Question about InFocus ScreenPlay 61" Rear Projection HDTV
Night and indoor scenes are too dark
The TV displays night and dim indoor scenes too dark. The usual on-screen adjustments will not correct this problem. Are there any other adjustments that can be made on this tv? I have not been able to find a service tech. manual.
  • Anonymous Nov 26, 2007
    I have the same problem and have tried to resolve it by adjusting the color, etc. By the time I finish with those adjustments to get a lighter picture, the picture is fuzzy. How can I find a repair person in San Diego, California?
    President:
  • 3,130 Answers
If the set is less then 2 years old it should still be under warranty. As I understand there is a 2 year warranty on this set. There is some adjustments to adjust on and inside this DLP TV set but they are not customer adjustments and should not be attempted without a service manual. They are on a service menu for the tech to access and adjust. My best suggestion would be to contact the manufacture from a contact number in the owners manual or from the store where you purchaced the set from or from a number I found for a main contact. Main support number 800-294-6400. Good Luck
Posted on Mar 20, 2007
2015 Territory, for 6 months, if headlights turned on in day, dash lights usually dim, centre panel unreadable, sometimes will not dim except at night. When new, latter was norm, but now as above.
This is a different model in the States. If this has a display for the Navigation there are controls to set for brightness and auto adjustment for day and night. These controls are reached within the programming of the Navigation screen and independent of the dash lights switch.
You are probably zoned out of making adjustments when the screen is dark. So you will need to tinker with this when you can see the screen better.
On our vehicles the headlight dimmer switch only controls the dash lights. Could be you had this vehicle serviced. Sometimes when an OIL CHANGE is done the service technician wants to reset the oil interval and goofs up some other settings in the process. Think about when the problem started and if someone else had their hands on your vehicle.
Jan 29, 2018 | Ford Territory Cars & Trucks
Color is grate on my Sharp 26" TV. However night scenes have become almost too dark to see. I have tried to adjust the settings but no improvement. Is this a fixable problem? Using Comcast Cable a
Check 'brightness' and 'contrast' settings in (usually) 'picture' menu. Use a recording (DVD etc.) of a dark scene to adjust the picture. My TV (not Sharp) has several pre-programmed picture settings. If yours has that, maybe one of them will be good. Otherwise, use manual settings.
Oct 18, 2014 | Sharp Televison & Video
Hitachi model 57SWX20B which has a dark screen
loss of brightness could need the mirror and lens cleaned and also the screen.if the tv is over 8 years old then the crts are getting weak.
Jul 28, 2009 | Hitachi 57SWX20B 57" Rear Projection...
I have a JVC tv only 1 year old and the picture is getting dark.
have you tryed adjusting the picture in the menu section! this may help!! or on back of tv is adjusters those may help as well.
Mar 24, 2009 | JVC AV-27920 27" TV
Sorry to tell you but JVC is a well-known un-reliable brand and if it's cheap, probably even worse. U may have screen burn from leaving a games console on while plugged into the tv, even if its not showing the game, it will burn it onto the screen. :(
Mar 24, 2009 | JVC AV27F476 27" TV
Picture getting dark
My jvc 27" tv was so dark I could hardly see any night scenes, even with the bright all the way on. If you push the sleep button, let go, then hold down the video and display (together), the service menu will come on. Scroll down to #7 (too dark) and adjust the brightness there. Works immediately. Good luck.
Nov 29, 2008 | JVC AV-27530 27" TV
How to increase brightness in Canon Powersot A620 ?
Are you asking about brightness as viewed on the LCD, or are you asking about increasing brightness on the actual image taken? If it's the image, there are two special modes that you can select on your mode dial. They are "Night Scene", "Night Snaphot", and "Indoor". A description of both, along with your camera's other special settings, may be found here:
http://www.canon.co.jp/imaging/mode/camera/scene-e.html
"Night Scene" can be selected directly from the dial. It's the one showing a person standing under a star. Note that Night Scene should be used with a tripod to reduce the potential for blurriness.
"Night Snapshot" works almost as well, but does not require a tripod. It can be accessed by selecting SCN on the dial, and then pressing right or left with the selection buttons until it shows in the menu. The camera will remember this setting the next time you select SCN. I usually keep my camera always set to this setting so that I merely have to select SCN to use it.
"Indoor" works very well in those large rooms that may produce dark backgrounds when taking photos. It also does not require a tripod. It's accessed the same way as "Night Snapshot" (Select SCN, then right/left until selected). This is another good setting that I like to keep sometimes set in SCN.
Try all three settings, (and don't forget all the others too). Think you'll be impressed.
Feb 23, 2008 | Canon PowerShot A620 Digital Camera
Dark screen
try to adjust your Contrast and Brightness settings to your desired option.ok??
Jan 15, 2008 | Zenith IQB50M90W 50" Rear Projection...
Jvc av 27530
**WORKS**
In my case, the adjustment was available from outside the TV. Sortof. On the rear of the TVabout 2 inches to the right of the coax in, there are two vertical slits on a little protrusion. Inside the slits are the two adjustment screws. The lower screw adjusts brightness, the upper screw adjusts focus.
Dec 23, 2007 | JVC AV-27530 27" TV
Night or dark scenes are too black
take your set to a tech for adjustment of the focus.
Apr 03, 2007 | JVC AV-48WP30 48" Rear Projection...
InFocus ScreenPlay 61" Rear Projection HDTV Logo
509 people viewed this question
Top InFocus Televison & Video Experts
Donni Steen
rostit
Are you an InFocus Televison and Video Expert? Answer questions, earn points and help others
