Question about Roper Dryers
Clothes not drying
Have a Roper RED 4340SQ1 electric dryer, the drum turns and I have heat but the clothes are not drying. The vent is clear as is the lint trap.
  • singramafhe Dec 16, 2008
    The venting system is clear as it simply goes thru the outside wall.
Clean vents, including exhaust vent
Posted on Dec 16, 2008
Roper dryer works on high heat only
DID U CHECK THE HI LIMIT AND THE CYCLING THERMOSTAT? AS WELL AS THE MOISTER SENSOR?
Dryer venting issues slow drying, fire flare ups, to hot, noise and clothes ripping etc
A lint filter that is full of lint will restrict airflow and lengthen dry times.
A blower wheel that is not firmly attached to the drive motor can slip and therefore not move air fast enough to properly dry clothes or even reduce airflow to the point where the high limit thermostat may trip and turn off the heat circuit.
In gas dryers, defective gas valve coils can create a symptom of taking too long to dry if they are intermittent. Check for proper flame ignition for the complete dry cycle to determine if this may be the cause.
The drum seals are used to prevent excess air from entering the dryer drum and act as a cushion between the drum and the front and rear bulkheads. The drum seals are made up of a felt like material. If the seal is torn or is worn then clothing can become stuck in the gap when the drum is turning. This can produce a scraping or thumping noise and the clothes can also be ripped and/or have black marks on them.
DOOR SEAL When the door is closed in gas and electric dryers the door seal helps to keep cooler air from entering the drum.
The vent tube or line itself. If it is kinked, smashed, to long, or filled, clogged with lint build up it can not only cause slow dry times but create a fire safety hazard. Try to stay away from using plastic or flimsy cellophane venting, aluminum is best!
To provide better air flow and heat dissipation try the following
Note the length of your dryer vent is a determining factor in how efficient your dryer will perform. If the total length of your pipe exceeds 25 feet then your dryer simply won't be able to perform as should, especially if your pipe runs vertically and through the roof. This is where a booster fan is sometimes needed. Booster Fans provide the extra push of air to exhaust the moisture and lint to the outside. These fans operate only when the dryer is activated, this is done by sensing the air flow through the pipe by a pressure switch mechanism or an electrical sensing relay which in turn activates the booster fan blower. I personally try to avoid adding booster fans simply because they are usually placed in a crawl space or attic and are therefore "Out of sight and out of mind." What I mean is... the unit could malfunction and you would never be aware of it. The result would be a restriction in the pipe which would cause a build up of lint at the fan. In addition, it's recommended that lint traps be placed before the fan itself which has to be cleaned out frequently. These can also easily be overlooked.
1. On gas and electric dryers that have an "Auto Dry" cycle, the cycling thermostat is often used to advance the timer as well regulate the drum temperature. Essentially, thermostat will alternately turn on the heat source or the timer motor when the temperature has been satisfied. To check this thermostat, you will have to check for power to the timer motor with a multi-meter, during a cycle. This is a live voltage test and caution should be used.
2. Some dryers will use a cool down thermostat to tumble the clothes without heat, at the end of the dry cycle. Power is routed through this thermostat to the drive motor to keep it running until the drum temperature has dropped to a specific temperature. If this thermostat fails it can cause the drum to turn indefinitely or until the door is opened. You can check the thermostat for continuity with a multi-meter. This test should only be made with the power removed from the dryer.
Lastly check the moister sensor for OHMS according to ur schematic as it must show a certain amount of ohms as per ur unit. When unit has been on short while
Mar 28, 2016 | Roper Dryers
Dryer taking to long to dry
Overloading
1. One of the simplest problems to remedy could simply be that you are putting too many items inside the machine during the drying cycle. Avoid overloading your dryer, as this might cause your dryer to work extra hard to dry your clothing, extending the length of the dry cycle.
Wrong Heat Setting
2. A common issue with clothes dryers could be the wrong heat setting. Most home dryers feature several settings, from low heat settings to high heat and permanent press. Be sure the setting you choose is right for your needs. Another setting to check is the load size of your dryer. If you are drying a large amount of clothes, be sure the setting for large loads on high heat is selected. Choosing the wrong heat setting or load size can cause your clothes and linens to take longer to dry.
Lint Trap
3. One of the simplest fixes for drying issues might just be that your lint trap is clogged. Each time you use your dryer, lint will form in the trap. If the lint trap and vents are full, this could block air going into your dryer and slow down if not completely stop the drying process. After you use your dryer, remove this lint trap and empty it fully. Even if the lint trap is full, your other dryer vents might be clogged as well.
Clogged Vents
4. If your clothes are in the dryer for a long amount of time, but still not drying, the reason for this could be a clogged vent. A sign that your vent is clogged is if your clothes are warm or hot to the touch after sitting in the dryer, but still damp. To unclog your dryer vent, you may need professional assistance. This is especially necessary if your dryer vent leading out of the house is particularly long.
Heat Source
5. If the dryer is not getting enough heat to dry your clothes,something could be wrong with the heating system. After the drying cycle, touch your clothes to see if they are warm. If not, this means that the heating mechanism is malfunctioning. It will need to be repaired or replaced by a professional.
Feb 28, 2011 | GE Profile Harmony DPGT750GC Gas Dryer
Turn dryer on two or three times to completely dry clothes
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum.
Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Jan 25, 2011 | Roper REX4634KQ Electric Dryer
I have Roper Dryer #RED 4340sq1 the dryer can run all day it will heat up the wash room , but the will not be dry. The timer will remain at the same setting, so I replaced the timer with a new one and I...
Okay so the timer is not advancing in any cycle? if so its a bad clock on the back of your timer I know you put a new timer in the unit but I have seen them brand new and something be broke out the box with parts. after that or if the timer advances in the timed dry cycle its definitely a venting problem or a power issue need to make sure the vent is installed correctly no more than a 90 degree bend in the pipe and you don't want the vent hose longer than 4 feet hope this helps. If it still not drying correctly I would recommend you having a qualified service technician come to your home and inspect it to save you some time and money but hope this helps.
Jan 22, 2011 | Roper Dryers
Heat is not always coming on in dryer. Roper dryer from Lowes
There are numerous temperature sensors on the dryer. Some are near the drum, some could be near the lint filter if it is located inside the dryer door. Try changing these first as they are an in expensive fix. It could also be the heating coils themselves. Highly unlikely it would be the dial, unless the dial was accidentally turned in the wrong direction.
Apr 26, 2010 | Roper REX4634KQ Electric Dryer
I have a roper dryer Model RES7646KQ2. While I
Sounds like thermal cut off fuse has blown. That is indicative of airflow obstruction somewhere either internally in the dryer or venting from dryer to outside v
Nov 15, 2017 | Roper REX4634KQ Electric Dryer
Roper dryer stopped working during cycle REX6634RQO
replace your t-fuse again but also chekc to see if the vent going outside is restricted. if hte vent is smashed or clogged the heat has nowhere to go. i would say that is your issue. clean your vent before you change he t-fuse.
Jul 27, 2009 | Roper REX4634KQ Electric Dryer
Dryer comes on, dryer turns, dryer heats but does
make sure your vent is clear from dryer to outside the house.your keeping moisture in dryer and if it cant circulate the air out correctly your clothes will take forever to dry.
Mar 10, 2009 | Dryers
Dryer want heat
If the dryer is heating but not drying it is because of a clogged up dryer vent so disconnect it from the back of the dryer and if clothes dry then your vent is clogged and needs cleaned or replaced. please rate me
Jan 09, 2009 | Roper REX4634KQ Electric Dryer
What would cause intermittant heating in a Roper Electric Home Dryer?
the dryer vent, not the parts behind the dryer, where it goes into the wall to where the vent leaves the house has lint build up in it. this will cause the element to short cycle cause long dry times. if its really bad ive seen people have to run dryer 3 or 4 times to get clothes dry. clean out vent. this should solve problem
Nov 20, 2007 | Roper REX3614KW Electric Dryer
Dryers Logo
113 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
