Water cut off not operating.messy floors
Water overflow at start of cycle. solenoids operate and stop flow when lid raised. vacuum hoses connected and seem in good repair. has anyone any bright ideas and also the parts needed to fix the problem
Thankyou Wayne
  • Washing Mach... Master
  • 8,220 Answers
Easy fix. Remove the water level pressur hose and blow it out. This get the sediment and trash out the tube and allows it to correctly read the water pressure as i fills in the tub.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 16, 2008
Water intake does not stop
there is a pressure sensitive control that is activated by a small tube running from the bottom of the tub up to the top of the machine
as the water in the tub rises ,air that is trapped exerts pressure on a diaphragm in the sensor
the pressure is set by your selection of the wash load /level
when that pressure is reached the sensor pressure is overcome and the switch is activated . as a result the inlet water solenoid is shut off and the wash program starts
now knowing how it works , check for the small hose is not full of water when the tub is empty, the hose is intact and not cracked or broken and the pressure switch is operational ( disconnecting the hose at the tub and blowing air into it ( like blowing up a balloon) will activate the switch
if that is working ,the next point ti check is the solenoid that switches of the tap water with the machine on as if you are doing a wash the water will start to flow . blow into the tube and the switch should shut off the water flowing into the tub and start the wash cycle
if the machine starts to wash but the water still flows then it is the solenoid that is faulty
fix is a replacement unit
Sep 24, 2015 | Samsung Washing Machines
My Simpson Eziset 550 will not drain after a (normal) wash cycle. When the drain hose is lowered to the floor drain water flows heavily from the hose (gravity). When the hose is returned to the sink d
Hi Erin just read your post,I have worked on these machines alot.Now I need you to manually drain the machine of all the water. Once drained i want you to select drain and spin cycle. Now push the start button,do you hear the pump working?If you do stop the machine and select normal cycle on small water level and push the start button.The machine will then fill.Once it stops filling stop the machine and select drain an spin cycle.Does the machine pump out? Now if you do not hear the pump, could be the pump is faulty or jammed.Does the water flow very fast when you lower it to the floor? Please reply with answers to these questions and I will try my best to help you.
Jan 25, 2014 | Washing Machines
Hot water will not stop flowing. Hot water
Sounds like a bad shutoff solenoid. It operates the valve to let water in and then shut it off. There should be a valve behind the machine where the hose connects to the wall so you don't have to isolate hot water to the entire house.
Sep 18, 2017 | Bosch Axxis WFL 2060 Front Load Washer
The machine stopped and is flashing the F them H signal. What does this mean. Already did a spin cycle. Before all this happened water was found on the floor. Hoses look okay.
FH: If after 30 seconds the control does not detect water entering
machine, the valves will be turned off and the error code will be
displayed. OR If the control has turned the water valves on and after
8 minutes the flow sensor has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
If there is no water in the unit:
-Make sure that both valves at the water source(s) are turned
on all the way.
-Check for plugged or kinked inlet hoses or plugged screens in
the inlet valves.
-Verify inlet valve operation.
If there is water in the unit:
-Verify drain pump operation.
-Verify that the pressure switch hose is in good condition and
properly connected to tub and pressure switch.
1. Verify there is not a siphon problem.
2. Unplug washer or disconnect power.
3. Verify wire harness connections to inlet valves,
pressure switch, drain pump, flow meter, and
Central Control Unit (CCU).
4. Check all hoses for possible leaks.
5. Plug in washer or reconnect power
6. Verify pressure switch operation.
7. Verify flow meter operation by blowing air through the part and
measuring the resistance.
8. Verify CCU operation by running a Diagnostic test or any cycle.
Handy Hippy's guide to HE bliss
Feb 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Code says evaporator purge solenoid
Which code specifically? Do not assume you need a new solenoid. Our recommendation will depend on the specific code and some troubleshooting results. I usually recommend checking over all the EVAP vacuum lines and the gas cap too whenever there is a purge valve code. Check the vacuum lines at the cannister in the left rear bumper. I will paste info on the purge solenoid below.
P0440 Evaporative emission (EVAP) system - malfunction
Possible causes: Hose connection(s), intake leak, EVAP canister purge valve
P0441 Evaporative emission (EVAP) system - incorrect flow detected
P0442 Evaporative emission (EVAP) system - small leak detected
Possible causes: Hose connection(s), intake leak, EVAP canister, EVAP canister purge valve
P0443 Evaporative emission (EVAP) canister purge valve - circuit malfunction
Possible causes: Wiring, EVAP canister purge valve, ECM
P0444 Evaporative emission (EVAP) canister purge valve -open circuit
Possible causes: Wiring open circuit, EVAP canister purge valve, ECM
P0445 Evaporative emission (EVAP) canister purge valve -short circuit
Possible causes: Wiring short circuit, EVAP canister purge valve, ECM
P0450 Evaporative emission (EVAP) pressure sensor - circuit malfunction
Possible causes: Wiring, EVAP pressure sensor, ECM
P0455 Evaporative emission (EVAP) system - large leak detected
P0456 Evaporative emission system - very small leak detected
Possible causes: Mechanical fault, hose connection(s), EVAP pressure "sensor
P0457 Evaporative emission system - leak detected (fuel cap loose/off)
Possible causes: Mechanical fault, hose connection(s), EVAP pressure sensor
P0458 Evaporative emission system, purge control valve -circuit low
Possible causes: Wiring short to earth, EVAP valve
P0459 Evaporative emission system, purge control valve -circuit high
Possible causes: Wiring short to positive, EVAP valve
Evaporative Emission Purge Solenoid
Description & Operation
The duty cycle EVAP canister purge solenoid (DCP) regulates the rate of vapor flow from the EVAP canister to the intake manifold. The Powertrain Control Module (PCM) operates the solenoid.
During the cold start warm-up period and the hot start time delay, the PCM does not energize the solenoid. When de-energized, no vapors are purged. The PCM de-energizes the solenoid during open loop operation.
The engine enters closed loop operation after it reaches a specified temperature and the time delay ends. During closed loop operation, the PCM cycles (energizes and de-energizes) the solenoid 5 or 10 times per second, depending upon operating conditions. The PCM varies the vapor flow rate by changing solenoid pulse width. Pulse width is the amount of time that the solenoid is energized. The PCM adjusts solenoid pulse width based on engine operating condition.
Removal & Installation
The duty cycle evaporative (EVAP) canister purge solenoid is located in the engine compartment near the brake master cylinder.
  1. Disconnect electrical connector at solenoid.
  2. Disconnect vacuum lines at solenoid.
  3. Lift solenoid slot from mounting bracket for Removal & Installation.
To Install:
  1. Position solenoid slot to mounting bracket.
  2. Connect vacuum lines to solenoid. Be sure vacuum lines are firmly connected and not leaking or damaged. If leaking, a Diagnostic Trouble Code (DTC) may be set with certain emission packages.
  3. Connect electrical connector to solenoid.
Purge solenoid location:
EVAP cannister location:
Nov 05, 2010 | 2000 Jeep Grand Cherokee
Water keeps going and overflows
Hi and welcome to FixYa. I am Kelly
You will have to open the top panel for steps below
Water level control is handled by the water level pressure switch inside the top panel. It is about 3.25 inches in diameter, has 3 wires connected to it and a hose that looks like a small vacuum line.
Check that vacuum looking line for any holes, kinks or disconnects.
You will need about 3 feet of the same knid of line available from any autoparts store for this test.
Remove the machine side hose and connect the 3 ft hose you just obtained. DO NOT drop the machine hose into the machine.
Place the timer on the wash cycle and start the cycle
Result = fill
Force air into the hose orally until you hear a click.
Result = fill stop agitation begin
If it does not pass this test then the pressure switch is bad.
If water never stops flowing the water inlet valve has debris internally and will probably have to be replaced.
Don't forget to reconnect the machine side hose to the pressure switch.
Thanks for using FixYa!
Kelly
Then remove the vacuum
Feb 18, 2010 | Maytag PAV2300 Top Load Washer
Cold water cycle has warm water no cold water allowed. sounds like some kind of valve is not stopping the hot water from coming in
Make sure that the inlet hoses are connected to the correct inlet solenoid valve (located just inside the cabinet). If the hot water solenoid was passing water when not wanted, the washer would eventually overflow on to the floor. There may be a problem with the solenoid control circuits which may require professional help to diagnose.
Feb 02, 2010 | Maytag Atlantis MAV6451 Top Load Washer
When furnace cycles on the humidifier overflow spout has a tremendous flow of water that pours all over basement floor. Is there a valve problem ? I can connect a drain tube from this overflow spout to the...
If the water stops when the heater is not running then the humidifier is working fine. I know it seems like alot of water but that's how it's designed.
Jan 02, 2010 | Aprilaire 550 Humidifier
After two to three days the water starts to appear
hello mam
please check the solenoid walve which controls the water to check this please open the top cover of the washer and see the water line where the water hose pipe is connected there you can find the solenoid walve and observe this as you give the supply and timer switch is ON you hear the sound of the walve operation while it opens the line to take the water and as switch of the mains it should shut the water line to stop the intake of water and if this operation is not happen then please change the solenoid walve.
Oct 07, 2009 | Bosch 23 in. SHU3302UC Built-in Dishwasher
Ge wbsr washer overflows...
Could it be ...this happens only when it is overloaded or the load is out of balance. Please clarify.
If this is not the case .. the water level hose running from the outside tank to the water level switch is likely not making a good seal (otherwise the water level switch itself is bad). Sometimes with age the hose forms a crack in it near or at the end where it connects. This could happen at either end of the hose. Also if you have removed the control panel recently (for any reason) you may have (not knowingly) pulled the water level hose loose from the water level switch. Just slide the hose back onto the tube of the switch before putting the control panel back in place and all will be fine after the first filling of the tub (it may take one filling cycle to build the needed vacuum back up in the hose). Unless of course in the process you have broken the tube off the switch where the hose goes on. In this case replace the switch.
Jun 05, 2017 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
