Question about Canon iP4500 Photo Printer
Black lines running through certain lines of printed documents
I have the MP390 and there are black line running horizontally through certain lines in the printed page, I did a deep clean of the ink head but it still remains.
HELP!!
  • 2,427 Answers
Hi, ok your ink well is clogged (the stuff the ink cartridges fit in) remove all the ink tanks, then remove the inkwell by pulling the lever to the right. In a dish pour some rubbing alcohol and tel the ink jets soak a bit. pour some alcohol over the nossles(where the ink sits to send the ink through) and let it soak a bit more. Use a straw and cover the jets then blow, this will force the bad ink out clear the jets. Blot it dry then replace. blot each inktank before replacing them to insure the ink is running out. A couple of deep ink cleanings and you will be set.
If this fails you may have to replace the ink well and the cartridges (order new ones from canon) But cleaning it should work, try at least 3 times before deciding to buy a new one.
Posted on Dec 16, 2008
There are black horizontal lines printing through my document only when I copy, not print.
open the document feeder and clean the small glass that runs from the front of the machine to the back. probably has whiteout on it.
Mar 01, 2011 | HP OfficeJet J4580 All-In-One Laser...
I am scanning a photo. I have translucent lines running horizontal through the picture before i print it.
Documents scanned/copied from the document feeder pass over a thin glass area where scanning occurs. Clean this area if sent faxes, copies or scans have black or white vertical lines.
  1. Lift the document cover to expose the platen glass.
  2. Wipe the ADF scan area (C) with a clean, soft, lint-free cloth moistened with water.
  3. Then wipe with a clean, soft, dry, lint-free cloth making sure there are no residues left, especially on the platen glass.
  4. Close the document cover and make a copy of a text document to confirm the black line has disappeared.
Dec 20, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Extra horizontal lines on my document.
Have a real good cleanup of the ink that was (presumably) leaking from the old black cartridge. Remove the cartridges from the cartridge carrier and use kitchen paper towel to soak up any ink in the bottom. Give the cartridge outlet holes a dab on the towel as well. Replace the cartridges promptly.
Turn the printer on, and as soon as the print head moves, pull the power cord out of the back. You should now be able to (carefully) move the print head by hand. Place a layer of paper towel on the printer track, and move the print head across it to mop up any surplus ink. Move the print head across to the left out of the way and use kitchen towel to mop up surplus ink in the Print Head parking area.
Now turn the printer on and carry out a cleaning cycle (right click the little printer icon in the bottom right corner of the screen and select clean). Now run a nozzle check (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Are there any extra black lines in evidence now? If so, try another 1 or 2 cleaning cycles and nozzle check. Black lines gone now?
If you still have the black lines, come back with a new comment.
If this information is useful to you, please rate it.
Jan 29, 2009 | Epson Stylus C88 InkJet Photo Printer
Dropout when printing
DId you use a refilled or 3rd party cartridge?
Try a new cartridge
Nov 19, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Lexmark x5470 printer printing blue horizontal lines on coloured documents
hi
try to perform maintenance of your printer
on the setting
and open your printer clean up the nozzle
use alcohol and cotton buds and then placed it back properly!!
Nov 10, 2008 | Lexmark X5470 All-In-One InkJet Printer
Black Lines
Hi
Please try with replacing the INK catridge, it will solve your problem
Boopathy.T
Aug 17, 2008 | Lexmark X6170 All-In-One InkJet Printer
My Sharp Copier AR-5320 print black and white horizontal parallel lines on the documents.
Check for scratches on the drum surface. If you have ran a lot of copies on there, its a good time to get it serviced. It could be the cleaning blade on the drum as well.
Jul 20, 2008 | Sharp AR-5320 Black and White Copier
HP 7110 still won't print in color
Your post "...it prints very faint horizontal lines in color..." is indicative that indeed your color printheads are clogged and would need repetitive deep head cleaning. This is of course would require that you keep on cleaning until such time as the faint color lines have turned to legible print.
Apr 08, 2008 | HP OfficeJet 7110 All-In-One Thermal...
Dell 3100cn printing horizontal stripes
Sounds like a bad imaging drum to me...
Aug 14, 2007 | Dell 3100cn Laser Printer
Black not printing
I just ran into a similar issue with my MP390. Actually both the color and black inks were not printing very well. I would get very inconsistent printing. Fixed the problem very easily and quickly as follows: On the top of each print cartridge, there is a small hole. Remove the print head (lift the gray bar at the front of the print head and lift out the print head) with the cartridges still in place. Holding the print head over a piece of paper/paper towel, blow into the holes on the top of the cartridges (either directly or using a straw/tube of some kind). You should get ink coming out of the botton of the print head, both color and black. Replace and print head and test print.
Feb 28, 2007 | Canon MultiPASS MP390 All-In-One InkJet...
Canon iP4500 Photo Printer Logo
117 people viewed this question
old marine
old marine
