Seeker5211
    Seeker5211
