Question about Compaq Inkjet IJ750 Printer
Paper feed Compaq IJ750
The paper is not being pulled into the printer in order to print.
    Guru:
  • 829 Answers
The paper sensor might be damaged.
Posted on Dec 16, 2008
My brother printer LC75 won't print says on the screen error no paper feed reload paper press start I did this still won't print
In order to solve this issue try the below mentioned step:
1. If you have a photo paper tray installed just above the main tray, pull it back towards you otherwise it blocks the paper feed.
This should resolve your paper feed issue.
GuruAid.com
Dec 12, 2014 | Brother Office Equipment & Supplies
How to load evelopes HL 2140
Brother Hl 2140 Printing on thick paper, labels and envelopes 2
When the back output tray is pulled down, the printer has a straight paper path from the manual feed slot through to the back of the printer. Use this paper feed and output method when you want to print on thick paper, labels or envelopes.
Open the back cover
Open the manual feed slot cover.
Using both hands, slide the manual feed slot paper guides to the width of the paper that you are going to use.
Using both hands, put one piece of paper or one envelope in the manual feed slot until the front edge of the paper or envelope touches the paper feed roller. When you feel the machine pull in the paper, let go.
• Put the paper into the manual feed slot with the side to be printed face up.
• Make sure that the paper or envelope is straight and in the proper position on the manual feed slot. If it is not, the paper or the envelope may not be fed properly, resulting in a skewed printout or a paper jam.
• Do not put more than one piece of paper in the manual feed slot at any one time, as it may cause a jam.
• If you put any Media (paper, envelope and so on) in the manual feed slot before the printer is in the Ready state, the media may be ejected without being printed on.
Jul 18, 2011 | Brother HL 2140 Laser Printer
Canon ip3300 paper feed not working properly
There is a small switch on the bottom left on the front of the printer that was selecting envelope feed instead of paper feed. Changing this fixed the problem.
Jan 14, 2010 | Canon PIXMA iP3300 InkJet Photo Printer
Paper pulls to the right, jams, won't print, tried different paper still won't print
Sounds like the feed rollers need cleaning.
Clean the feed rollers, lint free cloth,bottled water.
wait for them to properly dry
Revolve the feed roller bar as you clean them, to clean the feed rollers all the way round, remove all particles from them.
Check you ADF grips are set correctly, if not you will get mis-fed sheets. check the tray is sat properly too or mis-feeds.
Check paper size is correct in print properties too.
Should be good then
Try print.
Regards
Richard.
Apr 21, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Error on inkjet "print spooler service not running"
hi, friend. You need to re install your Printer software CD because the program corrupted. thats the only way to solve that.
Apr 08, 2009 | Compaq Inkjet IJ750 Printer
Paper feed not working
Take a size 10 Envelope fold it so that it should become like a thin long strip........ Now Insert that Envelope on the left side corner of the Printers Paper Feed Tray and move it from right to left and left to right as fast as u can for about 10 times.......... Now Insert the Ordinary Papers onto the Printer and insert both the catridges and Turn on the Printer............Now Try to Print......
Good Luck
Mar 01, 2009 | Compaq A3000 All-In-One InkJet Printer
Lexmark z2300 printer won't pull in paper
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Jan 03, 2009 | Lexmark Color JetPrinter Z23 InkJet
Paper not feeding in order to print
make sure the input tray is properly setup and aligned, the tab is pushed against the paper.
Dec 12, 2008 | HP LaserJet 1018 Printer
Paper will not feed into printer
Oct 17, 2007 | Lexmark X83 All-In-One InkJet Printer
Compaq Inkjet IJ750 Printer Logo
103 people viewed this question
Top Compaq Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Pam Kelly Andrews
Pam Kelly Andrews
Level 1 Expert
Are you a Compaq Office Equipment and Supply Expert? Answer questions, earn points and help others
