I have CTL laptop that will not power on. The last time it was on it said switch to electrical power because the battery was low. Now it does nothing.
  • 611 Answers
Remove the battery and agian fix it in your laptop you get it and with him power adpater pulg on it
Posted on Dec 16, 2008
Electrical issues with instrument power cycling when starting the truck.
Check grounds. Battery to engine, battery to body and engine to body. Battery to body will corrode. engine to body is usually the first to break.
Dec 08, 2015 | 2008 Chevrolet Tahoe LT
Tip
How to keep your Laptop battery healthy and last long
Always remember to unplug the power main supply to the laptop when your laptop battery is full (100%) use unless your laptop say LOW battery only then power up the main supply in this way you can extend your laptops battery life.
Do not keep your laptop connected to main supply and work for longer time.
on Jul 16, 2011 | Computers & Internet
Invertomatic victron imv ups
Malfunction of input circuit: voltage delivered is too low. The batteries may
be faulty or depleted. Wait for a few hours, leave the UPS switched on
If absence of input power (utility failure, maintenance work) is expected to last longer than a few hours, switch
off the UPS to save battery power. If the UPS input power is absent for several days and the UPS remains on
under no-load conditions, the batteries can be discharged very deeply, resulting in a short battery life time
Apr 22, 2014 | Computers & Internet
When starting my netbook(turning it on) it goes to right after the 3 light down at the bottom right an application error occurs that claims that the system must shut down, of course it does not....
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Aug 24, 2011 | Sylvania G-Netbook
When my Blue Notebook Model no. iL1 left open and it shutdown because of low battery, i charge it and when it's full i open it and only black screen appears but if you turn off the power you will...
Hi, If you can, try turning up the brightness on the screen. Also if you have a power adapter plug that in and see what happens. It could be you need a new battery. Good luck.
Aug 01, 2011 | CTL IL1 Notebook
Power is going to laptop but it will not turn on. Was just using it w/out power cord. Plugged power cord in and it won't turn on. Tried, Alt, ctl, delete but nothing...:(
Try switching the outlets that you're using the power your laptop. You may have a faulty outlet which could be why it isn't giving off any power to the power cord. Next, try unplugging your power cord, then taking out the battery, plugging back in the power cord and turning your laptop back on. If the laptop turns on, the problem may be with your laptop's battery. If the laptop still doesn't turn back on, put the battery back into your laptop, and see if it works. If it still doesn't work, try taking it to a place like Geek Squad in Best Buy.
Hope this helps!
-Anonymity
Feb 25, 2011 | Toshiba Satellite C655S5085 Notebook
What do I have to do with 1090 critical low battery problem?
HI
do you have an electric power plug to charge the battery up
Feb 01, 2011 | IBM ThinkPad T20 2647 Notebook
Battery its ctl1616 they said NO NEED FOR BATTERY CHANGE but it's not true. How many year this battery last?
The CTL 1616 is a special device.
It's not really a battery, but a "capacitor", which means, that it's mainly supplied by the energy of the light. The capacitor is designed to maintain the functions only for (short) periods of darkness.
It's NOT a "standard lithium battery", because It has a different voltage (2.3 V instead of 3 V) and consists of different materials.
Unfortunately, the capacitor loses its ability to store the energy over the time. So your watch may be able to maintain all the functions for more than 11 months of darkness in the BEGINNING, but after a few years it may only last for a few hours!
However this may be STRONGLY influenced by the use of the functions: for example the automatic reception of radio signals or using a digital compass may strain the energy seriously.
So, the use of different functions may affect the lifetime of a CTL 1616.
I also recommend to expose the watch to (bright) light as often as possible in order to maintain a HIGH level of stored energy.
I also heared that there were serious problems with the quality of this type of capacitor a few years ago. Maybe a new CTL 1616 will last for decades.
Jan 28, 2011 | Casio G-Shock GW1310
Brand New Toshiba Laptop Screen won't come on
That state might called comatose, during the shut down the battery gone low, so the system is in a hang state, after recharging to its full, then you power it on and the system try to recall the last status,sometimes needs reset and the system will work, other trick is remove the battery and PSU then push power switch several times to drain residual power and attach the battery and turn power on.If this will not work, the bios might be need reset, in this case you must claim your warranty service.
Sep 02, 2009 | Toshiba Satellite A135 Notebook
What type of battery goes into Casio G shock MTG900, Module 2638
CTL is the designation for a rechargeable secondary battery. The CR is a primary disposable battery and is a 3 volt cell. The CTL1616 while the same size as the CR1616 function completely differently and are not interchangeable. The CTL1616 is 2.3 volts and is recharged by solar or light or kinetic movement. The CR1616 is 3 volts is not rechargeable and will not function properly in a time piece designed for a 2.3 volt circuit. There is only one manufacturer of the CTL1616, Panasonic and they sell through Casio parts distribution.
Jan 22, 2009 | Luminox 3102 (Size: ) Watch for Men
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
