Question about Sony KDSR50XBR1 50" Projection HDTV
Too much green on Sony KDS-R50XBR1
Can't adjust the colors. lots of green and less red and other colors? what should I do? I bought this TV in March 2006. I got it from Circuit City.
  • 1 more comment
  • c_wel Dec 20, 2008
    Same problem here, TV is just over 2 years old and I just replaced the lamp. Called Sony support, they did some basic troubleshooting (unplug the TV, reset, etc) then suggested I called a service agent.
  • Dennis Emerson Dec 23, 2008
    i have the same problem with my grand wega. i just replacd the lamp and the color is full fo reds and greens also with double red images.
    i have the same problem with my grand wega. i just replaced the lamp and now the picture is full of reds and greens. and double red images.
I have the same model and mine did the same thing last year. Initially had the "green blob" problem, but then it seemed like overnight, an overpowering green push that I could not correct with the full range of white balance controls. Turned out to be the dreaded bad optical block. The OB's are a known problem with this set and its 60" sibling, and the basis of a class action lawsuit against Sony. Under the settlement of the lawsuit, Sony has extended the warranty only for the optical block until June 2009. You can find out more than you wanted to know about it on the AV Science Forum at and they have a link to Sony's web page for this problem. BTW, after my optical block replacement (at no cost), my set has a very faint pinkish to greenish color impurity which fades to nearly imperceptibile after warmup. It hasn't gotten worse over the past year and it doesn't bother me enough to risk having it replaced with another OB which could be worse. Bottom line: it sounds like you need and optical block replacement, which Sony is having done in-home at no cost to you.
Posted on Dec 24, 2008
I have a sony tv kds-r50xbr1 first the color was green and now there is no picture at all.. flashing red light that says lamp
Feb 23, 2010 | Sony Televison & Video
Light Engine Call Encompass Parts Distrubtion
1-800-638-3328 and Call UED 1-800-648-6657 Just see which one has the lowest Price.
Dec 31, 2009 | Sony KDS-60A2000 60" HDTV
Sony KDS-R50XBR1 50 in. HDTV picture cycles on and off
It is clear symptoms of weak lamp in TV, replace lamp to correct that problem.
Lamp replacement is easy and written in user manual of TV.
Please buy Sony original lamp for TV safety.
Nov 17, 2009 | Sony KDS-R50XBR1 50" HDTV
if all sources and hdmi cable are good--you need the hdmi input board--dont know sonys letter designation
Jul 22, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony kds-r50xbr1 turns itself off and then green light blinks 52
I too have a Sony KDS-R60XBR1 tv and the issue that you are experiencing is due to one of your fans in the rear of the tv is not working.  The tv automatically shuts off in protective mode.  Make sure the POWER/STANDBY light is blinking and not the lamp light below it.  Is the power/standby blinking 4 times in red? If, yes then its a fan that needs to be replaced.  If its the lamp light blinking then you need to replace the lamp.  The lamp is easy to replace by ordering the lamp either from Sony for $250 or find it cheaper for approx. $150 from other DLP sources and replace youself by following your manual.  I hope this helps you.
Apr 22, 2009 | Sony KDS-R50XBR1 50" HDTV
Sony kds-r50xbr1 turns itself off and then green light blinks 52 times
Just replace its Lamp and procedure is written in user manual of KDS-R50XBR1
F93087600 XL-5100 LAMP BLOCK
Lamp is available in Sony Accessories and price is $250
Always buy Sony original lamp for good picture in TV and avoid aftermarket / cheap lamps that can cause damage of TV circuits.
Click Sony Support to download Instruction Manual copy, if you want it.
Apr 22, 2009 | Sony Video Cameras
KDS-R50XBR1 5 red blinks
If you are positive that the fan is still running and that it isn't an over heating issue, I would venture to say you need a new dlp lamp. Your model uses a Sony XL 5100 dlp lamp. You can grab one over at
Feb 15, 2009 | Sony KDS-R50XBR1 50" HDTV
9 red blinks
Can you verify that its 9 blinks? There is no error code in that set for 9. also please verify that its a kdsr50xbr1
Jun 29, 2008 | Sony KDS-R50XBR1 50" HDTV
Sony KDS-R50XBR1 9 red blinks
Isn't that the idicator telling you that its time to change the dlp lamp?
Jun 28, 2008 | Sony KDS-R50XBR1 50" HDTV
WEGA only show yellow
Hello watts74:
When you turn your tv on, you still get an image of whatever channel you are on, but the background on the entire screen is green/yellow, correct? If so, the problem is the optical block. Read what I posted below on another thread and you should be on your way to getting your situation resolved.
Here is the link to the other thread I mentioned:
All the best...
By nonexpert_s.gif KDS-R50XBR1
Rank: Apprentice
Rating: 0%, 0 votes
If your SONY KDS-R50XBR1 or KDS-R60XBR1 color screen suddenly turns green, the optical block (aka light engine) is the culprit. Don't fret because as "Leadtech" has already posted back on Jul 04, 2007, SONY is aware of this problem and has extended the warranty to replace this very part. Additionally, and aside from the class action lawsuit currently pending in district court, parts and labor for in-house service IS included.
SONY states the warranty as follows:
"As part of the Sony commitment to quality, Sony is announcing that it is extending the limited warranty (parts and labor), in the United States, on the optical block of KDS-R50XBR1 and KDS-R60XBR1 model SXRD televisions until October 31, 2008, regardless of purchase date."
So all you have to do is:
1) Contact SONY Customer Service at (800) 222-7669 or (888) 772-7669 - Hours: Mon-Fri 9:00AM-10:00PM / Sat-Sun 10:30AM-7:15PM EST
2) Provide them with your model (as above) and your television's serial number
3) Tell them your screen color is nothing but green
4) They will provide you with a case number
5) They will ask you for your zip code and provide you with one or more SONY authorized service dealers, and their contact information.
6) You contact the dealer of your choice and schedule an in-house service. Explain to them that your screen is green and you are aware that many, same tv-model owners that have had this same problem, and that the optical block is the problem.
7) The SONY authorized dealer you speak with will schedule and appointment with you, and will provide in-house service.
Regarding the service, it will take about an hour to complete. Not that it is complicated for the technician, but where the optical block is located is that is time-consuming. It sits just "behind" the bottom of the tv screen and in order to get to it, the technician will have to:
1) Remove the bottom back gray cover
2) Remove the replaceable projection lamp located on the left side of the tv (looking from the back)
3) Remove lots of phillips screws
4) Disconnect many plugs
5) Remove 3 chassis closest to the back of the tv before getting to the optical block chassis, which is located up front, just behind the tv screen
Once the optical block is replaced, you will be amazed on correct color results.
Hope this helps...
Oct 15, 2007 | Sony KDS-R50XBR1 50" HDTV
Open Questions:
Sony KDSR50XBR1 50 black screen, no faults! Lamp working, fans OK Sony KDSR50XBR1 50" HDTV: The light engine was working fine before the fan quit starting on it's own. After disassembly, cleaning and lubrication of the fan, I have no errors but the input display or menu options will not post on the screen. The lamp is on but seems to either be projecting a solid black picture, or not be at full brightness and there are no faults. I have a solid greed LED on top, but can get no picture. Sound is fine. What should the lamp voltage be at operating mode? I have tried reseating connectors and pushing on the wires to make sure the connectors seat. This is baffelling because the lamp fired fine for 1 second before the stuck fan issue was corrected and I have no faults now after lubricating the fan. I'm going to check connectors again today as a triple check; as I did remove the power supply. The TV has been reset per instructions in the book. Any advice would be much appreciated but I cannot believe it's the OB as it worked fine before the fan quit and it's about 14 months old. I'm thinking something may not be assembeled correctly, but everthing seems to be pretty idiot proof for re-assembly. Also the menu or input banners will not post. I have 2 new lamps, so it's not that.It seems to be stuck in somne black screen mode. The large fan does start by itself now after cleaning and lubrication, therefore no fault blinks. Please help!!!
Mar 01, 2017 | Sony KDSR50XBR1 50" Projection HDTV
Sony KDSR50XBR1 50" Projection HDTV Logo
121 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
