I need to reset my copier and i do not know how to get in the service mode. I have a error code Eoo5-0001. Thanks
SOURCE: Canon Copier NP 1020 - error code E0
pretty much the same, the codes are good for several models not just one.
you need to find the other numbers to know exactly which code it is, press the start or stop key to see it display the other #'s.
fuser is on the left side if you replace the parts might as well replace the claws and oil roller.
"E000"
Heater lamp, Thermistor, DC controller
"E001"
Heater lamp, DC power supply / AC Driver circuit board, Thermistor, DC controller.
"E010"
Main motor clock sensor, DC controller PCB, Main motor, DC power supply / AC Driver circuit board
SOURCE: How to get in service mode on Canon ImageRunner 1630
You DO NOT WANT TO RESET THIS ERROR CODE !!!!!!!
there is a problem with the fuser, if you reset it most likely it will melt the rollers in the machine.
check the lamp (burn out), and thermofuse. replace
SOURCE: Error code E20 in Canon NP 6241 copier
Check this code - does it read E020 ? if so this is usually a result of toner starvation possibly caused by a faulty toner sensor in dev or hopper unit.I have also found the toner hopper supply motor can fail with the same result. In either case it is an engineers job to rectify. Good luck !
