Windows xp tools
Good morning all. I have some "problem" (pardon my english) with my cpu.When we go to start - run, type 'winmsd' and press enter, we will see the system information window. When we click the 'tools' tab, there's a list of tools will come out such as :
-windows report tool
-update wizard uninstall
-system file checker
-signature verification tool
-registry checker
-automatic skip driver agent
-dr watson
-system configuration utility
-scandisk
-version conflict manager.
My problem is, when i check my computer, there're only 5 items that is
-net diagnostics
-system restore
-file signature verification utility
-directX diagnostic tool, and
-dr watson
So, my question is where are the rest? and how can i get it back? (if it's possible)
By the way, i'm using a Dell Optiplex GX270, Intel P4, 2.66 GHz, Bios Version A03, 512 mb DDR SDRAM & 30gb hard disk.
  • jeramtoi Dec 16, 2008
    Well actually it's not a problem, it's more to "i'm curious" :-) you know.. bibleman01 since you also have the same thing, then i think it is ok, thanks guys..
  • Greg Wilkins
    Greg Wilkins May 11, 2010
    I have a dell Demension 2400 and when i type that in i have the same thing you have.so why do you think you should have more
  • 2,427 Answers
Hi,, Well what you have is not really a problem, Dell uses an OEM version of windows that is specially designed for the, therefore some of the features just arent there. If you wish to use the you will need to purchase a copy of windows (the same version of the one you are using) or borrow one. use the product key that came **** on a sticker on your system, this will install the windows and then you may register it online. You dont need a fress install, just select repair windows or replace system files.
Posted on Dec 16, 2008
What are specifications of the CPU
please click start menu and type on the run dxdiag and press enter wait for a windows to appear, there you will read the specification of your cpu.
Aug 19, 2011 | Microsoft Windows XP Professional for PC
My pound sign comes up as # and my @ as "
Windows 7 or Windows Vista
  1. Click Start Collapse this imageExpand this imagevistastartbutton.jpg, type intl.cpl in the Start Search box, and then press ENTER.
  2. On the Keyboards and Language tab, click Change keyboards.
  3. Click Add.
  4. Expand the language that you want. For example, expand French (Canada).
  5. Expand Keyboard list, click to select the English(United States) check box, and then click OK.
  6. In the options, click View Layout to compare the layout with the actual keyboard.
  7. In the Default input language list, click English(United States) - English(United States), and then click OK two times.
  8. In the Regional and Language Options dialog box, click OK. Note The Language bar appears on the taskbar. When you rest the mouse pointer over this bar, a tooltip appears that describes the active keyboard layout.
  9. Click the Language bar, and then click English(United States).
Windows XP
  1. Click Start , type intl.cpl in the Run box, and then press ENTER.
  2. On the Languages tab, click Details.
  3. Under Installed services, click Add.
  4. In the Input language list, select the language that you want. For example, select French (Canada) .
  5. In the Keyboard layout/IME list, click English(United States), and then click OK .
  6. In the Select one of the installed input languages to use when you start your computer list, click English(United States) - English(United States), and then click OK.
  7. In the Regional and Language Options dialog box, click OK. Note The Language bar appears on the taskbar. When you rest the mouse pointer over this bar, a tooltip appears that describes the active keyboard layout.
  8. Click the Language bar, and then click English(United States).
How to make sure that the selected layout matches the keyboard Windows 7 or Windows Vista
  1. Click Start, type osk in the Start Search box, and then press ENTER.
  2. Match the keyboard on the screen with the physical keyboard to make sure that the layout matches.
  3. To check the uppercase characters, click the shift key on the keyboard or on the screen, and match the characters printed on the keyboard.
Windows XP
  1. Click Start, type osk in the Run box, and then press ENTER.
Jan 07, 2011 | Dell Computers & Internet
Does not start after the Defragmenter is run. Says, BOOTMGR Press ctrl + alt + Del to restart.
1.Insert the Windows XP CD-ROM into the CD drive, and then restart the computer.
2.Click to select any options that are required to start the computer from the CD drive if you are prompted.
3.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
4.Press 1 (One) to select windows XP and then hit enter.
5.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
6.At the command prompt, Type Bootrec /RebuildBcd and then press ENTER.
7.If the Bootrec.exe tool runs successfully, it presents you with an installation path of a Windows directory. To add the entry to the BCD store, type yes. A confirmation message appears that indicates the entry was added successfully.
8.If the Bootrec.exe tool cannot locate any missing Windows installations, you must remove the BCD store, and then you must re-create it. To do this, type the following commands in the order in which they are presented. Press ENTER after each command.
Bcdedit /export C:\BCD_Backup
ren c:\boot\bcd bcd.old
Bootrec /rebuildbcd
1.Restart the computer
Nov 04, 2010 | Compaq Presario CQ60-220US PC Laptop
How can i repair or replace boot.ini in windows xp
Enter Windows XP Recovery Console. The Recovery Console is an advanced diagnostic mode of Windows XP with special tools that will allow you to restore the boot.ini file.
When you reach the command line (detailed in Step 6 in the link above), type the following command and then press Enter.
bootcfg /rebuild
The bootcfg utility will scan your hard drives for any Windows XP installations and then display the results. Follow the remaining steps to add your Windows XP installation to the boot.ini file.
The first prompt asks Add installation to boot list? (Yes/No/All).
Type Y in response to this question and press Enter.
The next prompt asks you to Enter Load Identifier:.
This is the name of the operating system. For example, type Windows XP Professional or Windows XP Home Edition and press Enter.
The final prompt asks you to Enter OS Load options:.
Type /Fastdetect here and press Enter.
Take out the Windows XP CD, type exit and then press Enter to restart your PC.
Assuming that a missing or corrupt boot.ini file was your only issue, Windows XP should now start normally.
Nov 03, 2010 | Computers & Internet
I am now not able to run Defragmenting tool and also not able to down load Microsoft security essential?
ok i am making a lot of assumptions here, you didnt tell us your operating system, but can i guess your running norton antivirus. close it if you are. remember some antivirus's have a defrag in them this may be interrupting the process. let me know
mel
Jun 11, 2010 | Microsoft Windows XP Professional
I have a dell inspiron 9300 laptop runing windows xp. i want to download the trial version of sony vegas pro 9. do download 32bit or 64bit version --or does it matter? Thanks in advance for your help.
Right click on My Computer on your desktop and select Properties. If you have a 64-bit system it should say so in the window that pops up. It would say x64 after the Operating System name or 64 bit near the bottom.If it does not say, it is a 32 bit system.
You can also select Start>Run, type winmsd in the box and press ENTER. In the right pane look for Processor. If it is a 64 bit system the Processor line will start with ia64 or AMD64. If a 32 bit system it will start with x86.
Thanks for using Fixya.
Oct 12, 2009 | Sony Computers & Internet
Win Xp: 32-bit or 64- bit ???
Press the WINDOWS key + BREAK
then the system info will come up. Check the "system" tab. If you have 64bit it will say there.
Aug 26, 2009 | Computers & Internet
Zero wireless configuration has been disabled on presario
Follow this procedure to stop and start the Wireless Zero Configuration service in the Windows XP Operating System:
  1. Click the Start button, then click Run .
  2. In the Run window, next to Open , type cmd .
  3. Press the ENTER key.
  4. In the Command Prompt window, type net stop wzcsvc .
  5. In the Command Prompt window, type sc config wzcsvc start= auto .
  6. Press the ENTER key. NOTE: The [SC] ChangeServiceConfig SUCCESS should be displayed.
  7. Type net start wzcsvc .
  8. Press the ENTER key. NOTE: The Wireless Zero Configuration service was started successfully message should be displayed.
  9. Type exit .
  10. Press the ENTER key.
Jul 29, 2009 | HP Computers & Internet
5100-3583 slowed down
1) scan for adware using another scanner (for eg., ad aware http://www.download.com/Ad-Aware-2008/3000-8022_4-10045910.html?hhTest=1)
Antiviruses can miss some problems, so it never hurts to get a second opinion.
2) Reduce the number of programs that start with Windows, like messengers, file sharing, etc. You can do this from the program options. (for eg, Windows Live Messenger, Ares, Yahoo Mesenger) For startups that you cannot stop in this way, go to Start>run and type "msconfig" (without the quotes) and click on the "startup" tab and uncheck any of these programs you RECOGNIZE and do not need to have start with Windows. (You can always start them from Start>Programs if you need to)
http://www.answersthatwork.com/
This page can help you determine what's necessary and what's not.
3) Go to Start>programs>Accessories>system tools>disk cleanup and run this application. Follow the instructions given.
4) Could be that you need more RAM. XP's supposed to run comfortably on 128 MB of RAM, but recent applications seem to be using more and more as time progresses. If you have 512MB or less, it's a good idea to upgrade regardless.
5) Check for file system problems (not very likely, but just in case) Go to Start>run, type "cmd" (without quotes) and press "enter". At the cursor in the window that opens, type chkdsk c:/f and press enter. Follow instructions given. (this most likely requires a restart)
6) If all else fails, try a system restore to the last time your PC worked reasonably well. (Start>Programs>Accessories>System Tools>System Restore. Follow the instructions)
7) If this doesn't work, a reformat might be quickest way to solve all your problems. You'll need an original copy of Windows XP (unless you want to upgrade to Vista, which has higer hardware requirements) and install disks or files for all your installed programs as well as backups of ypur personal files. Better left to a professional if you're unsure.
Aug 08, 2008 | Acer Aspire 5100 Notebook
Change wellcome screan of windows xp
Disabling the Windows XP Welcome screen.
  1. Click Start, Settings, and Control Panel.
  2. Open User Accounts.
  3. Click "Change the way users log on or off".
  4. Uncheck the "Use the Welcome screen".
  5. Click "Apply Options"
Disabling the Windows XP login prompt for password.
Click Start and Run
  1. Type "Control Userpasswords2" and press enter.
  2. Uncheck the box for "Users must enter a user name and password to use this computer."
  3. Click Apply and Ok.
Jun 09, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
