Question about Brother SE-270D Computerized Sewing Machine
Embroidery Carriage slightly squeaking, can/should it be oiled?
My embroidery carriage has a slight squeak when it's operating, sounds like it could use oil. Can and should i oil it? IF so do I use regular sewing machine oil? I couldn't find any topic for this in my manual
akylas
  • 26 Answers
SOURCE: brothers pe150 embroidery machine will not sew
If you tighten up your needle thread, reduce the tension of the needle thread.
For embroidery, and zig-zag, and because the needle makes side movements, it needs more needle thread.
So try to keep you needle thread not very tight,
and tight up your bobbin case tension more, so that the two threads meet under the meterial.
Posted on Jun 10, 2008
SOURCE: The carriage of the embroidery unit is not move automatically to the embroidering standby position.
Is the need in upright position ?
or have you fitted the embroidery hoop correctly.
If all else fails switch off and start up again - should then automatically go to correct position.
Posted on Jun 18, 2008
  • 4 Answers
SOURCE: The embroidery carriage
Wow, I finally get to have a solution.
1. Turn the machine off.
2. Remove the hoop.
3. CAREFULLY slide the bar on the embroidery unit to the left.
4. CAREFULLY slide the piece where the hoop attaches toward you.
5. Turn on the sewing machine. The machine should take the unit to "standby" with a click.
6. Attach the hoop with the power on.
7. Exit the Futura program.
8. Restart the software.
This "should" fix the problem, however, you may have to repeat this process more than once to get it to "stick".
Posted on Jul 31, 2008
  • 21 Answers
SOURCE: DISNEY BROTHER SE-270D COMPUTER SEWING & EMBRIODERY
but is the carriage moving,? if not disconnect and try to connect again, the embroidery hoop holder usually moves to check itself, if it still does the same thing the connection that goes onto the machine is not making a proper connection, I also had this problem, with a 2100 brother , I fixed it by using a crochet hook and just tightening the connection that connects to the machine on the embroidery unit, but tread very carefully it just takes a slight move. if this fails it will have to be adjusted cost is usually $100au
Posted on Sep 21, 2008
SOURCE: My Disney Brother SE-27OD Embroidery Sewing Machine/trouble
Can you buy embroider memory cards with out down loading on your PC?
Posted on Jan 15, 2009
My machine makes a terrible squeaking sound at the handwheel?when I wind the bobbin. What is squeaking and can I fix it myself?
Depends on the make & model...
Some older mechanical sewing machines need regular cleaning & oiling. Check your user manual.
Apr 20, 2015 | Sewing Machines
My janome memory 9000 squeaks when embroidering
If it squeaks when you are embroidering and not when you are sewing, it's the belts on the embroidery unit. From use, they can become glazed, slick and then they squeak.
If it squeaks when you are doing either, it's more than likely an internal lubrication of the machine that needs to be done by a trained technician.
Cheers,
Kelly
Embroidery Services
San Diego, CA
Feb 25, 2015 | Janome Memory Craft 9000 Computerized...
What is the symptom of a broken hoop
Sounds like you might be having problems with the machine not wanting to start sewing an embroidery pattern or not recognizing the hoop size. If the former, and the embroidery is full size (say 100x100mm), try reducing the embroidery slightly (say 98x98mm). If the latter, your embroidery unit may need slight adjustment to correctly identify the hoop. Its not an elaborate adjustment but you will probably need a profession to accomplish it.
Mar 23, 2014 | Husqvarna Viking 1
Singer Quantum XL 6000 embroidery unit keeps saying the embroidery hoop is loose or not installed. There is some problem with the electronic contacts and the embroidery hoop. Can't get any help.
Try push in and push out your hoop several times into the carriage, then if the problem is still there, most likely the carriage hoop lock sensor is faulty.
Oct 21, 2013 | Singer Quantum XL-6000 Computerized Sewing...
Board
Close your futura file & exit, switch off your futura machine. Disconnect the embroidery unit from the machine,move the hoop carriage a bit to the left then to the right & it should be able to move. Connect back embroidery unit to your futura machine,ensuring the connecting point click properly. Re thread the machine & ensure needle is fully up position. Now you switch on the machine, you will see hoop carriage moving and stop at its zero point. If that is OK and the earlier led blinking gone, you should be able to operate the futura embroidery program again.
Jul 18, 2013 | Singer CE-200 Quantum Futura Computerized...
My Bernina deco 340 embroidery carriage is out of line
sounds like something isn't installed correctly or is broken.
Sep 07, 2012 | Bernina Sewing Machines
Should the Simplicity SE3 embroidery machine be oiled by the operator
If the manual doesnt mention oiling at all, then it probably has silicon or nylon parts not needing lubrication. It may also have oiling wicks which the technican will attend do during the regular services that the manufacturer probably recommends annually in the manual.
You do need to clean out the bobbin area regularly though and your manual should mention this, lint will build up in any sewing machine and affect perforance.
May 15, 2011 | Simplicity SE3 Computerized Sewing Machine
It squeaks when u sew. i need to know where to oil it at
Squeaking or popping sounds could be a blunt needle so make sure you change it regularly, 4-6 hours sewing time is rule of thumb.
To find where to oil this machine download the manual from http://www.singerco.com/accessories/manuals.html, just type in your model number into the search field and click 'Search', most of the manuals are there as a downloadable pdf file.
The manual will show oiling points for your machine. Use sewing machine (clear) oil only, a little drop only but oil and clean regularly to get the best performance. Brush out any lint and dust first (don't use compressed air to blow a machine out, much better to brush out carefully with a little brush and remove the lint from the machine).
You can also put a drop of oil onto a piece of waste fabric then rub this up and down the needle bar (the metal part that goes up and down holding the needle) to keep this clean and lubricated.
May 05, 2011 | Singer 1525 Mechanical Sewing Machine
My bobbin thread keeps coming to the top of my fabric during embroidering on my Singer Futura CE350, I've tried bobbin embroidery thread, regular embroidery thread and clear nylon thread, I've tried...
With the embroidering, some of the bobbin thread is SUPPOSED to show on the top of your embroidery-the machine isn't doing anything incorrectly. You'll need to thread your bobbin with the same thread as you are using with the top. I had the same "problem" when I first got the machine and took it to a wonderful local technician whose helped me with a lot of things who informed me that this is perfectly normal on embroidery machines.
Oct 23, 2010 | Singer CE350
Sep 10, 2008 | Brother LS-2125 Mechanical Sewing Machine
Brother SE-270D Computerized Sewing Machine Logo
405 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
