FixYa.com
Tags:
Micro Pro 7599 Iron
My iron is a steam iron and I put h2o in it to... (by 2 users)
By Bouncy - usenet poster
My iron is a steam iron and I put h2o in it to create steam. I let the h2o sit and now when I turn it on I get a brown mist coming out of it. I tried to let the iron steam until it was out of h2o, but it did not work. I was once told that you could clean an iron by putting vinegar in it and letting it steam out. Is this true?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Angie629, posted on Apr 30, 2008
I get brown spots in my fabrics when I iron with my DPP 1500 iron. What do do?
Best Solution
posted on Aug 08, 2005
FixYa! (100)
Luisa_K
Luisa_K - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Actually what you are getting out of your iron is not rust per se. Did you use tap water? If tap water what you are seeing is the minerals from the water.
To clean out your iron go to your local fabric store or variety store i.e. Walmart, K-Mart, etc. There is a cleaner made for this. Just follow the directions. You are probably also getting some residue on the soleplate from the brown steam. There is also a sole plate cleaner to get that off.
If you can't find the cleaner just tip your iron upside down over a sink and drain out as much water as you can. Then start using the distilled water. Don't forget to clean the soleplate. Run at least one filling of distilled water through the iron by using it to iron something you don't care about until the steam comes out clean. Otherwise it will spit this stuff out on your good clothing.
For the future to prevent this from happening you need to use distilled water which is available by the gallon at your local grocery store. It's right next to the bottled drinking water.
Even with the distilled water do not let it sit in the iron after you are through. Once the iron cools off hold it upside down over the sink and let the rest of the water drain out before putting iron away until next use.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: Conair Professional Ceramic Hair Straightener - Black Conair GS20 Iron Conair FSP5 Iron Conair GS10 Iron Conair Ceramic Hair Straightener - Black Panasonic Cordless Steam Iron - White/Aqua Panasonic NI-R73NR Iron
Can you Help with these Irons problems?
Irons
Iron Auto Shutoff
My iron was accidentally... Answer This...
Irons
auto shut down has come on
auto shut down has come on my... Answer This...
Irons
tefal express iron cleaning
spitting out brown through... Answer This...
Micro Pro 7599 Iron
euro pro x iron
Just plugged it in and the on... Answer This...
Micro Pro 7599 Iron
Sunbeam Iron
My iron will not heat up no... Answer This...
Repair Service
Find Iron Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
